TSA proposal TSA-208-0021, Large Aircraft Security Program
Link here, comments are open through 2/27/09,
http://www.regulations.gov/fdmspubli...=TSA-2008-0021 Affected parties are owners/operators of large GA airplanes ( 12,500# gross wt), of which there are roughly 9000 in US. The TSA's own estimate is that these regs will cost those 9000 owners about $1.4 Billion over ten years. Among other things, TSA wants to screen pax for private GA flight. Only on large GA aircraft... for now. This is a news item in EAA mag this month, I'm sure it's on the radar at AOPA as well. Passing along for the benefit of the soaring community. Evan Ludeman / T8 |
One (of many) problems I understand about this proposal is that if you
operate our of an airport that operates aircraft in excess of this weight, that it will simply be impractical for the FBO there to not screen everyone as they enter the airport, even if it isn't required So even if you are going through to your DG400 you may still have be screened because but they can't practically just wave you around there screening process becuase you say it doesn't apply to you. Simply put the proprosal does explain how the will determine who to screen and who not to. There are many other problems with this proprosal as well. Brian |
Similar Threads | ||||
Proposal to Provide Aircraft to Snowbirds | BLR | Aviation Marketplace | 0 | September 16th 06 07:12 AM |
Airport security still a welfare to work program in Atlanta | JJ | Instrument Flight Rules | 0 | October 18th 03 02:28 PM |
