#31
OSKI 3 wrote: Here is my 2 cents worth. Why not get a 150 or 152 with a 150/160 HP engine. Throw in a taildragger mod. and you are somewhere near $35K. Now you have the most bullet proof cessna made, parts are still around, will outrun a 172, take off in a litle over 400 ft, land in the same distance, all metal, and burn about 7 plus GPH. And be totally useless because before you put any gas in the useful load is less than 250 pounds. There was a magazine article on this 150/150 in the last couple of years. Nice idea but without a gross weight increase it's useless. |
#32
Newps wrote in message ...
OSKI 3 wrote: Here is my 2 cents worth. Why not get a 150 or 152 with a 150/160 HP engine. Throw in a taildragger mod. and you are somewhere near $35K. Now you have the most bullet proof cessna made, parts are still around, will outrun a 172, take off in a litle over 400 ft, land in the same distance, all metal, and burn about 7 plus GPH. And be totally useless because before you put any gas in the useful load is less than 250 pounds. There was a magazine article on this 150/150 in the last couple of years. Nice idea but without a gross weight increase it's useless. I've flown one of these and the main drawback I saw was range. The bigger engine burns 1/3 more fuel than the original, but the tanks are the same size. John Galban=====N4BQ (PA28-180) |
#33
John Galban wrote: I've flown one of these and the main drawback I saw was range. The bigger engine burns 1/3 more fuel than the original, but the tanks are the same size. I would still agree with newps. The bigger engine weighs more and subtracts from the useful load, which isn't very much to start with. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
#34
John Galban wrote:
: I've flown one of these and the main drawback I saw was range. The : bigger engine burns 1/3 more fuel than the original, but the tanks are : the same size. I never have bought that argument. Just because a plane has a bigger engine doesn't mean you need to *use* it. Aside from additional weight or ridiculous extremes (e.g. running a huge engine at 20% power or the like), bolting a larger engine onto the same airframe doesn't have to cost you range. In fact, I'd argue in some situations it'll gain you range. Consider that a 150 with an O-235 lycoming would have more range than one with an O-200 continental... Run it at 65% rather than 75% and the higher compression will get you farther on the same amount of fuel. You'll also spend less time in extra-bad fuel economy regions like climbout if you climb faster. I've got more range on my 180 HP O-360 than on a 150 HP O-320... provided I don't run it at the same *percent* power... rather the same *absolute* power. Now, with a 150/150, it might be bordering on wretched excess, so the weight increase may skew the results a little bit. Still... it's not going to have inherently less range except for the added 25-50 lbs the engine weighs. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
#35
Should that not be 2¢ worth. |
#36
I have always wonderd. What has happened to the "¢" sign? Nobody uses it any more and my computer doesn't even have one on its keyboard. Lets start a move ment to bring back the ¢ sign. ¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢ ¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢ ¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢¢ |
#37
I'm not sure that makes ¢. |
#38
We are going two make a go around, you had to much power in. We are number too two land after a Cessna. Two, too. to and ¢ are never used Wright. |
#39
"WARREN1157" wrote in message ... I'm not sure that makes ¢. We are going two make a go around, you had to much power in. We are number too two land after a Cessna. Two, too. to and ¢ are never used Wright. It's enough to make you loose your mind! |
Similar Threads | ||||
Dream Airplane poll | Bob Babcock | Home Built | 39 | December 24th 04 02:20 AM |
T Bird - | ZackGSD | Home Built | 1 | December 15th 03 01:47 PM |
Tying down the bird | david whitley | Owning | 17 | September 23rd 03 03:57 AM |
Bird control | David Naugler | Aviation Marketplace | 7 | September 22nd 03 03:40 PM |
