A beginner's doubt on jet engines
Old December 23rd 04, 06:26 AM
Ramapriya
Default A beginner's doubt on jet engines
I know that a car's engine needs to be mated to the transmission for
propulsion. This I know isn't the case with an aircraft with a jet
engine; if the engine is turned on without the brakes applied, the jet
of air leaving the engine will hurl the craft forward.
My doubt is, why does this forward motion effect not occur during
push-back, when the engines are normally turned on? Is it because at
low revs the engine would lack the punch to initiate the forward motion
of a heavy aircraft? If not, I'd imagine the push-back becomes a bit of
a tiresome affair by the time it's over...
Sorry if this is infuriatingly elementary, but I need to ask somewhere
Ramapriya
Old December 23rd 04, 06:38 AM
Mike Rapoport
There is not enough thrust at idle to be a problem.
MU-2
"Ramapriya" wrote in message
Ramapriya
Old December 23rd 04, 06:46 AM
Morgans
Ramapriya
At idle, turbo fan engines, or turbo jet engines do not make a tremendous
amount of thrust. The push-back tugs are very powerful, with very low
gearing. They simply push harder than the engines are pushing.
Sometimes, the engines are not started until after push-back, or while the
push-back is taking place.
Some of the heavy metal pilots can tell you better than me, but it is my
understanding that it takes well over 50% RPM to get 50% thrust, so it
goes to follow that 10% RPM is way less than 10% thrust.
Where have you been? Kinda' lonely around here, without your constant
questions! g
Old December 23rd 04, 07:09 AM
Jay Beckman
Ramapriya
Sometimes they don't even need a tug to get away from the gate...
I've been on American Airlines MD80s that have pushed back under their own
power via their reversers.
Jay Beckman
PP-ASEL
Chandler, AZ
Old December 23rd 04, 02:48 PM
Ron Parsons
In article . net,
MU-2
roups.com...
Ramapriya
I've seen numerous times on an icy ramp when it was.
Ron Parsons
Old December 23rd 04, 02:51 PM
Ron Parsons
roups.com...
Ramapriya
questions! g
Thrust and RPM do not have a linear relationship. Idle can be as high as
60%.
Ron Parsons
Old December 23rd 04, 02:53 PM
Corky Scott
As others have mentioned, there is not so much thrust generated by the
jet engines at idle that the tugs cannot overcome it to push it back.
Take a look at the tugs sometime, they are massively constructed with
extra weight added on so that they have sufficient mass to push and
pull the big jets.
In addition, next time you are take a flight in a jet airliner, notice
how much power the pilot has to make the engines produce in order to
get the airliner rolling.
Corky Scott
Old December 23rd 04, 03:04 PM
Ramapriya
their own
Oops! Do they have rear-view mirrors? Prima facie, reversing blind
doesn't seem overly safe...
Ramapriya
Old December 23rd 04, 03:15 PM
Ramapriya
Hi there Jim, been in the wilderness of northeastern Sudan, laying a
gas pipeline, hence the bit of silence
Returned a couple of hours ago (sneaked a visit to the A320 cockpit
until TOD), and will be returning back there in about 3 days for
another month or so, but my laptop works in the deserts too, so the Qs
might just keep comin
Cheers,
Ramapriya
PS: Don't know if they trolled me, but both the pilots today didn't
seem to know much of the CFM56's internals. Possibly they didn't want
to bother answering, but I'll have to look elsewhere to figure the
compressor's and ignition chamber's construction...
Old December 23rd 04, 03:44 PM
Garner Miller
In article .com,
Ramapriya wrote:
their own power via their reversers.
They have wing-walkers to direct the reversing, just as they direct
them into the gate. They aren't doing it blind at all. I've done it
in a turboprop; it's a very strange sensation. AA seems to do it more
than any other airline; not sure why.
Garner R. Miller
ATP/CFII/MEI
Clifton Park, NY =USA=
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
