#41
oups.com... "Why Choose a Turbo-Normalizer Instead of a Turbo-Booster?" http://www.m-20turbos.com/choose.htm With which statement on that page do you take issue? Note that they are talking about using inter-cooling and "after-cooling" (not sure what that is). For sure, inter-cooling can do a lot to address the issue of higher operating temperatures, by counter-acting the temperature rise that occurs due to compression. Regardless, unless you are trying to say that you disagree with the entire page, providing just the link really does very little to explain to us what it is you have trouble with. I don't see anything obviously wrong with the statements made on the page (though I can't comment on some of them, such as the legalities of turbo-boosting the particular installations they are talking about for example). Pete |
#42
ink.net... Actually a constant speed prop converts HP into thrust about the same at all (reasonable) altitudes. That is one of the great advantages of a CS prop. Really? I just assumed that with air density lower, the prop (CS or otherwise) had less air available to move, and thus could not produce sea-level thrust. I guess in that case, my longer take-off runs are solely due to the higher true speed required. Still, that's a significant effect. I just don't want anyone thinking that a turbocharger makes high-altitude takeoffs just like sea-level. Pete |
#43
On 18 May 2005 19:52:12 -0700, "Robert M. Gary"
wrote: "Why Choose a Turbo-Normalizer Instead of a Turbo-Booster?" http://www.m-20turbos.com/choose.htm Simple really. I could add a turbo normalizer to my engine while changing little else. If I added a turbocharger, I'd have to put in lower compression pistons, but depending on the STC could get more HP. IOW, you can basically add the turbonormalizer to almost any engine, but you can't do that with a turbocharger. If you limit the boost of the turbocharger you have just turned it into a turbonormalizer. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#44
On Wed, 18 May 2005 17:33:58 -0700, "Peter Duniho"
wrote: What's the cost? Well, I can't speak for the average. But in my own case, I have had a "mini top overhaul" (replaced one piston, due to leaking rings on that piston, causing erosion of the piston head), and have had to replace all of the exhaust valves and guides. I don't even know that this was due to the turbo-charger, but certainly it seems that the extra heat may have accelerated the wear, if not caused it entirely. There was a website devoted to the wear of Lycoming valve guides that went into design and development of Lycoming engines, and also what they think is the actual problem causing the premature wear in certain models of Lycomings. You probably can find it by Googling "lycoming valve guide wear". To synopsize, the mechanics who took it upon themselves to research the problem feel that it is Lycoming's use of a particular type of cam follower or lifter, that has created the situation (of accelerated valve guide wear). Lycoming patterned their original lifter after those used by flathead engines. Since flathead engines have the valves in the block, not the head, the lifter design, which was not intended to flow much oil through it, worked fine. But when this lifter was used in Lycoming's overhead designs, there were problems because not much oil was getting to the valve guides and they suffered premature wear. Many of the fixes for those engines that suffered the most are fixes that bring more oil to the valve guide area, according to this well documented and extensive three or four part article. But the conclusion of the article is that Lycoming does not have the in-house engineers to come up with a real fix at this point. Corky Scott |
#45
On Thu, 19 May 2005 09:07:42 -0400, Corky Scott
wrote: There was a website devoted to the wear of Lycoming valve guides that went into design and development of Lycoming engines, and also what they think is the actual problem causing the premature wear in certain models of Lycomings. Here's the article I was referring to: http://precisionengine.home.mindspring.com/engine1.htm Corky Scott |
#46
"Mike Rapoport" wrote in message news:hyTie.4294 I would disagree, there are a lot of reasons to buy a turbo (nomalizer or otherwise). To fly higher, fly faster, climb much faster, takeoff shorter (much shorter at high DA). In the case of the B36TC, your TBO goes up 100 hours. Here is some data and examples (Check the brochure links at the bottom of the page). http://www.taturbo.com/tcppr.html Here is the contrast from a TSIO-520 to a TNIO-550 http://www.taturbo.com/performance.html Reference http://www.taturbo.com/houtbk.jpg Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#47
"Robert M. Gary" wrote in message ups.com... But runnnig your engine at 30" at 15,000 feet is MUCH harder on the engine than running 30" at 5,000 feet. The engine runs hotter and harder. (Where are you getting this information from?) No, it isn't. MOF, it's probably easier as the air temp is colder and thus aerodynamic cooling of the engine compartment will be more efficient. Matt (TN Beech B36) --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#48
"Mike Rapoport" wrote in message nk.net... 65% is 65%, is 65%. All equal, no harder. That is the point of turbo norm. The engine has not got a clue how high it is. MP is the same at sea level or 15 thousand. The only argument is the temp. Keep it cool. it is not that hard, nor is it rocket science. -- Jim in NC Yes the MP is the same but the CHTs will be much higher. Basically you are trading better performance for higher temps. Turbo Lances can't make 75% power above 16,000 on warm days without CHTs well over 400F. It really isn't possible to produce a lot of power at high altitude without higher temps. I think that Robert's point is that there is a tradeoff. Well, it's wrong. My CHT's are virtually the same (370-380) at 8000 as they are at 16K. Heat come from your mixture, and at higher altitude, there is less drag to be overcome. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#49
"Mike Rapoport" wrote in message ink.net... "Peter Duniho" wrote in message ... In addition, mountain flying is less dangerous. Ground speeds are still higher, and the prop can't convert the horsepower to quite as much thrust as it would at sea-level. But it's not nearly as much a reduction as I'd get without the turbocharger. Acceleration, even at max gross, is good as is the climb rate (handy when you are surrounded by high terrain ). Actually a constant speed prop converts HP into thrust about the same at all (reasonable) altitudes. That is one of the great advantages of a CS prop. Some of them. In the Bonanza conversions, you would need a new prop or else your engine is placarded to limit MP. Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#50
"Corky Scott" wrote in message ... On Thu, 19 May 2005 09:07:42 -0400, Corky Scott wrote: There was a website devoted to the wear of Lycoming valve guides that went into design and development of Lycoming engines, and also what they think is the actual problem causing the premature wear in certain models of Lycomings. Here's the article I was referring to: http://precisionengine.home.mindspring.com/engine1.htm Corky Scott Also... (Fried Valves) http://www.avweb.com/news/columns/182155-1.html -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Similar Threads | ||||
FS: Duo Discus Turbo - Texas, USA | Mark Zivley | Soaring | 2 | May 4th 05 11:34 PM |
turbo stc? | The Weiss Family | Owning | 21 | October 3rd 04 10:35 PM |
Turbo prop AT-6/SNJ? | frank may | Military Aviation | 11 | September 5th 04 02:51 PM |
Turbo 182: correct mixture for final approach at high altitude? | Barry Klein | Piloting | 38 | January 15th 04 03:25 AM |
A36 Bonanza turbo prop | Jeff | Owning | 46 | January 7th 04 02:37 PM |
