#81
![]() "Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in news:rG8Sj.111613$Ft5.59820 @newsfe15.lga: "Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in : "Buttman" wrote in message ... Bertie the Bunyip wrote: Buttman wrote in : WingFlaps wrote: On Apr 27, 7:03 am, Mxsmanic wrote: I just tried a few experiments No, that doesn't sound right. The stall horn is supposed to sound before the stall speed is reached. Cheers "supposed to", but doesn't always. I've flown planes (especially cessnas with their crappy cereal-box-toy-quality plastic stall horns) that don't go off at all, but will test fine on the ground. What, you didn't stick chewing gum in them to fail them so your students would learn what it was like when they failed? Bertie Oh bertie, you're such a card Na, not really. Just a self made prick. Moi? never. Nope. I just treat people exactly as the expect to be treated. Fjukktard. Bertie So you want people to follow you around and call you a Fjukktard? I don;t want them to, but they can if they like. You recommend it do you, heroin boi? Bertie That's what you said dip ****. Try to keep up, uh? |
#82
I'm not sure I understand: Are you saying that you can do slow flight in
the sim as in the real aircraft, except that you have to do it by instruments, or are you saying that the sim doesn't correctly simulate slow flight at all (i.e., it can't be done)? Sorry, I lost this thread beneath the avalanche of Bertie/Maxwell crap. It's amazing the depths to which so-called "real" aviators can sink. Anyway, the former is correct. Other than engine sound there is no "feel" in the sim, so everything in slow flight mus be done on instruments. Interestingly, we were trying to spin one of the Mustangs (that comes with the Acceleration package), and were unable to do so. It just would not break, even fully cross-controlled at the stall. Perhaps Dudley can comment on this, as I was under the impression that Mustangs would spin pretty easily. Also, are you using the default aircraft or have you installed add-on aircraft? For the Cessna I'm flying, I use Carenado's Cessna 182RG II simulation, which is supposedly pretty good (vastly better than the default Cessna, of course). Nope, I was referring to default aircraft. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#83
Looked at another way, if I trim on base and again on final, I will need
two hands pushing the yoke forward if I mosh the throttle for a go-around (until I retrim for climbout). My guess is I would stall quite dramatically if I didn't. My Beech is no different. Same with my Piper -- and every other plane I've flown, with the exception of the Ercoupe. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#84
If you show significant climb rate with a single piston your sim is
smoking tobacco substitute. 1500 fpm climb isn't unreasonable in a lightly loaded 182 on a cold day. Our Pathfinder (basically a "Piper 182", with the wing on the proper side) easily hits 1500 fpm with just Mary and me on board in the winter. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#85
On 2008-05-01, Jay Honeck wrote:
If you show significant climb rate with a single piston your sim is smoking tobacco substitute. 1500 fpm climb isn't unreasonable in a lightly loaded 182 on a cold day. Unfortunately, "significant" is one of those weasel words: you can argue that 1500 fpm is 'not a significant climb rate', but someone else can argue that 500 fpm is significant :-) Many light singles can do 1500 fpm or better, not even on a cold day. The S-35 Bonanza we used to have in the club would do 1800 fpm with two on board. Our 160 hp Auster will happily do 1600 fpm... at 60 mph (leading to a pretty decent climb angle). I bet a Super Cub with a similar engine could do that too. -- From the sunny Isle of Man. Yes, the Reply-To email address is valid. |
#86
Jay Honeck wrote:
I'm not sure I understand: Are you saying that you can do slow flight in the sim as in the real aircraft, except that you have to do it by instruments, or are you saying that the sim doesn't correctly simulate slow flight at all (i.e., it can't be done)? Sorry, I lost this thread beneath the avalanche of Bertie/Maxwell crap. It's amazing the depths to which so-called "real" aviators can sink. Anyway, the former is correct. Other than engine sound there is no "feel" in the sim, so everything in slow flight mus be done on instruments. Interestingly, we were trying to spin one of the Mustangs (that comes with the Acceleration package), and were unable to do so. It just would not break, even fully cross-controlled at the stall. Perhaps Dudley can comment on this, as I was under the impression that Mustangs would spin pretty easily. Also, are you using the default aircraft or have you installed add-on aircraft? For the Cessna I'm flying, I use Carenado's Cessna 182RG II simulation, which is supposedly pretty good (vastly better than the default Cessna, of course). Nope, I was referring to default aircraft. Power off erect spin mode in a P51 is normal and recovery is normal; similar to the T6. Power on spins can be unrecoverable in the Mustang and you can lose tremendous amounts of altitude. Not recommended! -- Dudley Henriques |
#87
![]() "Jay Honeck" wrote in message news:y3jSj.144815$yE1.73334@attbi_s21... -----------some snipped--------------- Sorry, I lost this thread beneath the avalanche of Bertie/Maxwell crap. ----------remainder snipped------------- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Jay, Please observe the "path" which is really quite illuminating... Peter |
#88
news:y3jSj.144815$yE1.73334@attbi_s21: I'm not sure I understand: Are you saying that you can do slow flight in the sim as in the real aircraft, except that you have to do it by instruments, or are you saying that the sim doesn't correctly simulate slow flight at all (i.e., it can't be done)? Sorry, I lost this thread beneath the avalanche of Bertie/Maxwell crap. It's amazing the depths to which so-called "real" aviators can sink. Anyway, the former is correct. Other than engine sound there is no "feel" in the sim, so everything in slow flight mus be done on instruments. Interestingly, we were trying to spin one of the Mustangs (that comes with the Acceleration package), and were unable to do so. It just would not break, even fully cross-controlled at the stall. Perhaps Dudley can comment on this, as I was under the impression that Mustangs would spin pretty easily. it's a toy, not an airplane, dip****. Bertie |
#89
news:y3jSj.144815$yE1.73334@attbi_s21: I'm not sure I understand: Are you saying that you can do slow flight in the sim as in the real aircraft, except that you have to do it by instruments, or are you saying that the sim doesn't correctly simulate slow flight at all (i.e., it can't be done)? Sorry, I lost this thread beneath the avalanche of Bertie/Maxwell crap. IOW you were lying through your teeth about your killfile. Not to mention the big lie.... Bertie |
#90
![]() Bertie Certainly not stupid. He reads your nonsense in my replies. |
The Sky is Their Limit | [email protected] | Soaring | 7 | November 13th 06 02:44 AM |
speed limit in class B | Andrey Serbinenko | Piloting | 0 | July 23rd 06 04:05 AM |
Pegasus life limit | Mark628CA | Soaring | 2 | March 30th 06 10:37 PM |
Aft CG limit(s) | Andy Durbin | Soaring | 13 | November 26th 03 05:10 AM |
Pushing the limit | Dan Shackelford | Military Aviation | 20 | September 14th 03 10:27 PM |
