How about some talk about flying?
Since this group is being overwhelmed by an incredible quantity of crap,
and contains virtually no actual reasonable on-topic posts, here's a little attempt to switch things up. I wrote this message to my club, but it ought to fit in here OK. Even though it's not about big complicated machines with spinning fans up front, at least it's about flying! .... And an incredible testament to the power of XCSkies here. I checked the XCSkies forecast in the morning before I left home. It showed good lift to about 3,000ft over the Massanutten, and to 6,000ft over the Blue Ridge. Since they're so close together, I figured this couldn't POSSIBLY be really accurate, and just took it to mean that the lift would be spotty. After the shortest non-rope-break tow I have EVER experienced (the vario needle disappeared past 10kts before the end of the runway, and eventually pegged so hard that the needle went all the way around past zero a second time) I climbed in good lift over the Massanutten to... a little over 3,000ft. Couldn't get much past that no matter what I tried. Remembering the XCSkies forecast, I fell back to the Blue Ridge. Lift was consistent enough that I got there at around 3,200ft still, and hit solid lift again. A few minutes later I banged into cloudbase and checked the altimeter... 6,200ft. Now THAT is incredible weather forecasting precision. An XCSkies subscription is worth every penny in my view. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
On Nov 7, 7:15*am, Mike Ash wrote:
Since this group is being overwhelmed by an incredible quantity of crap, and contains virtually no actual reasonable on-topic posts, here's a little attempt to switch things up. I wrote this message to my club, but it ought to fit in here OK. Even though it's not about big complicated machines with spinning fans up front, at least it's about flying! ... And an incredible testament to the power of XCSkies here. I checked the XCSkies forecast in the morning before I left home. It showed good lift to about 3,000ft over the Massanutten, and to 6,000ft over the Blue Ridge. Since they're so close together, I figured this couldn't POSSIBLY be really accurate, and just took it to mean that the lift would be spotty. After the shortest non-rope-break tow I have EVER experienced (the vario needle disappeared past 10kts before the end of the runway, and eventually pegged so hard that the needle went all the way around past zero a second time) I climbed in good lift over the Massanutten to... a little over 3,000ft. Couldn't get much past that no matter what I tried. Remembering the XCSkies forecast, I fell back to the Blue Ridge. Lift was consistent enough that I got there at around 3,200ft still, and hit solid lift again. A few minutes later I banged into cloudbase and checked the altimeter... 6,200ft. Now THAT is incredible weather forecasting precision. An XCSkies subscription is worth every penny in my view. Sounds like there might be decent wave in that area.. |
In article
, george wrote: Remembering the XCSkies forecast, I fell back to the Blue Ridge. Lift was consistent enough that I got there at around 3,200ft still, and hit solid lift again. A few minutes later I banged into cloudbase and checked the altimeter... 6,200ft. Now THAT is incredible weather forecasting precision. An XCSkies subscription is worth every penny in my view. Sounds like there might be decent wave in that area.. I had similar thoughts. The satellite picture showed unmistakable signs of wave farther south, terminating about 30 miles or so south of my airport. The clouds in the area weren't classic wave formations, but I thought they looked promising. However, no matter how hard I searched, I never found wave. The area where I was flying was very rotor-like, with strong turbulence everywhere, decreasing slowly with altitude, but I only ever found very bumpy lift under the clouds, never anything away from them, and never anything smooth. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
On Nov 7, 1:23*pm, Mike Ash wrote:
In article , *george wrote: Remembering the XCSkies forecast, I fell back to the Blue Ridge. Lift was consistent enough that I got there at around 3,200ft still, and hit solid lift again. A few minutes later I banged into cloudbase and checked the altimeter... 6,200ft. Now THAT is incredible weather forecasting precision. An XCSkies subscription is worth every penny in my view. Sounds like there might be decent wave in that area.. I had similar thoughts. The satellite picture showed unmistakable signs of wave farther south, terminating about 30 miles or so south of my airport. The clouds in the area weren't classic wave formations, but I thought they looked promising. However, no matter how hard I searched, I never found wave. The area where I was flying was very rotor-like, with strong turbulence everywhere, decreasing slowly with altitude, but I only ever found very bumpy lift under the clouds, never anything away from them, and never anything smooth. Get a tow into the 30 mile south area and do an orbit on tow. If theres anything you'll feel it. It may be that the areas pretty dry and lenticular won't form. Was the rotor visible? |
In article
, george wrote: On Nov 7, 1:23*pm, Mike Ash wrote: In article , *george wrote: Remembering the XCSkies forecast, I fell back to the Blue Ridge. Lift was consistent enough that I got there at around 3,200ft still, and hit solid lift again. A few minutes later I banged into cloudbase and checked the altimeter... 6,200ft. Now THAT is incredible weather forecasting precision. An XCSkies subscription is worth every penny in my view. Sounds like there might be decent wave in that area.. I had similar thoughts. The satellite picture showed unmistakable signs of wave farther south, terminating about 30 miles or so south of my airport. The clouds in the area weren't classic wave formations, but I thought they looked promising. However, no matter how hard I searched, I never found wave. The area where I was flying was very rotor-like, with strong turbulence everywhere, decreasing slowly with altitude, but I only ever found very bumpy lift under the clouds, never anything away from them, and never anything smooth. Get a tow into the 30 mile south area and do an orbit on tow. If theres anything you'll feel it. It may be that the areas pretty dry and lenticular won't form. Well, there were lenticular-looking things on the satellite photo. I wasn't up to doing such a long tow, though, especially since the 30 miles was just a rough estimate. Was the rotor visible? There were a couple of lower-level clouds that looked like they may have been rotor clouds, but for the most part no. Another interesting part to this day. It had been mostly calm all day. The report came in from another fellow that there was lift, so I started getting ready for takeoff. As I was standing next to my glider getting the cockpit prepped, there was this sudden WOOSH as the wind went from 0 to 10+kts instantaneously, and just stayed there for the rest of the day. Really odd stuff! -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
On Nov 7, 6:35*pm, Mike Ash wrote:
Well, there were lenticular-looking things on the satellite photo. I wasn't up to doing such a long tow, though, especially since the 30 miles was just a rough estimate. You -could- always go slumming and get a ride with a friendly power pilot in the general direction :-) If its wave it'll be there :-) What, might I ask, are you flying? |
Similar Threads | ||||
King Johnny Calls In to Talk Radio in America - These calls are just a small random grouping of call-ins I've done in these last several weeks in America - King Johnny Calls In to Talk Radio in America | Ian B MacLure | Naval Aviation | 0 | April 14th 09 05:28 AM |
Anyone want to talk me out of... | Jon Kraus | Owning | 46 | October 1st 04 08:25 PM |
Reasons to talk to ATC... | jsmith | Piloting | 22 | April 7th 04 01:21 AM |
Talk me out of this... | Paul Folbrecht | Owning | 84 | February 11th 04 10:20 PM |
Talk to your ATC | James Hetrick | Simulators | 1 | August 25th 03 01:02 AM |
