Update - Garmin GPSmap 496 False Terrain Alert
Garmin have pointed out how I can read the terrain data from the 496. On the
Terrain page use the cursor to point to a location. The elevation MSL is shown on line two in the black band above the map. The south end of runway 15 has a terrain elevation of 715 ft msl in the database. In fact, it has an actual elevation of only 639 ft msl using the Jeppesen chart for the airport. In addition, the terrain just north of the airport is also shown as 715 ft msl. Using the GPS I've gotten readings that this terrain is actually more like 650 ft msl. That may be part of this problem. Thanks, -Ron "Ron Gordon" wrote in message . net... That's a very good suggestion. I will make the request on Monday. Since I can carry the 496 to the elevation data points leading to and around the approach path, these should be easy to confirm. And as you point out, the terrain around KADS is very flat. It is likely that an erroneous data point may be self evident. Thanks! -Ron Gordon Ron, have you asked Garmin if they're willing to give you a copy of the raw datapoints of the terrain elevation around ADS? I'm thinking the erroneous datapoint(s) will be terrain data since an obstacle should be easily displayed as such on the 496 map. Since you know the area, you might be able to spot the errant datapoint and help them out. Marco |
Similar Threads | ||||
Garmin Gpsmap 96 | chris | Piloting | 5 | February 9th 07 01:05 AM |
Garmin 296/396 Terrain Data | [email protected] | Instrument Flight Rules | 21 | December 14th 05 02:46 PM |
Garmin GPSMAP 195 | Jonathan Goodish | Aviation Marketplace | 0 | June 21st 05 01:00 AM |
Garmin 430 Terrain Avoidance | endre | Instrument Flight Rules | 5 | July 22nd 04 03:41 AM |
FS: Garmin GPSMAP-196 | Aircraft Mechanic in Tampa | Aviation Marketplace | 3 | March 6th 04 03:19 AM |
