Headphone/mic adapter question
I'm a musician and I have some excellent noise reduction
in-ear headphones. I would like to use these as my in-cockpit headphones. Generally - the regular over-the-head, squish-your-ear things are quite annoying to me. However - that leaves me with the issue of a mic and adapter to use these headphones. Can anyone tell me what I need to look for so I can use my own noise isolation in-ear headphones (they have the same connector as a regular walkman type headphones - 1/8" connector) while flying? I will still need a mic. THANKS ALL! You guys have always had great suggestions. I appreciate your help in advance. G. Gilbert 6472L @ W29 |
The first issue with the headphones is impedance. Most home audio and music
equipment speakers and headphones are 8 ohm. General aviation electronics use 600 ohm, I believe. So you will need something to match that. You will need a 1/4" to 1/8" adapter for the plug. Hello, my name is Mike, and I am an airplane addict.... GEG wrote in message ... I'm a musician and I have some excellent noise reduction in-ear headphones. I would like to use these as my in-cockpit headphones. Generally - the regular over-the-head, squish-your-ear things are quite annoying to me. However - that leaves me with the issue of a mic and adapter to use these headphones. Can anyone tell me what I need to look for so I can use my own noise isolation in-ear headphones (they have the same connector as a regular walkman type headphones - 1/8" connector) while flying? I will still need a mic. THANKS ALL! You guys have always had great suggestions. I appreciate your help in advance. G. Gilbert 6472L @ W29 |
Hi Mike -
Actualyl, small headphones generally are not the 8 ohm impedance. They are higher. But, 600 ohm might not be the spec on these - I'll check. Possibly 32 ohm is quite common in in-ear phones. But, a simple transformer can fix that. . . Thanks for the follow up. Gary |
Similar Threads | ||||
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Phoenix AIM-54A (QUESTION) | Krztalizer | Naval Aviation | 10 | February 23rd 04 07:22 AM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
