Altimeter 3066
Old December 2nd 06, 05:42 AM posted to rec.aviation.piloting,rec.aviation.student
M[_1_]
Default Altimeter 3066
A very high pressure settled in Pacific NW:
KPSC 020453Z 31006KT 6SM BR BKN007 BKN075 M07/M08 A3066 RMK AO2
SLP389 T10671078
That's the highest that I've ever remember seeing.
I always thought that the NW seems to have larger pressure swings
(probably more so in Alaska). We can go from 2960 to 3060 in about two
days.
Old December 2nd 06, 06:03 AM posted to rec.aviation.piloting,rec.aviation.student
M[_1_]
BTW, FAR 91.144 restricts flight operations when barometric pressure
exceeds 31 inch mercury. Any idea why? (note this restriction applies
to VFR traffic a well).
SLP389 T10671078
days.
Old December 2nd 06, 06:27 AM posted to rec.aviation.piloting,rec.aviation.student
J. Severyn
"M" wrote in message
ps.com...
The Kollsman Window is only required to have a range of 28.00 to 31.00
inches Hg. So if barometric pressure is outside that range, you cannot
accurately set most altimeters.
John Severyn
@KLVK
Old December 2nd 06, 06:48 AM posted to rec.aviation.piloting,rec.aviation.student
M[_1_]
I don't believe VFR flight requires accurate altimeter adjustable for
barometric pressure. 91.205 only requires such altimeter for IFR
operations.
ps.com...
John Severyn
@KLVK
Old December 2nd 06, 06:52 AM posted to rec.aviation.piloting,rec.aviation.student
M[_1_]
operations.
ps.com...
John Severyn
@KLVK
Old December 2nd 06, 07:24 AM posted to rec.aviation.piloting,rec.aviation.student
J. Severyn
Correct. But you still are required to follow the NOTAM in extremely high
or low barometric pressure conditions. If you read FAR91.144 quoted he
"Sec. 91.144
Temporary restriction on flight operations during abnormally high barometric
(a) Special flight restrictions. When any information indicates that
barometric pressure on the route of flight currently exceeds or will exceed
31 inches of mercury, no person may operate an aircraft or initiate a flight
contrary to the requirements established by the Administrator and published
in a Notice to Airmen issued under this section.
(b) Waivers. The Administrator is authorized to waive any restriction issued
under paragraph (a) of this section to permit emergency supply, transport,
or medical services to be delivered to isolated communities, where the
operation can be conducted with an acceptable level of safety."
In other words, it says "Read the NOTAM" or "Get a Waiver". Normally the
NOTAM will restrict operation at certain altitudes so that safe altitude
separation can be maintained in spite of the inability to correctly enter
the barometric pressure.
John Severyn
@KLVK
operations.
ps.com...
John Severyn
@KLVK
Old December 2nd 06, 07:31 AM posted to rec.aviation.piloting,rec.aviation.student
J. Severyn
operations.
AIM 7-2-2 might answer your question about high and low barometric
pressures.
John Severyn
@KLVK
Old December 2nd 06, 08:16 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
That is the highest pressure you can set on the Kollsman
window.
ps.com...
barometric pressure
restriction applies
RMK AO2
| SLP389 T10671078
pressure swings
3060 in about two
| days.
Old December 2nd 06, 02:16 PM posted to rec.aviation.piloting,rec.aviation.student
Heck,,, get out and go flying. The wings love the thick air and the
motor really LOVES it too.
SLP389 T10671078
days.
Old December 2nd 06, 04:03 PM posted to rec.aviation.piloting,rec.aviation.student
Fred G. Black
The "why" is that the altimeter setting range on most altimeters doesn't
go past 31.00". Does anyone have an example of a NOTAM under 91.144?
(how restrictive is it).
The rules that apply in Canada are a bit more explicit:
http://www.tc.gc.ca/CivilAviation/pu...12-1.htm#12-12
Basically it says
- for enroute, set the altimeter to 31"
- for IFR approaches, set the altimeter to the actual altimeter setting
if able, otherwise set it to 31" and adjust the altitude minima (add
100' and 1/4 SM per 0.1" above 31.00")
- aerodromes which cannot report the actual altimeter setting are
restricted to VFR.
-"For aircraft operating VFR, no additional restrictions apply; however,
extra diligence in flight planning and in operating in these conditions
is essential. "
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
