Javelin...
Old May 6th 07, 12:32 AM posted to rec.aviation.piloting
Dan[_1_]
Default Javelin...
Looks nice, but could suffer from some of the "Cirrus-like" links
between marketing and safety record. Still, if I had the money, it
would be the ultimate ride. (as long as your kids don't want to ride
along).
http://www.youtube.com/watch?v=Ko1WY...elated&search=
http://www.avtechgroup.com/
They've been talking about this thing for a while, but it would seem
that there is only one flying..?
--Dan
Old May 6th 07, 01:35 AM posted to rec.aviation.piloting
Larry Dighera
Default Javelin...
On 5 May 2007 16:32:46 -0700, Dan wrote in
.com:
Truly awesome! Breathtaking!
I hear Hayden "Jim" Sheaffer's* has a deposit down on one of those.
Pilots like him shouldn't have any problem thinking ahead of an
aircraft like the Javelin. :-)
* http://www.aopa.org/whatsnew/newsite...050523faa.html
Old May 6th 07, 11:35 AM posted to rec.aviation.piloting
B A R R Y
Default Javelin...
Reminds me of a T-33.
Old May 6th 07, 01:41 PM posted to rec.aviation.piloting
Morgans[_2_]
Default Javelin...
"B A R R Y" wrote in message
Form does follow function, in this case, doesn't it?
2 engines, 2 seat, small, no need for heavy carry capability. Plop! There
it is; almost like a T-33!
Jim in NC
Old May 6th 07, 05:45 PM posted to rec.aviation.piloting
B A R R Y
Default Javelin...
On Sun, 6 May 2007 08:41:56 -0400, "Morgans"
I meant some of the details, like the intakes, and the arches along
the size.
Lots of 2 seat jets with similar capability don't look like a T-33.
Old May 6th 07, 06:52 PM posted to rec.aviation.piloting
B A R R Y
Default Javelin...
On Sun, 06 May 2007 12:45:42 -0400, B A R R Y
the size.
What a maroon I am...
I was actually referring to the Javelin resembling a T-38, the trainer
version of the F5.
Hey, _I_ knew what I was talking about! G
Old May 7th 07, 12:04 AM posted to rec.aviation.piloting
Morgans[_2_]
Default Javelin...
version of the F5.
Yeah, I did too, and I wasn't even in your head! I didn't catch the
mistake, either.
Seriously though, given the project's mission, it is not surprising to me
that it came out looking a lot like the T-38. There are not that many
different ways you can arrange things, and make it perform as the designers
intended. I'm sure they did a lot of, "well, what is out there, that does
what we want to do, and does it look cool. It has to look cool!"
Jim in NC
Old May 7th 07, 09:37 PM posted to rec.aviation.piloting
Erik
Default Javelin...
along).
--Dan
What's the minimum length runway needed??
Old May 8th 07, 03:31 AM posted to rec.aviation.piloting
Dan[_1_]
Default Javelin...
along).
--Dan
What's the minimum length runway needed??- Hide quoted text -
- Show quoted text -
Technical features for the Javelin MK-10
Engines: Two - 1,700 pound thrust, turbo-fan Williams International
FJ33-4A-17M
Seating capacity: Two, tandem
Max gross weight: 6,200 pounds
Wing span: 23.25 feet
Length: 36 feet
Height: 10.5 feet
Wing area: 120 square feet
Take-off ground roll (std day, SL, 6,200 lb): 1,800 feet
Balanced field (std day, SL, 6,200 lb): 3,000 feet
Max rate of climb: 10,000 ft/min
Time to climb to 41,000 ft (ISA, std day, 6,200 lb): 13 min.
Cruise speed (ISA, std day, 5,500 lb, 35,000 ft): 0.90 Mach, 525 KTAS,
600 mph
Stall speed in landing configuration (6,080 lb.): 110 KCAS
Approach speed: 132 knots (at max gross weight)
Approach speed: 114 knots (at landing weight)
Landing distance (std day, SL, 6,080 lb, full flaps)
Ground Roll: 2,200 feet
Over 50 ft: 5,000 feet
Landing Distance (std day, SL, 4,575 lb, full flaps)
Ground Roll: 1,800 feet
Over 50 ft: 4,200 feet
IFR Range (M 0.80): 1,200 nm
Endurance: 3.5 hours
Fuel capacity: 280 gallons
Fuel Consumption at mid-cruise weight
Economy cruise (0.80 Mach at 45,000 ft): 75 gal/hr
High-speed cruise (0.90 Mach at 35,000 ft) 109 gal/hr
Certified ceiling: 45,000 feet
Cargo/Baggage: up to 200 lb.
Price 2005: $2.795 million (will be indexed, taxes not included)
Old May 8th 07, 04:16 AM posted to rec.aviation.piloting
Montblack
Default Javelin...
("Dan" wrote)
http://www.viper-aircraft.com/
Check out these guys
Forget the price, look at those build hours. Wow.
Montblack
My Dad's Avalon pics : ATG Javelin 2 Dave Kearton Aviation Photos 0 March 30th 07 10:11 AM
How many Javelin Ford V6s actually flew/are flying? Bret Ludwig Home Built 12 October 10th 05 03:29 PM
