Duo Discus canopy problems
I recently had the alarming experience of the canopy coming nearly fully
open on a Duo Discus shortly after take-off on aerotow. Both my student (who was flying the glider at the time) and I grabbed the handles when the canopy was about 45 degrees open and managed to close it. However all efforts to lock it failed, probably because the airflow was distorting the Perspex and preventing the frame from seating correctly, so we resorted to holding it closed. The canopy catch has had a SH mod. kit fitted which is supposed to apply some spring pressure to keep the catch in the closed position. The takeoff in question was a relight after landing at another airfield, and after discussion with my student, we decided to continue the launch and had an otherwise uneventful glide home, holding the canopy shut till we landed. Both my student and I clearly recalled doing our pre-takeoff checks, including confirming that the canopy was locked closed. The most likely cause of the incident seems to be vibration during the slightly bumpy takeoff run, which probably caused the catch to move towards the open position. I subsequently discovered that this has happened before. The mod. kit is pretty ineffective as the spring isn't even strong enough to pull the catch into the closed position when the canopy is open, let alone when the mechanism has to engage at three points along the canopy's length. The following day I wrapped a single turn of PVC wing tape around the catch; enough to hold it closed, but easy to break if the canopy needed to be opened in an emergency. The worst aspect of the whole incident was losing my favourite gliding hat which blew off my head when the canopy opened! Has anyone had a similar experience or advice on improving the Duo's canopy catch? David Starer |
I was a partner in a 2001 Duo that came with the canopy
latch mod already fitted. The canopy never came open spontaneously and I never found any tendency for the latch to gradually open itself. BUT - several times I found that in the front cockpit my left hand would catch on the latch - the distal end of which projects a bit - and several times I found that I slightly caught the latch in the open part behind the button of long sleeved cotton shirts. I was surprised how easily the latch would move in flight with a gentle catch and on one ocasion I accidentally pulled the latch open on my shirt but was able to shut it quickly before the canopy moved. I would doubt that the latch of our glider would have opened by vibration on the ground run. I do think that the shape of the Duo latches makes them particularly liable to be accidentally caught. It would be better if the latch was shaped like LS latches - curved in from the canopy frame and then back towards it so that it is easy to get hold of but has no projecting forward facing end. John Galloway At 07:54 20 June 2004, David Starer wrote: I recently had the alarming experience of the canopy coming nearly fully open on a Duo Discus shortly after take-off on aerotow. Both my student (who was flying the glider at the time) and I grabbed the handles when the canopy was about 45 degrees open and managed to close it. However all efforts to lock it failed, probably because the airflow was distorting the Perspex and preventing the frame from seating correctly, so we resorted to holding it closed. The canopy catch has had a SH mod. kit fitted which is supposed to apply some spring pressure to keep the catch in the closed position. The takeoff in question was a relight after landing at another airfield, and after discussion with my student, we decided to continue the launch and had an otherwise uneventful glide home, holding the canopy shut till we landed. Both my student and I clearly recalled doing our pre-takeoff checks, including confirming that the canopy was locked closed. The most likely cause of the incident seems to be vibration during the slightly bumpy takeoff run, which probably caused the catch to move towards the open position. I subsequently discovered that this has happened before. The mod. kit is pretty ineffective as the spring isn't even strong enough to pull the catch into the closed position when the canopy is open, let alone when the mechanism has to engage at three points along the canopy's length. The following day I wrapped a single turn of PVC wing tape around the catch; enough to hold it closed, but easy to break if the canopy needed to be opened in an emergency. The worst aspect of the whole incident was losing my favourite gliding hat which blew off my head when the canopy opened! Has anyone had a similar experience or advice on improving the Duo's canopy catch? David Starer |
You wrote that you and your student were sure that the canopy was
