#11
The shop that does my annual repaints the battery box every annual.
??? I can think of no valid reason for this. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
How often do you check the battery in your PA28?
At annual. (Or if the plane doesn't start -- which has never happened with either of the Cherokees I've owned...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote: The shop that does my annual repaints the battery box every annual. ??? I can think of no valid reason for this. My shop usually does (maybe they occasionally skip a year). The reason is that the non-sealed battery usually has seeped some acidic residue somewhere in the box. That stuff needs to be brushed off properly, which usually scratches the paint, which requires that the box be painted afterwards, to protect it from any new seepage. John Galban=====N4BQ (PA28-180) |
Guess I'll add "Check battery condition" to the monthly checklist and
replace the battery box in August at annual. Thanks for the comments everyone. Eddie N40008 |
Robert M. Gary wrote:
The shop that does my annual repaints the battery box every annual. I'm not sure why, my battery has never leaks. Its either preventative or just an extra annual tax. The paint they use on battery boxes is "acid resistant". It helps prevent battery acid from eating a hole in the bottom of your plane. I have a can of that paint that I use each year. I wash the battery box with a mixture of baking soda and water, dry it, and re-coat it with a thin coat of the acid resistant paint. In addition, I use compressed air to blow out the vents. Incidentally, your battery DOES leak, you just don't know it (unless you have one of the newer design "sealed" batteries). The act of charging causes it to off-gas a vapor of battery acid. That's why battery boxes have vents. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Obviously, it's checked at annual time, but I'll often try and check it
at the mid-year point, too. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Similar Threads | ||||
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 09:12 PM |
