Engine Making Metal
In rec.aviation.owning Stan Prevost wrote:
: If the mixture is set to spec, it is not necessary to lean for ground ops, : since it is already lean enough to prevent plug fouling. Ground leaning is : effective only if leaned back to the edge of idle cutoff, anyway. : The Lycoming manual doesn't seem to have any tables for adjusting RPM rise : for density altitude. If it is leaned to the 5RPM rise spec at a high : altitude airport, I wonder if it might be too lean at a low-altitude : airport, with no way to enrichen it. Not to mention seasonal variation. With temperatures in Virginia in the 60s (!) the past weeks it's difficult to even do it for winter/summer... not to mention density altitude. I ground lean mine... typically right on the edge of idle cutoff. It's enough so that anything over 1200 RPM will cause the engine to stumble. That way it will be periodically run extra-lean during the taxi and help reduce plug fouling. Can't hurt the engine with leaning at such low power and it's impossible to runup or takeoff without enrichening. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Engine Making Metal
With regard to severe leaning on the ground, does hot summertime temps make
a difference? Long taxis or long hold shorts? I made the "lean the sh!t out of it on the ground" comment at a flying club meeting once, & one of the guys flipped. wrote in message ... In rec.aviation.owning Stan Prevost wrote: : If the mixture is set to spec, it is not necessary to lean for ground ops, : since it is already lean enough to prevent plug fouling. Ground leaning is : effective only if leaned back to the edge of idle cutoff, anyway. : The Lycoming manual doesn't seem to have any tables for adjusting RPM rise : for density altitude. If it is leaned to the 5RPM rise spec at a high : altitude airport, I wonder if it might be too lean at a low-altitude : airport, with no way to enrichen it. Not to mention seasonal variation. With temperatures in Virginia in the 60s (!) the past weeks it's difficult to even do it for winter/summer... not to mention density altitude. I ground lean mine... typically right on the edge of idle cutoff. It's enough so that anything over 1200 RPM will cause the engine to stumble. That way it will be periodically run extra-lean during the taxi and help reduce plug fouling. Can't hurt the engine with leaning at such low power and it's impossible to runup or takeoff without enrichening. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Engine Making Metal
Steven Barnes wrote:
With regard to severe leaning on the ground, does hot summertime temps make a difference? Long taxis or long hold shorts? I made the "lean the sh!t out of it on the ground" comment at a flying club meeting once, & one of the guys flipped. Leaning during high ground temperatures should not cause excessive cylinder temperatures since you are taxiing at very low RPMS. The C172SPs (fuel-injected engines) at my former flight school always experienced fouled plugs if the students/renters failed to lean for ground operations. -- Peter |
Similar Threads | ||||
Nasa Icing courses | Jim Burns | Piloting | 96 | February 1st 06 04:16 AM |
Nasa Icing courses | Jim Burns | Owning | 108 | February 1st 06 04:16 AM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 05:18 PM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
