#11
I'm using either Downloader via an IPAQ or LXE with a laptop to move
information so I don't know much about the Winpilot interface. However, the Winpilot uses the same NMEA data stream As Fly With CE. The settings can be found under the setup menu. That is accessible through the menus behind Password. The NMEA stream goes through the 232. The LX7K had a cable set labeled Winpilot which hooked into the dangling 232 cable. I think the only purpose it served was a wiring reconfiguration to support IPAQ communication. The round shaped 5 pin I connect to a female terminated cable to a 232 serial to the laptop. I've never checked to see if the NMEA data goes to this port. "Ludovic Launer" wrote in message ... Thanks a lot. Where are NMEA sentences coming out from ? From the RS232C ? or from the PC-RS232C ? Or both maybe ? Is the BINDER 5pin male the round shape connector ? Regards, Ludovic I would have expected it to come with the unit, but I have a wiring diagram (includes other LX recorders as well) which I will post at: http://www.spsys.demon.co.uk/temp/LX-wiring.pdf |
Clint wrote:
not have a colour (not a spelling mistake - it is how we spell color in Africa) PDA as the Palm colour units are poor in direct sunlight (plenty of that in Africa as well) and do not have the money for an IPAQ and Winpilot. I use a Tungsten T and previously an M515. Both has color display and has no problem under sunlight. Avoid T2, T3 and zire types, that units has the problem what you described. Regards, /Janos |
Similar Threads | ||||
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
LX5000 help | Ted Wagner | Soaring | 1 | April 29th 04 03:27 AM |
iPaq and LX5000 connectivity question (hardware?) | Ted Wagner | Soaring | 1 | April 22nd 04 09:29 PM |
Any LX5000, SeeYou Mobile & Downloader users ... | Ted Wagner | Soaring | 2 | April 4th 04 05:48 PM |
