Mic info
Looking for advice on improving the radio transmissions in the recently acquired Duo Discus XL.
The factory installed Microaire M760-1 radio and Bayerdynamic SHM 424 microphone work fine - if you are practically eating the mic. If your head is turned slightly no voice, only carrier. Anyone know of a gain adjustment of some sort to make the mic more sensitive? Thanks in advance. Karl Striedieck |
Mic info
On Monday, August 29, 2016 at 7:08:08 PM UTC-4, Karl Striedieck wrote:
Looking for advice on improving the radio transmissions in the recently acquired Duo Discus XL. The factory installed Microaire M760-1 radio and Bayerdynamic SHM 424 microphone work fine - if you are practically eating the mic. If your head is turned slightly no voice, only carrier. Anyone know of a gain adjustment of some sort to make the mic more sensitive? Thanks in advance. Karl Striedieck There are two trim pots on the right side of the radio. Rear is mic gain. Para 4.8.2 of the P rev manual says quote Please refer to the figure below to see how the trim pots are adjusted. The trim pots have a total movement of only 270 degrees (3/4 turn). The heads of the trim pots are plastic, and can be distorted or broken off unless adjusted with great care. A small straight blade screwdriver with an insulated shaft is required. Ensure the radio is turned off before punching the hole under the black dot, and probing for the slot in the head of the trim pot. Once the screwdriver is engaged on the trim pot, the radio can be turned on, and the adjustment made. unquote The other trim pot is for sidetone. I had feedback and adjusted the mic gain to sort it out. Counterclockwise turn decreases mic gain. Dan |
Mic info
Thanks Dan! I'll give that a try.
KS |
Mic info
If the gain adjustment doesn't do the trick I've found the current Microaire mics are pretty good. A vast improvement on the ones that came with the M760's when we equipped several of our club ships with those radios back around 2000 both in terms of audio performance and in staying where you put them (the old ones lost strength in the booms after one year and kind of flop around).
Mic info
Per the Microaire manual info I increased the gain to full and that solved the problem.
The mic was also floppy and fell out of position with air and ground bumps. Simply rotating the entire goose neck about 10 degrees seated it firmly in whatever threads are hidden behind the moulding. Thanks again! KS |
Mic info
I had to take my Microair M760 out of the panel to find the slot in head of the trim pot. I made the adjustment and now the radio is almost tolerable. No actually it's on my must replace, list :-(
Gino Cavicchioli Sosa Gliding Club Canada |
Mic info
Karl,
I have a FSG 71M Dittel (10 ch memory on a knob) and a new dynamic mic on a long goose neck that's excess to my needs. Give me a shout if you want to replace your microair. JJ Johnsincllair210(at)yahoo.com |
Mic info
On Tuesday, August 30, 2016 at 11:55:39 PM UTC-4, wrote:
Karl, I have a FSG 71M Dittel (10 ch memory on a knob) and a new dynamic mic on a long goose neck that's excess to my needs. Give me a shout if you want to replace your microair. JJ Johnsincllair210(at)yahoo.com Microair radios are very voltage sensitive... you can add a voltage booster to 14v, and they work much better. They do have lower transmit power than the other radios, though. The price you pay for the price you pay. |
Mic info
My experience with Microaire radios over the last 20 years has been very good. They've never given me any problems and I can converse with other gliders 100 miles away (Harris Hill). KS |
Mic info
On Wednesday, August 31, 2016 at 10:24:59 PM UTC-4, Karl Striedieck wrote:
My experience with Microaire radios over the last 20 years has been very good. They've never given me any problems and I can converse with other gliders 100 miles away (Harris Hill). KS This agrees with my experience. UH |
Similar Threads | ||||
Info please | ASM | Soaring | 7 | October 21st 06 02:41 PM |
More info about LEX | JohnWayne | Instrument Flight Rules | 15 | September 3rd 06 05:23 PM |
RHJ-8 Info? | Scott | Soaring | 6 | March 24th 05 09:21 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
