Calibrating temperature probes
Background first: Two significant points exist for calibrating a
temperature probe or thermometer without comparing it to a known probe or thermometer -- freezing and boiling points of water. For the freezing point, one mixes up a slush of ice and water, the probe should read zero degrees centigrade when immersed in the liquid. For the boiling point, stick the probe in a pot of boiling water and it should read 100 degrees. Except, of course, for the barometric pressure. We all know water boils at lower and lower temperatures (?? 3 degrees per 1,000 feet??) as altitude is increased. Question: Why doesn't the same pressure effect occur for the freezing point? Oh yeah, to make this an aviation related topic consider calibrating a temperature probe or thermometer to use as a reference to check the OAT gauge in your plane once in a while. You all do that now and then, don't you? |
"Casey Wilson" wrote in message
... Question: Why doesn't the same pressure effect occur for the freezing point? I believe it does. If I recall correctly, the pressure from the blade of an ice skate is what melts the ice and allows the skate to glide easily across the ice. However, it requires a much greater change in pressure to make the same change in freezing point, so it's not relevant for your purpose. All off the top of my head...look it up if you really want to know. Pete |
... Background first: Two significant points exist for calibrating a temperature probe or thermometer without comparing it to a known probe or thermometer -- freezing and boiling points of water. For the freezing point, one mixes up a slush of ice and water, the probe should read zero degrees centigrade when immersed in the liquid. For the boiling point, stick the probe in a pot of boiling water and it should read 100 degrees. Except, of course, for the barometric pressure. We all know water boils at lower and lower temperatures (?? 3 degrees per 1,000 feet??) as altitude is increased. Question: Why doesn't the same pressure effect occur for the freezing point? It does. For a phase change, there's an equation called the Clapeyron equation that shows how the temperature varies with pressure. dT/dP = T deltaV / deltaH where deltaV is the volume change and deltaH is the enthalpy change (think of it as energy and you're not too far off) of the phase change. (It sort of makes sense that the pressure variation of the phase change depends on what the volume change is. If there's no volume change it doesn't really matter what the pressure is, as everything happens in the same space.) For water - steam, deltaV is very large, so the variation of T with P is significant. For ice-water, deltaV is tiny, so the variation of T with P is miniscule. At about 130 atmospheres, the melting temperature of water drops by 1 degC. Julian Scarfe |
"Peter Duniho" wrote in message
... I believe it does. If I recall correctly, the pressure from the blade of an ice skate is what melts the ice and allows the skate to glide easily across the ice. I don't doubt your recall, Peter, as I'm sure I was taught the same. However, check out: http://www.physlink.com/Education/AskExperts/ae357.cfm Julian Scarfe |
"Julian Scarfe" wrote in message
... I don't doubt your recall, Peter, as I'm sure I was taught the same. However, check out: http://www.physlink.com/Education/AskExperts/ae357.cfm Interesting. Oh well... I'm at least relieved to find that it is indeed the case that the melting point changes with pressure, and that it changes very little. It just changes a lot less than I even suspected. The explanation on that page *is* a little confusing though. I think they got their math right, but the wording is odd. They start out talking about the reduction of freezing point, but then later talk about an increase in the temperature of the ice. The two are not really the same, even if they result in the same effect. Pete |
Casey Wilson wrote:
For the boiling point, stick the probe in a pot of boiling water and it should read 100 degrees. Except, of course, for the barometric pressure. We all know water boils at lower and lower temperatures (?? 3 degrees per 1,000 feet??) as altitude is increased. Question: Why doesn't the same pressure effect occur for the freezing point? It does. It's just that the melting point curve is a lot steeper than the boiling point curve, so it takes a lot more pressure for the same effect. An interesting experiment can demonstrate the effect. Suspend an ice cub between two supports. Loop a fine wire over the ice cube, and use it to suspend some significant weight (say 0.5-1 pounds). After some time the wire will be in the middle of the ice cube, with ice above and below it. After even more time, the wire will "cut" through the cube and fall out the bottem, leaving behind a solid block of ice. (The pressure of the wire on the ice raises the melting point, so that the ice in immediate contact with the wire becomes liquid. After the wire passes that spot, the melting point returns to normal and the water re-freezes. Rich Lemert |
Nomen Nescio wrote:
Question: Why doesn't the same pressure effect occur for the freezing point? The vapor pressure of ice (and ice -water mix) is effectively 0. Irrelevent! The melting point involves an equilibrium between the solid ice and the liquid water. The vapor is totally irrelevent (except at the triple point, where all three phases are in equilibrium). Rich Lemert |
Julian, that's the complex answer. Remember PV=nRT?
This is what I use... Change it to PV/T=nR From this you can write: (P1V1)/T1=(P2V2)/T2 Julian Scarfe wrote: It does. For a phase change, there's an equation called the Clapeyron equation that shows how the temperature varies with pressure. dT/dP = T deltaV / deltaH where deltaV is the volume change and deltaH is the enthalpy change (think of it as energy and you're not too far off) of the phase change. (It sort of makes sense that the pressure variation of the phase change depends on what the volume change is. If there's no volume change it doesn't really matter what the pressure is, as everything happens in the same space.) For water - steam, deltaV is very large, so the variation of T with P is significant. For ice-water, deltaV is tiny, so the variation of T with P is miniscule. At about 130 atmospheres, the melting temperature of water drops by 1 degC. Julian Scarfe |
"Julian Scarfe" wrote in message ... "Peter Duniho" wrote in message ... I believe it does. If I recall correctly, the pressure from the blade of an ice skate is what melts the ice and allows the skate to glide easily across the ice. I don't doubt your recall, Peter, as I'm sure I was taught the same. However, check out: http://www.physlink.com/Education/AskExperts/ae357.cfm Julian Scarfe I don't buy the physicist's argument. Blades are curved, so there is likely ten times less surface area on the ice. -- Jim in NC |
"john smith" wrote in message
... Julian, that's the complex answer. Remember PV=nRT? PV=nRT does not apply to solids or liquids. Hell, it barely applies to gasses, since they rarely are "ideal". Pete |
Similar Threads | ||||
Total Air Temperature question | Mike Rapoport | Instrument Flight Rules | 12 | December 14th 04 06:20 PM |
Total Air Temperature question | Julian Scarfe | General Aviation | 6 | December 14th 04 06:20 PM |
Total Air Temperature question | Mike Rapoport | General Aviation | 5 | December 11th 04 09:30 PM |
'Room Temperature' | Anthony | Home Built | 11 | August 23rd 04 07:36 PM |
Wanted to Buy/Trade: CTH Bayonet Type Probes | aRKay | Aviation Marketplace | 0 | August 14th 04 03:40 PM |
