Minimum rates of climb/descent for VFR
Old February 15th 08, 09:33 PM posted to rec.aviation.student,rec.aviation.piloting
Bertie the Bunyip[_25_]
Default Minimum rates of climb/descent for VFR
WingFlaps wrote in
On Feb 16, 9:52Â*am, Bertie the Bunyip wrote:
WingFlaps wrote
innews:b3a149c7-a9b9-4be1-b6fe-b9450
On Feb 16, 4:14Â*am, Mark Hansen wrote:
On 02/15/08 01:53, WingFlaps wrote:
On Feb 15, 9:19�am, Gig 601XL Builder wrgiac...@REMOVEgmail.
com
WingFlaps wrote:
On Feb 15, 12:31 am, "John" wrote:
No there are no regulations for climb or descent rates for
VFR fligh
t.
Err I don't think that's 100% correct but it will do for MX.
Cheers
Please then for my benefit point me to such a regulation.
Certainly. Vne is a limit that must not be exceeded (there are
others). This sets a limit on how fast you can legally descend
(remember pilots must fly within operating limits). You must
also not use ascent or descent rate that put you in conflict
with ATC unless you have got clearance. When NORDO you cannot
ascend or descend into controlled space except as part of a
flight plan.
What? You believe that an aircraft with no radio is not allowed to
enter controlled airspace without being on a flight plan?
Can you please provide a reference to that regulation?
Â* Â* Â* Â* Â* Â* Â* Â* Â* Â*
Â* Â* Â* Â* Â*The descent rate at
or below 500' must be zero or negative except at an aerodrome or
within a LFZ. You can probably now see other examples. Pilots
should think outside the box ;-)
An towered airport is controlled airspace so:
Unless otherwise authorized or required by ATC, no person may
operate an aircraft to, from, through, or on an airport having an
operational control tower unless two-way radio communications are
maintained between that aircraft and the control tower.
Communications must be established prior to 4 nautical miles from
the airport, up to and including 2,500 feet AGL. However, if the
aircraft radio fails in flight, the pilot in command may operate
that aircraft and land if weather conditions are at or above basic
VFR weather minimums, visual contact with the tower is maintained,
and a clearance to land is received. If the aircraft radio fails
while in flight under IFR, the pilot must comply with §91.185.
Flown nordo into controlled fields loads of times..
Not usually a prob. No flight plan either. Just called the tower by
phone before i departed or flew as a flight of two.
Yes, in my thinking that call to the tower established a plan.
Hmm, dunno. I suppose it does. You'd have to ask an ATC type how they'd
classify it, but it's a clearance into the zone at least.
bertie
  #83
Old February 15th 08, 11:05 PM posted to rec.aviation.student,rec.aviation.piloting
Mark Hansen
No there are no regulations for climb or descent rates for VFR flight.
Cheers
(remember pilots must fly within operating limits). You must also not
use ascent or descent rate that put you in conflict with ATC unless
you have got clearance. When NORDO you cannot ascend or descend into
controlled space except as part of a flight plan.
Actually, your statement was much broader than "Class D airspace". It
was "controlled airspace".
But I can see from your response that it's of no value to argue the
point with you - so I won't.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
  #85
Old February 16th 08, 02:20 AM posted to rec.aviation.student,rec.aviation.piloting
On Feb 15, 6:31 pm, Bertie the Bunyip wrote:
wrote in news:17f19905-7814-446d-9800-
On Feb 15, 8:23 am, Bertie the Bunyip wrote:
All da time in da USA!
Nope.
Yep.
Prove it.
For many heavies, min clean speed on takeoff is often over 250 knots and
they have permission to exceed 250 every time they need to.
Yes, but that's done in accordance with the regulation, not under a
waiver from it.
Nope
Yup:
§ 91.117 Aircraft speed.
(a) Unless otherwise authorized by the Administrator, no person may
operate an aircraft below 10,000 feet MSL at an indicated airspeed of
more than 250 knots (288 m.p.h.).
(b) Unless otherwise authorized or required by ATC, no person may
operate an aircraft at or below 2,500 feet above the surface within 4
nautical miles of the primary airport of a Class C or Class D airspace
area at an indicated airspeed of more than 200 knots (230 mph.). This
paragraph (b) does not apply to any operations within a Class B
airspace area. Such operations shall comply with paragraph (a) of this
section.
(c) No person may operate an aircraft in the airspace underlying a
Class B airspace area designated for an airport or in a VFR corridor
designated through such a Class B airspace area, at an indicated
airspeed of more than 200 knots (230 mph).
(d) If the minimum safe airspeed for any particular operation is
greater than the maximum speed prescribed in this section, the
aircraft may be operated at that minimum speed.
[Doc. No. 18334, 54 FR 34292, Aug. 18, 1989, as amended by Amdt. 91-
219, 55 FR 34708, Aug. 24, 1990; Amdt. 91-227, 56 FR 65657, Dec. 17,
1991; Amdt. 91-233, 58 FR 43554, Aug. 17, 1993]
  #86
Old February 16th 08, 02:21 AM posted to rec.aviation.student,rec.aviation.piloting
On Feb 15, 8:04 pm, Bertie the Bunyip wrote:
wrote :
On Feb 15, 9:02 am, Bertie the Bunyip wrote:
Mxsmanic wrote
Steven P. McNicoll writes:
The 250 KIAS speed limit can be waived but very seldom is.
It cannot be waived by ATC, but the FAA can waive it--not something
it's likely to do in real time for individual flights, though.
Wrong again fjukktad.
He's right, you're the fjukktad. (Whatever that is.) The 250 KIAS
rule can be waived by the Administrator but not by ATC.
Nope
Yup:
section.
  #87
Old February 16th 08, 03:11 AM posted to rec.aviation.student,rec.aviation.piloting
On Feb 15, 9:21 pm, wrote:
Nope
Yup:
(a) Unless otherwise authorized by the Administrator...
Any possibility the Administrator has delegated it internally within
FAA?
F--
  #88
Old February 16th 08, 03:30 AM posted to rec.aviation.student,rec.aviation.piloting
wrote in
wrote
innews:0f15696b-ff1a-486f-8ae3-5aff769cbf76@j
28g2000hsj.googlegroups.com:
something it's likely to do in real time for individual flights,
though.
Nope
Yup:
Nope.
section.
  #89
Old February 16th 08, 03:31 AM posted to rec.aviation.student,rec.aviation.piloting
wrote in
Nope.
Yep.
Prove it.
knots an
d
waiver from it.
Nope
Yup:
Nope
Bertie
section.
Descent below MDA -- what would you do? Roy Smith Instrument Flight Rules 50 August 29th 05 12:39 AM
ANR squeal on descent Juan Jimenez General Aviation 13 August 19th 05 10:39 PM
descent below minimums hsm Instrument Flight Rules 82 January 11th 05 06:33 PM
BRS and descent rate Roger Long Piloting 21 May 7th 04 05:34 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
