1-35 or 201B
So you have a choice for a first glider. You're flying in northeastern US,
i.e. generally light conditions (when it's not snowing). These 2 planes have roughly similar performance on paper and prices, although they probably handle quite differently and I would guess the 1-35 penetrates better. Maybe the Libelle climbs better. Both are in excellent condition. The Standard Libelle is the version (B) with larger air brakes and foam core, not balsa. Which would you pick and why? Thanks. Wad. |
1-35 or 201B
I would buy the one with the better trailer and the
better equipped instrument panel. One 'plus' the Libelle has over the 1-35: a canopy you can partially open for a blast of fresh air. The canopy lock allows the front of the canopy to rise up about an inch or so to let in the air. One 'plus' SOME 1-35's have over the Libelle: Hinged canopy. Ray Lovinggood Carrboro, North Carolina, USA At 00:48 31 March 2006, Waduino wrote: So you have a choice for a first glider. You're flying in northeastern US, i.e. generally light conditions (when it's not snowing). These 2 planes have roughly similar performance on paper and prices, although they probably handle quite differently and I would guess the 1-35 penetrates better. Maybe the Libelle climbs better. Both are in excellent condition. The Standard Libelle is the version (B) with larger air brakes and foam core, not balsa. Which would you pick and why? Thanks. Wad. |
1-35 or 201B
I have not flown a 1-35, but I have flown the 1-34 and other Schweizers, I
have flown the Libelle Understanding Ray's comments on trailers and instruments Both are Classics Libelle's go together easier 1-35s are metal and can stay out in the weather easier, any one can do sheet metal work Libelle's are fiberglass and gel coat and need more attention Personally, if I fit in both, I'd pick the Libelle BT "Waduino" wrote in message .. . So you have a choice for a first glider. You're flying in northeastern US, i.e. generally light conditions (when it's not snowing). These 2 planes have roughly similar performance on paper and prices, although they probably handle quite differently and I would guess the 1-35 penetrates better. Maybe the Libelle climbs better. Both are in excellent condition. The Standard Libelle is the version (B) with larger air brakes and foam core, not balsa. Which would you pick and why? Thanks. Wad. |
1-35 or 201B
Waduino wrote: So you have a choice for a first glider. Which would you pick and why? Thanks. Wad. I'd echo BT and say I'd pick the Libelle if I could fit in it anymore. They are a little tight around the shoulders these days. 1-35 has a bit larger cockpit. Think about how you'll feel after 3 hours in a cramped cockpit. Willie G. |
1-35 or 201B
Waduino wrote:
So you have a choice for a first glider. You're flying in northeastern US, i.e. generally light conditions (when it's not snowing). These 2 planes have roughly similar performance on paper and prices, although they probably handle quite differently and I would guess the 1-35 penetrates better. Maybe the Libelle climbs better. Both are in excellent condition. The Standard Libelle is the version (B) with larger air brakes and foam core, not balsa. Which would you pick and why? Thanks. Wad. Libelle. Choice strictly based on looks. :-) Shawn |
1-35 or 201B
Check if the 1-35 you are considering has the flap aileron
interconnect. Early model without it had a low cruise flap limit speed. I've flown both and I prefered the Libelle. Delightful handling and outclimbs almost anything. Andy |
1-35 or 201B
Andy wrote: Check if the 1-35 you are considering has the flap aileron interconnect. Early model without it had a low cruise flap limit speed. I've flown both and I prefered the Libelle. Delightful handling and outclimbs almost anything. Andy |
1-35 or 201B
Waduino wrote:
So you have a choice for a first glider. You're flying in northeastern US, i.e. generally light conditions (when it's not snowing). These 2 planes have roughly similar performance on paper and prices, although they probably handle quite differently and I would guess the 1-35 penetrates better. Maybe the Libelle climbs better. Both are in excellent condition. The Standard Libelle is the version (B) with larger air brakes and foam core, not balsa. It also has a larger horizontal stabalizer (I think) and the gear is more reasonable than on the 301. Which would you pick and why? I'll add that the Libelle assembles and disassembles *WAY* easier/faster than a 1-35 (in the 301 all you have to do is push the wings in place, insert a single wing pin, insert two readily accessible airleron pins, and then push the horizontal stabalizer into place and tighten a bolt -- it also has all automatic hookups except airlerons which is nice, I assume the 201 is similar) . The 1-35 however is hands down *WAY* better at off-field landings. It's hard to imagine a ship I'd prefer to take down into a tight field. The combo of the skid, strong brakes, a sheet metal skin, and the vertical flaps make it capable