landing gear interface.
Old September 23rd 05, 02:51 PM
Steve Franklin
Default landing gear interface.
Hi there..
I have no idea about aviation so excuse me if this is a dumb question.
Why is that on planes the landing gear:
a) has such an unique interface relative to the other avionics. E.g Why the
long handle?
b) What is the purpose of the wheel at the end of the landing gear arm?
Cheers
Steve
Old September 23rd 05, 03:02 PM
Allen
"Steve Franklin" wrote in message
Hi there..
the long handle?
Cheers
Steve
What kind of airplane are you looking at Steve? Some gear handles are only
an electric switch that activates a valve and on others the handle moves the
valve itself. The wheel on the end is a symbol of what the handle does.
Flap handles are usually a flat blade. Helps reduce the accidental gear
retraction accident
Allen
Old September 23rd 05, 03:10 PM
Steve Franklin
I have just been watching 'Executive Decision' on TV and the aircraft was a
Boeing 747. The handle for the landing gear seemed very long and it had a
wheel on the end that look a lot like a roller-blade wheel.
So you are saying the wheel has no function other than to provide an instant
identification to the pilot that it's the gear handle?
Cheers
Steve
"Allen" wrote in message
t...
Hi there..
the long handle?
Cheers
Steve
only an electric switch that activates a valve and on others the handle
moves the valve itself. The wheel on the end is a symbol of what the
handle does. Flap handles are usually a flat blade. Helps reduce the
accidental gear retraction accident
Allen
Steven P. McNicoll
the long handle?
Landing gear is not avionics. The size of the gear "lever" depends on the
method of gear actuation. Aircraft with manual gear retraction and
extension need fairly long gear levers in order to obtain sufficient
mechanical advantage for the pilot. Aircraft with straight hydraulic
systems generally have longer gear levers than those with electric or
electrohydraulic systems because it takes more force to turn a valve than
actuate a switch.
To readily identify it as the gear lever; move the "wheel" to move the
wheels.
Old September 23rd 05, 03:58 PM
Kev
You're correct, it's so you can tell by feel and visual shape.
power = cylindrical
supercharger = cylindrical with triangular teeth
rpm = ridges like a section of a mechanical gear, flat ridges
mixture = like rpm, but thin sharp ridges
flags = flat with thin edge facing you
heat/alternate air = square facing you
gear = wheel
Kev
Old September 24th 05, 01:06 AM
Steve Franklin
power = cylindrical
gear = wheel
Kev
Thanks Kev...that makes so much more sense now....I can understand now. I
just couldn't understand why it wouldn't just be a button like so much
else..
But I can see now how important it would be if you say lost all power to the
cockpit instrumentation to be able to easily find the landing gear in the
dark if neccessary...
It all makes perfects sense...
Cheers
Steves
Old September 24th 05, 03:26 AM
George Patterson
Actually, that's for all the time. In many cases you don't want to take your
eyes off of something else (like the runway) just to be sure you have the right
lever.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
A&P heroics Jim Piloting 31 July 18th 05 07:26 PM
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
