Connecting my 2 Batteries to 1 Solar Panel
I would like to connect my 2 8AH batteries to one Solar panel for charging while the glider is in its trailer. I will use a controller and I have 2 separate sockets in the glider-one per battery.
I thought to simply split the wires coming out of the controller to the two batteries/sockets but I came across this: http://www.morningstarcorp.com/en/su...ller.01.EN.pdf, Any suggestions? Dan G |
On 12/31/2012 6:49 PM, Dan G wrote:
I would like to connect my 2 8AH batteries to one Solar panel for charging while the glider is in its trailer. I will use a controller and I have 2 separate sockets in the glider-one per battery. I thought to simply split the wires coming out of the controller to the two batteries/sockets but I came across this: http://www.morningstarcorp.com/en/su...ller.01.EN.pdf, Any suggestions? It looks like it would work adequately for your 8 AH batteries. If not, I suggest you use the technique they reference: two controllers, one for each battery, but fed by a single PV panel: http://www.morningstarcorp.com/en/su...ries.01.EN.pdf It's the technique I use in my trailer to charge the glider battery and auxiliary battery in the front of the trailer. Seems to work well. The advantage is the batteries will charge more quickly, and to the proper voltage. Even so, it might not make much difference in the amount of charge each one gets. Alternatively, you could get a dual output controller, one output for each battery. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Eric,
What diode would you use for the 2 contollers/1 pV option you use ? My Solar panel is rated at 20W od 1.3A max. Dan G On Monday, December 31, 2012 9:49:58 PM UTC-5, Dan G wrote: I would like to connect my 2 8AH batteries to one Solar panel for charging while the glider is in its trailer. I will use a controller and I have 2 separate sockets in the glider-one per battery. I thought to simply split the wires coming out of the controller to the two batteries/sockets but I came across this: http://www.morningstarcorp.com/en/su...ller.01.EN.pdf, Any suggestions? Dan G |
On 12/31/2012 7:31 PM, Dan G wrote:
Eric, What diode would you use for the 2 contollers/1 pV option you use ? My Solar panel is rated at 20W od 1.3A max. Dan G I'd just go to Radio Shack and get ones rated at 2 amps or more forward current. They will all have enough voltage rating. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Monday, December 31, 2012 8:18:40 PM UTC-8, Eric Greenwell wrote:
On 12/31/2012 7:31 PM, Dan G wrote: Eric, What diode would you use for the 2 contollers/1 pV option you use ? My Solar panel is rated at 20W od 1.3A max. Dan G I'd just go to Radio Shack and get ones rated at 2 amps or more forward current. They will all have enough voltage rating. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) There is a slight benefit in using a Schottky diode in this application for their lower forward voltage drop. For the one controller sceanario this is more important as it affects the charge set point of the controller. But it also helps the other scenario as well. e.g. http://www.amazon.com/30pcs-1N5822-S.../dp/B007AU0GJI. I would not go to too lower diode forward current rating due to current derating (maybe 50%?) at temperatures they might happen in a charger environment/hot trailer. I hope there is not a too high expectation about how fast a "20W" panel will charge these two batteries. Solar insolation on a flat non-tracking panel gets pretty low. Darryl |
I took the easy way out and ordered one of these:
http://www.amazon.com/gp/product/B00...ls_o05_s00_i00 40 bucks. It has worked great with my 10 watt panel, is programmable and tells me the charge status of each battery. ZAP |
On 1/1/2013 6:26 PM, RAS56 wrote:
I took the easy way out and ordered one of these: http://www.amazon.com/gp/product/B00...ls_o05_s00_i00 40 bucks. It has worked great with my 10 watt panel, is programmable and tells me the charge status of each battery. This kind of controller would be a good choice for the OP, where both batteries are in the glider. I used separate controllers for my application, one in the glider for the glider battery, and the other at the front of the trailer, where my auxiliary battery is kept. That keeps the controllers in the temperature zone as the battery, and keeps the wires to battery much shorter. The auxiliary battery used with a DC/DC charger to charge the glider battery when the glider is tied down away from the trailer. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Thanks for the advice.
Now-if I connect these two batteries in oarallel- do I still need the two separate systems or I can charge them as one 8 x 2=16 AH battery ? Dan G On Monday, December 31, 2012 9:49:58 PM UTC-5, Dan G wrote: I would like to connect my 2 8AH batteries to one Solar panel for charging while the glider is in its trailer. I will use a controller and I have 2 separate sockets in the glider-one per battery. I thought to simply split the wires coming out of the controller to the two batteries/sockets but I came across this: http://www.morningstarcorp.com/en/su...ller.01.EN.pdf, Any suggestions? Dan G |
On Wednesday, January 2, 2013 7:28:54 AM UTC-8, Dan G wrote:
Thanks for the advice. Now-if I connect these two batteries in oarallel- do I still need the two separate systems or I can charge them as one 8 x 2=16 AH battery ? Dan G On Monday, December 31, 2012 9:49:58 PM UTC-5, Dan G wrote: I would like to connect my 2 8AH batteries to one Solar panel for charging while the glider is in its trailer. I will use a controller and I have 2 separate sockets in the glider-one per battery. I thought to simply split the wires coming out of the controller to the two batteries/sockets but I came across this: http://www.morningstarcorp.com/en/su...ller.01.EN.pdf, Any suggestions? Dan G Dan, The circuit you presented already is a parallel circuit in regards the batteries. Looking at it, I'm assuming the diodes are there to prevent damage to the batteries & the controller if one of them is hooked up reverse. In that case, I'd use two diodes. Regards, Chris C. |
On Wednesday, January 2, 2013 10:42:22 AM UTC-5, wrote:
On Wednesday, January 2, 2013 7:28:54 AM UTC-8, Dan G wrote: Thanks for the advice. Now-if I connect these two batteries in oarallel- do I still need the two separate systems or I can charge them as one 8 x 2=16 AH battery ? OOPS I neant using one controller for 2 batteries connected in parellel. Dan Dan G On Monday, December 31, 2012 9:49:58 PM UTC-5, Dan G wrote: I would like to connect my 2 8AH batteries to one Solar panel for charging while the glider is in its trailer. I will use a controller and I have 2 separate sockets in the glider-one per battery. I thought to simply split the wires coming out of the controller to the two batteries/sockets but I came across this: http://www.morningstarcorp.com/en/su...ller.01.EN.pdf, Any suggestions? Dan G Dan, The circuit you presented already is a parallel circuit in regards the batteries. Looking at it, I'm assuming the diodes are there to prevent damage to the batteries & the controller if one of them is hooked up reverse. In that case, I'd use two diodes. Regards, Chris C. |
Similar Threads | ||||
Connecting lap top to CAI 302 | apsoars | Soaring | 10 | June 8th 11 03:24 PM |
Batteries, Solar Panels, Transponders, etc. | JS | Soaring | 7 | August 31st 06 09:12 PM |
sizing solar panel | Udo Rumpf | Soaring | 18 | February 17th 06 01:36 AM |
Connecting a GNS 430/530 to a PC | PA34 F-GFTF | General Aviation | 4 | September 26th 04 07:09 PM |
Connecting a GNS 430/530 to a PC | PA34 F-GFTF | Aviation Marketplace | 7 | September 25th 04 04:38 AM |
