Night VFR following highways
Old February 1st 08, 06:28 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Default Night VFR following highways
Is it a bad idea to fly VFR at night and navigate by following highways? At
night outside large cities, there doesn't seem to be much else that's visible.
It seems to me that if you can clearly see the highway, it can guide you and
you can get a good idea of where you are with respect to terrain, so it should
work. Are there hidden dangers in this? Do night VFR pilots ever/often
navigate by following highways? What other forms of visual navigation are
usable at night?
Old February 1st 08, 06:57 PM posted to rec.aviation.student,rec.aviation.piloting
Ross
usable at night?
Why would you want to when VORs ang GPSs are available? However, on a
clear night you can see the far away town lights. You just need to be
sure that the lights you see are the town you want. I'll stay with my
GPS for navigation.
Regards, Ross
C-172F 180HP
KSWI
Old February 1st 08, 07:03 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Ross writes:
Mainly just for practice, in case the radio navigation fails or something.
However, on a
GPS for navigation.
What if the GPS stops working?
Old February 1st 08, 07:28 PM posted to rec.aviation.student,rec.aviation.piloting
Bertie the Bunyip[_25_]
Mxsmanic wrote in
Ross writes:
something.
Why, you don't fly.
Or is your latest terorist target a night target?
Bertie
Ross wrote in
highways? At night outside large cities, there doesn't seem to be
much else that's visible. It seems to me that if you can clearly see
the highway, it can guide you and you can get a good idea of where
you are with respect to terrain, so it should work. Are there hidden
dangers in this? Do night VFR pilots ever/often navigate by
following highways? What other forms of visual navigation are usable
at night?
If you're flying a no radio airplane?
Bertie
Old February 1st 08, 07:57 PM posted to rec.aviation.student,rec.aviation.piloting
Ross
Bertie the Bunyip wrote:
Ross wrote in
at night?
Bertie
Then I guess I would follow roads, but might buy a handheld GPS if I was
going to do a lot of this.
Regards, Ross
C-172F 180HP
KSWI
Old February 1st 08, 08:59 PM posted to rec.aviation.student,rec.aviation.piloting
gatt[_2_]
My father-in-law (ANG helicopter crewman) takes "IFR" to mean "I Follow
Roads " (or rivers)
At night outside large cities, there doesn't seem to be much else that's
visible.
and
should
work.
Sure. For example, Interstate 5 runs from Canada to Mexico, and the stretch
through most of Oregon looks like somebody drew a straight line with a
pencil across the landscape. If you were flying from Portland (possible
Seattle) to Eugene, Medford, Sacramento, etc, day or note you could follow
the freeway the entire route.
You'd still use your VFR navigation aids and checkpoints to make sure know
how far you are enroute, and also to avoid controlled airspace, etc, but
having that road, railroad, river makes for a more-enjoyable flight.
-c
Old February 1st 08, 11:16 PM posted to rec.aviation.student,rec.aviation.piloting
Rich Ahrens[_2_]
I followed a highway up to Alaska. In daylight,however.
Old February 2nd 08, 02:16 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
gatt writes:
Roads " (or rivers)
There is a sobering story right along those lines at
http://www.aopa.org/pilot/never_again/2008/na0801.html
I find it interesting that the author says this VFR flight scared him more
than any of his combat missions in Vietnam.
Good. I wanted to make sure I'm not missing some risk or danger to following
highways. From the article above I learned that things like wires and cables
are a real risk if you're very close to the highway, but only a helicopter
would be that low.
Old February 2nd 08, 10:02 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic wrote in
gatt writes:
Follow Roads " (or rivers)
more than any of his combat missions in Vietnam.
stretch through most of Oregon looks like somebody drew a straight
line with a pencil across the landscape. If you were flying from
Portland (possible Seattle) to Eugene, Medford, Sacramento, etc, day
or note you could follow the freeway the entire route.
know how far you are enroute, and also to avoid controlled airspace,
etc, but having that road, railroad, river makes for a more-enjoyable
flight.
following highways. From the article above I learned that things like
wires and cables are a real risk if you're very close to the highway,
but only a helicopter would be that low.
Wow, hittign a virtual wire in a virtual airplane could really ruin your
day if you were insane!
Bertie
Arizona Highways magazine on soaring, flight [email protected] Soaring 0 December 20th 06 03:05 AM
Night Flying. How many PPSEL pilots excersie night priveledges? [email protected] Piloting 42 December 16th 06 04:51 PM
Night lights, night flights, OLC and records Denis Soaring 19 October 9th 06 11:51 PM
Hood and sim work at night loggable as night time? Ron Garret Piloting 12 September 9th 06 02:15 AM
FS2004 scenery which shows roads and highways? John Doe Simulators 9 March 25th 04 08:36 AM
