Piper Cherokee RFI Capacitor
Old January 12th 04, 06:30 PM
Nathan Young
Default Piper Cherokee RFI Capacitor
Where is the RFI capacitor typically located in a 1971 Piper Cherokee 180?
On the firewall? In the cabin? Next to the battery?
Here's a link to the Cherokee electrical schematic.
http://www.needlescentered.com/cherokee_electrical.htm
Thanks,
Nathan
Old January 12th 04, 07:09 PM
Jay Masino
Usually, it's bolted to the alternator (with it's wire connected directly
to the output terminal of the alternator).
--- Jay
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino/ ! ! !
Checkout http://www.oc-adolfos.com/
for the best Italian food in Ocean City, MD and...
Checkout http://www.brolow.com/ for authentic Blues music on Delmarva
Old January 12th 04, 07:21 PM
mikem
Thanks,
Nathan
On the alternator.
What kind of RFI are you experiencing?
Things that cause RFI in GA airplanes:
Brush arcing in electric Turn Coord.
Brush arcing inside the alternator.
Brush noise in electric motor (such as old rotating beacons)
Bad shields on spark wires
Bad shields on P-leads
Bad shields on strobe wiring
MikeM
Old January 12th 04, 10:37 PM
COUGARNFW
Your schematic shows it attached to the alternator.
Having said that, sometimes they are on the backside outside but if the
alternator has been replaced....might be inside.
Neal
Old January 12th 04, 10:45 PM
Nathan Young
On Mon, 12 Jan 2004 12:21:37 -0700, mikem
Thanks,
Nathan
On the alternator.
Thanks Mike,
Fortunately, I do not have any RFI problems with the plane. The
radios are clear, and the voltage is stable (ammeter is stable too).
However, I've been debugging a problem with my charging system, and
spent some time looking at the schematics. While doing this, I
realized had no idea where the RFI cap sits...
I checked this afternoon. It is mounted on the engine side of the
firewall. The model is a Hisonic RFI 70. It's probably as old as the
plane, so I wonder if it has any capacitance left, or is merely along
for the ride.
-Nathan
Old January 14th 04, 01:25 AM
MikeM
for the ride.
-Nathan
If that Hisonic box is about 2" X 3" X 4", and has two terminals
(instead of one), it is actually a low pass filter containing series
rf chokes wound on ferrite as well as shunt capacitors. If it has just
one terminal, then it is likely just a shunt capacitor, where the
case is the other side...
In either case, the case has to be well grounded for it to have any
effect. The capacitor(s) in these things are high quality, and usually
do not dry out.
Mike M
Skylane '1MM
Pacer '00Z
Old January 14th 04, 04:15 AM
Nathan Young
On Tue, 13 Jan 2004 18:25:43 -0700, MikeM
for the ride.
-Nathan
do not dry out.
Thanks again Mike. The box is as you describe. A terminal on either
side, and presumably ground on the case...
-Nathan
Old January 16th 04, 05:09 PM
mikem
for the ride.
-Nathan
do not dry out.
-Nathan
btw- I dont think that this big LPF box is standard equipt. It was
probably added by somebody (probably without logging the work) in a
misguided attempt to cure "alternator whine" in the radios. The Hisonic
filters are RF lowpass; they are NOT effective at audio frequencies and
do NOT filter alternator ripple at audio frequencies.
Brush arcing in an alternator causes RF noise (hash), and the shunt
hypass (oil filled tub) capacitor was usually installed at the factory
to suppress this RF at its source. The RF noise out of an unsuppressed
alternator will clobber ADF and Loran frequencies (100-500Khz), but will
rarely effect a VHF (120MHz) radio, so even if there is no bypass
capacitor on your alternator; you are not likely to hear hash in a VHF
radio.
Alternator whine (& Strobe squeal) is not caused by radiated RFI
travelling from the alternator to a VHF antenna. Rather, they are
usually caused by alternator ripple currents flowing along the airframe
coupling into the audio system. Said coupling can be fixed by correctly
wiring the audio system so as to eliminate multiple grounding points
(single point ground). Naive avionics techs and owners install the big
Hisonic box filters on their alternator output lead as a bandaid which
rarely works to eliminate alternator whine; however, they will improve
ADF and/or Loran reception.
MikeM
Pacer '00Z
Skylane '1MM
FS: several Piper parts (long) Jay Masino Aviation Marketplace 0 September 15th 04 01:09 AM
Cherokee National Fly-In & Convention - THIS MONTH Don General Aviation 0 June 3rd 04 05:01 AM
Piper Cherokee RFI Capacitor mikem Home Built 0 January 16th 04 05:09 PM
replacement rotating beacon for 64 piper cherokee Patrick Mathews Owning 2 October 1st 03 01:55 PM
FS: Piper Side Window (New) JimC Aviation Marketplace 0 August 10th 03 12:19 PM
