Narco MK12d to king KN-73
Old February 20th 07, 02:17 AM posted to rec.aviation.owning,rec.aviation.ifr
Default Narco MK12d to king KN-73
need a little help with the wiring of a Narco MK12d Nav/Com to a king
kn-73 glideslope rcvr.
the king lists it's channeling as
pin N =0.1mhz
pin L= 0.3 mhz
pin y= 0.5 mhz
pin S= 0.7
pin P= 0.9
pin V=108mhz
pin K= 109
pin H=110
pin j= 111
pin n= 50Khz control
pin D= G.S Switching Voltage
pin Z= ILS Common
The Narco has
pin 11 = A Khz
pin 10 = B Khz
pin 09 = C Khz
pin 08 = D Khz
pin 07 = E Khz
pin M = A Mhz
pin L = B Mhz
pin K = C Mhz
pin J = D Mhz
pin H = E Mhz
pin 2 = X-Y Channel
pin 4= GS/Loc Activate
pin N= "to DME common ground"
To me it looks like it's straight down the list one for one..... But
I've been known to let the smoke out of things...
Any input would be appreciated..
Narco MK12d to king KN-73 [email protected] Owning 0 February 20th 07 02:17 AM
FA: NARCO MK12D Navcom and Indicator 14volt Ken Martin Aviation Marketplace 0 October 31st 05 12:50 AM
Narco Com 120 FS Mike Spera Owning 0 October 12th 05 02:13 AM
Narco MK12D MHZ Knob Set Screw Needed NW_PILOT Owning 0 May 21st 04 06:25 AM
Used avionics MK12D w/GS,KX170B etc. Rob Wren Aviation Marketplace 0 August 25th 03 07:46 PM
