Spinner strobing as a "Bird Strike Countermeasure"
Old December 4th 07, 06:25 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mxsmanic
Default Spinner strobing as a "Bird Strike Countermeasure"
Gig 601XL Builder writes:
Wrong, exactly backwards wrong. Rutger was correct.
The frame is a painted raster. The image is the complete set of visual data
for simultaneous assimilation.
  #82
Mxsmanic
writes:
You do know this stuff is archived ...
That's the best part.
  #83
Old December 4th 07, 06:26 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mxsmanic
Yes - I have a name writes:
I'm sure I've seen wheels on cars that appear to be moving backwards. Are my
eyes defective?
No, but your memory is imperfect. You've never seen that in real life, only
on TV and in films, or under stroboscopic lighting.
  #84
Old December 4th 07, 06:28 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mxsmanic
Maxwell writes:
This phenomenon is apparent to the naked eye under continuous
lighting conditions.
No, it is not.
You might need to wait for a three or four blade prop, but
it DOES happen in real life.
No, it does not. Continual assertions to the contrary will not change this.
  #85
Old December 4th 07, 06:29 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Maxwell
"Mxsmanic" wrote in message
my
eyes defective?
only
No it's because YOU have never seen anything in REAL LIFE retard.
If it hasn't been on a tv or computer screen, you have so little experience
YOU don't realize it exists.
  #86
Old December 4th 07, 06:33 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Yes - I have a name[_2_]
Are my
eyes defective?
only
Translation: I don't understand it, so it can't happen.
Looks like I've been MXed (The absolute denial of common knowledge).
  #87
Old December 4th 07, 06:46 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Paul Tomblin
eyes defective?
Wikipedia references some scientific papers that show three distinct cases
of people seeing it non-strobing (ie natural sunlight).
1. People see the effect on car wheels, mostly because hubcaps have
reflective surfaces that cause a strobing of the light in natural
sunlight, but also because of other things changing the light, like
shadows or the reflection off other objects.
2. People see the effect when their eyes are being vibrated. The article
addresses people seeing it when humming, but I suspect the same effect
could happen with the low frequency noise that permeates an airplane
cockpit.
3. There is some controversy about an effect that *some* people see when
they stare at a moving pattern of dots for periods of time greater than 30
seconds (some needing to stare as long as 10 minutes before they see it).
Some scientists are saying that it shows that our brain processes vision
in discrete frames. Others say it's a totally different effect.
I've never seen it in the air, and I'd never heard of it until I read the
wikipedia article, but it turns out that Maxwell and others are correct
and you're wrong. I guess I should have known.
Paul Tomblin http://blog.xcski.com/
"My band is called Imation CDR 74m 650 MB...have you seen our CDs?"
  #88
Old December 4th 07, 06:49 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
Shut the **** up, MX.
So Say We All!
  #89
Old December 4th 07, 07:23 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mxsmanic
I've studied it, and I understand why it cannot happen.
  #90
Old December 4th 07, 07:24 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Mxsmanic
Paul Tomblin writes:
... I'd never heard of it until I read the
wikipedia article ...
What does that tell you about the Wikipedia article.
... but it turns out that Maxwell and others are correct
Consult multiple sources, and be especially wary of Wikipedia.
Saturday 072807 in Oshkosh Pt 6 - Warbird show pix I forgot to post earlier [10/33] - "Bird Dog.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 10:48 PM
"British trace missile in copter strike to Iran" Mike[_7_] Naval Aviation 8 March 10th 07 08:20 PM
Bird strike(s) Jay Honeck Piloting 45 November 30th 05 04:39 AM
Bird strike Jase Vanover Piloting 16 May 17th 05 11:44 AM
