The rudder waggle signal does not work
On Friday, July 22, 2011 8:14:22 PM UTC-7, Steve Koerner wrote:
The most fundamental problem is that we invented too many towplane signals. Consider if there were only one signal, then there could never be this fatal problem of misinterpretation. The signal should simply be "tow problem". If I get a "tow problem" signal from the tug, I look to see if the tow problem is coming from my end of the rope (check dive brakes). If it is, I immediately correct the problem. If the tow problem is not at my end of the rope, it must be at the tugs end. In which case, I wait until I am certain that I can make a safe return to the field and then I release. What need have we for more than one signal? Good point! Tow pilot signals me to "wake up, something's wrong". I then do a self assessment and if I'm happy, then the there must be something wrong with the tug. So I'll release and get out of the way. -Tom |
Similar Threads | ||||
The rudder waggle signal does not work | Pat Russell[_2_] | Soaring | 99 | August 2nd 11 02:16 PM |
Rudder waggle | toad | Soaring | 33 | November 21st 07 05:44 AM |
DG Rudder AD - DONE! - Notes from my work | ContestID67 | Soaring | 0 | March 30th 06 07:36 PM |
CH Rudder pedals, why don't they work | wan2fly99 | Simulators | 2 | January 12th 06 12:30 PM |