properly locked before take-off. The cockpit handle has to come a long way back before it unlocks the canopy. Probably the canopy on your duo has a rather loose fit? It also seems that the spring pressure needs to be readjusted. On my duo the canopy still has a tight fit after 300+ hours and lots of tows from bumpy fields. I think that your modification with the pvc tape is an excellent short term solution. On Sun, 20 Jun 2004 08:42:03 +0100, "David Starer" wrote: I recently had the alarming experience of the canopy coming nearly fully open on a Duo Discus shortly after take-off on aerotow. Both my student (who was flying the glider at the time) and I grabbed the handles when the canopy was about 45 degrees open and managed to close it. However all efforts to lock it failed, probably because the airflow was distorting the Perspex and preventing the frame from seating correctly, so we resorted to holding it closed. The canopy catch has had a SH mod. kit fitted which is supposed to apply some spring pressure to keep the catch in the closed position. The takeoff in question was a relight after landing at another airfield, and after discussion with my student, we decided to continue the launch and had an otherwise uneventful glide home, holding the canopy shut till we landed. Both my student and I clearly recalled doing our pre-takeoff checks, including confirming that the canopy was locked closed. The most likely cause of the incident seems to be vibration during the slightly bumpy takeoff run, which probably caused the catch to move towards the open position. I subsequently discovered that this has happened before. The mod. kit is pretty ineffective as the spring isn't even strong enough to pull the catch into the closed position when the canopy is open, let alone when the mechanism has to engage at three points along the canopy's length. The following day I wrapped a single turn of PVC wing tape around the catch; enough to hold it closed, but easy to break if the canopy needed to be opened in an emergency. The worst aspect of the whole incident was losing my favourite gliding hat which blew off my head when the canopy opened! Has anyone had a similar experience or advice on improving the Duo's canopy catch? David Starer |
WANTED PIK 20b rudder Also Pawnee Rudder and Starboard aileron (don't ask) -- David Reilly |
I hope the correspondent who sent me a private e-mail response to my earlier
post won't mind me quoting it as it gave me a good laugh: Dear Dave, What a problem. Next time, Ducktape an ELT onto your hat so that you may recover it in due course. David Starer "David Starer" wrote in message ... I recently had the alarming experience of the canopy coming nearly fully open on a Duo Discus shortly after take-off on aerotow. Both my student (who was flying the glider at the time) and I grabbed the handles when the canopy was about 45 degrees open and managed to close it. However all efforts to lock it failed, probably because the airflow was distorting the Perspex and preventing the frame from seating correctly, so we resorted to holding it closed. The canopy catch has had a SH mod. kit fitted which is supposed to apply some spring pressure to keep the catch in the closed position. The takeoff in question was a relight after landing at another airfield, and after discussion with my student, we decided to continue the launch and had an otherwise uneventful glide home, holding the canopy shut till we landed. Both my student and I clearly recalled doing our pre-takeoff checks, including confirming that the canopy was locked closed. The most likely cause of the incident seems to be vibration during the slightly bumpy takeoff run, which probably caused the catch to move towards the open position. I subsequently discovered that this has happened before. The mod. kit is pretty ineffective as the spring isn't even strong enough to pull the catch into the closed position when the canopy is open, let alone when the mechanism has to engage at three points along the canopy's length. The following day I wrapped a single turn of PVC wing tape around the catch; enough to hold it closed, but easy to break if the canopy needed to be opened in an emergency. The worst aspect of the whole incident was losing my favourite gliding hat which blew off my head when the canopy opened! Has anyone had a similar experience or advice on improving the Duo's canopy catch? David Starer |
Similar Threads | ||||
Canopy crack repair | Pete Brown | Soaring | 0 | May 18th 04 03:09 AM |
Redundant canopy latching | John | Soaring | 5 | March 16th 04 12:50 PM |
Pegasus comparisons sought | Ted Wagner | Soaring | 9 | January 24th 04 04:36 AM |
All Czech built Discus grounded | Paul | Soaring | 0 | September 14th 03 02:22 AM |
18m Discus | Burt Compton | Soaring | 2 | September 8th 03 10:52 AM |
