USAF = US Amphetamine Fools
Old August 15th 03, 07:31 PM
Paul J. Adam
In message , BUFDRVR
writes
Second, I've never taken, nor been told to, "anti-nerve"
agents. The only time you take these is when you've been exposed to a nerve
agent.
There are also Nerve Agent Pre-treatment System (NAPS) tablets which are
taken in anticipation of exposure to cholinesterase inhibitors (nerve
gases, organophosphorous insecticides and so on) - these increase your
resistance to the compounds and buy you more time to mask up, seal up
and grab a Combopen.
I don't believe they're issued to aircrew, though, which would be why
you haven't come across them.
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old August 15th 03, 07:32 PM
Tarver Engineering
"John R Weiss" wrote in message
news:Ji9%a.121293$Oz4.25309@rwcrnsc54...
"John Hairell" wrote...
He is delusional - this has been argued ad-nauseam this year, last
year, and the prior year, and Tarver always argues from the same
position, namely that the military is not at all subject to FAA
jurisdiction. This seems to be an issue of "constitutionality" with
him, i.e. his position has previously been that DOD is part of the
executive department and is not subject to any regulatory agencies.
And he is wrong.
Indeed, those of us who have been here for a while know that Tarver posts
a lot
of incredible BS around here. However, lest the occasional newcomer start
to
accept any of it as truth, it is worth debunking again.
Just admit you are wrong about FAA having Authority over the military,
Weiss. FAA control of airspace through ATC is at the discression of the
military.
As to my understanding of electric aircraft systems being a minor area, I
recommend you spend some time educating yourself as to how modern aircraft
work.
John p. Tarver, MS/PE
Old August 15th 03, 08:11 PM
John R Weiss
"Tarver Engineering" wrote in message
FAA provides military operations areas wherever the military requests them.
http://www1.faa.gov/ATPubs/AIR/air2501.html#25-1-6
Not quite... The FAA MAY provide a military operations area when the military
requests one. The FAA has the final decision authority (14 CFR 11.69).
Additionally here is the FAA Order for special military operations, as
published in the Congressional Record.
http://www1.faa.gov/ATPubs/MIL/INDEX.HTM
Indeed, the military may REQUEST exercise areas and Special Use Airspace from
the FAA for special military operations. However, as provided in par. 2-1-4.a.
of Order 7610.4J, Order 7400.2 governs the procedures. Par. 21-1-5 of Order
7400.2E is very clear:
"FAA Headquarters is the final approval authority for all permanent and
temporary SUA, except CFA's. CFA approval authority is delegated to the regional
ATD."
Again, the FAA has the final authority to approve or deny requests.
For safety and cost reasons FAA ATC has control of airspace for both
civilian and military operations, but ATC has no authority to sanction
either a pilot, or the military. ATC, as demonstrated in the two ATC Orders
(law) posted here, is in compliance with the Military's needs and not the
other way around. In the case of "Special Operations", ATC may have an
obligation to ground all civil aircraft, as was demonstrated in 2001.
The FAA certainly has the obligation to consider military needs, but it is not
required to approve all military requests.
Note that the FAA is the one that grounded all civil aircraft in 2001 -- not
some other agency. Certainly other agencies had significant input into the
FAA's decision, but "the Administrator" made the final decision.
Neither of the orders you cite has anything to do with FAA sanctions of pilots
or "the military."
Old August 15th 03, 08:35 PM
Tarver Engineering
. net...
"Tarver Engineering" wrote...
military.
Not according to all the statutes, regulations, and orders cited so far...
What would you have FAA do if the Military chose to take flight?
USAF axes the bicycle aerobics test S. Sampson Military Aviation 22 August 10th 03 03:50 AM
FS Books USAF, Navy, Marine pilots and planes Ken Insch Military Aviation 0 July 20th 03 02:36 AM
NZ plane lands safely with help from USAF Jughead Military Aviation 0 July 6th 03 10:23 PM
From Col.Greg Davis USAF (ret) ArtKramr Military Aviation 0 July 3rd 03 07:56 PM