of coming down at a very steep angle, and coming to a stop exceptionally quickly and still retain some ability to steer on the ground. Although the 1-35 is great at off field landings it probably isn't what you are used to because of the lack of air brakes so you'll have to practice. The 301, while having a more conventional landing posture, is not an easy aircraft to land well for a variety of reasons. I suspect the 201B is considerably easier than the 301 though. My guess is the Libelle handles better (I've never flown a 201, but I own a 301B -- the 301 is rather twitchy at low speed, but I suspect the 201B is much less so), is more comfortable (A couple 1-35 drivers I've talked to have complained the lack of compliance in the metal makes for a very harsh ride in turbulent air) and has higher performance (although this is probably marginally so). I suspect the 1-35 penetrates better, but only marginally if at all. In the looks department, I guess its technically subjective, but not to me. The Libelle is... a Libelle, perhaps the most gorgeous glider ever made, whereas the 1-35 is a Schweitzer, a nice looking Schweitzer, but still... a Schweitzer. The Libelle canopy is a blessing and a curse. In flight its wonderful. You can open it in the air (although only a good idea at low speed), which gives much better ventilation than any vent system. My guess is it could be jetisoned very easily if you need to egress (although I've never tried). On the ground its a pain in the butt because it doesn't open up, you have to remove it and install it (or rather get someone else to install it) and although its not difficult, the person doing it needs to have practiced a few times. Visibility in the 301 is marginal, maybe a little better than a 2-33, but not much. Visibility on the ground is bad. I suspect the 201 is noticably better however. I have no idea what the 1-35 is like in terms of visibility, Also pay attention to which 1-35 you are looking at, a few of them have interconnected flaps and retractable gear, but I think most don't. Without interconnected flaps it really hurts your high speed performance. I'll reiterate what others have said... Trailer condition counts, between a 1-35 and a 201, if the price is similar, a good versus bad trailer may be a reasonable deciding factor. dan |
1-35 or 201B
Libelle! hands down!!
The 135 looks wizzy for a Schweizer but is only a marginal performance glider.it also is an easy glider to fly, but isn't a "groovy" glider to fly...the 1-35 takes a lot of attaention to really thermal well.it likes some flaps for thermalling and is light enough that the added flaps are draggy enough that they just don't allow any pushing or pulling to take advantage of the strong bumps in the thermal without slowing the glider so you end up flying in more or less octagons rather than circles...it's just not as fun as it should be.... The Libelle also needs attention since it doesn't groove like some later and heavier gliders but it's still delightful...it just leaves you feeling "good" The Libelle is of course much prettier ) but assembles quick and easy, just a well designed glider for the time... Support for the Libelle remains very good with Hansjorg Streifeneder in Germany keeping almost all parts readily available and since Sikorsky took over Schweizer support for all Schweizer gliders today is nil.though this might change as someone takes over at least some of the Schweizer parts... But of the 2...no question.....Libelle! ) tim Please visit the Wings & Wheels website at: www.wingsandwheels.com "Waduino" wrote in message .. . So you have a choice for a first glider. You're flying in northeastern US, i.e. generally light conditions (when it's not snowing). These 2 planes have roughly similar performance on paper and prices, although they probably handle quite differently and I would guess the 1-35 penetrates better. Maybe the Libelle climbs better. Both are in excellent condition. The Standard Libelle is the version (B) with larger air brakes and foam core, not balsa. Which would you pick and why? Thanks. Wad. |
1-35 or 201B
If you're looking at a 1-35 and a Libelle, I'd include a PIK-20B. It
has the best attributes of both in my opinion. Same 90-degree flaps for short-field landings. Has -8 degree flaps interconnected with ailerons for running. More importantly, has a 130 kt. rough-air redline, and no gel-coat issues. They are built very robustly. I have 128 hours in a 1-35 and about 20 in my PIK. The PIK will run and hide from most 1-35's. At higher speeds will go away from a Standard Libelle. There's a reason it has won a world championship... I was up to 9000 MSL today in West Texas, and went about 70 miles... come on summer! In my opinion, a PIK's the best value out there, and there are several for sale... Jack Womack PIK-20B N77MA (TE) |
Similar Threads | ||||
Libelle 201B in SoCal... | Pat Russette | Soaring | 0 | April 9th 05 05:42 AM |
Dual Tires on Libelle 201b | Ray Lovinggood | Soaring | 11 | September 9th 04 04:34 PM |
