Ugly Trailer
Ok, time to change threads from 'Where are you from'
to 'Ugly trailer. The trailer does not load over the tongue, but from the back. The idea of the trailer is quite sound, I believe. The wing tips go in first. It has the heavy part of the fuselage towards the front and the heavy part of the wings towards the rear, rather than the roots, thus the trailer is quite well balanced. It tows extremely easily. I towed it behind my four cylinder Honda for a few years until I was forced to get a newer car. Now, I tow it behind a six cylinder Honda and it tows even more easily. To improve the design, I would have a professional craftsman: 1. Build the trailer with brakes. 2. Put a cargo door up front. 3. Have the rigging tweaked. 4. Paint it! I don't know the weight of the trailer, but it must be light. Steel tube triangulated frame covered in aluminum skin attached to a steel angle perimeter frame and plywood floor. It's not a Cobra or Komet, but it serves it's purpose of storing my glider away from the elements and transporting it whenever the needs arises. Ray Lovinggood Carrboro, North Carolina, USA LS1-d 'W8' |
Ugly Trailer
Sounds like the Ugly L-23 "factory" trailer.. but it has CG problems with
the wing roots aft. BT "Ray Lovinggood" wrote in message ... Ok, time to change threads from 'Where are you from' to 'Ugly trailer. The trailer does not load over the tongue, but from the back. The idea of the trailer is quite sound, I believe. The wing tips go in first. It has the heavy part of the fuselage towards the front and the heavy part of the wings towards the rear, rather than the roots, thus the trailer is quite well balanced. It tows extremely easily. I towed it behind my four cylinder Honda for a few years until I was forced to get a newer car. Now, I tow it behind a six cylinder Honda and it tows even more easily. To improve the design, I would have a professional craftsman: 1. Build the trailer with brakes. 2. Put a cargo door up front. 3. Have the rigging tweaked. 4. Paint it! I don't know the weight of the trailer, but it must be light. Steel tube triangulated frame covered in aluminum skin attached to a steel angle perimeter frame and plywood floor. It's not a Cobra or Komet, but it serves it's purpose of storing my glider away from the elements and transporting it whenever the needs arises. Ray Lovinggood Carrboro, North Carolina, USA LS1-d 'W8' |
Ugly Trailer
Ray Lovinggood wrote: Ok, time to change threads from 'Where are you from' to 'Ugly trailer. What's so ugly about it? The idea of the trailer is quite sound, I believe. The wing tips go in first. It has the heavy part of the fuselage towards the front and the heavy part of the wings towards the rear, rather than the roots, thus the trailer is quite well balanced. It has that in common with most glider trailers in use here in NZ, except that the designer has gone to some trouble to taper it at the front whereas most trailers here are just a rectangular box (perhaps with a higher bit for the fin). -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- |
Ugly Trailer
In article Zcppf.921$_L5.796@fed1read06,
"BTIZ" wrote: Sounds like the Ugly L-23 "factory" trailer.. but it has CG problems with the wing roots aft. I remember someone, who's initials are "Guy Byars" once "liberating" some sandbags from a road construction project to remedy an L-23 trailer CG problem. |
Similar Threads | ||||
trailer interior lighting? | Ted Wagner | Soaring | 1 | February 16th 05 11:31 AM |
Trailer hitch inadvertant disconnect | Bill Daniels | Soaring | 5 | July 16th 04 03:17 AM |
Trailer spare - who woulda thunk? | Bill Daniels | Soaring | 7 | May 20th 04 04:47 PM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
Tire Stiffness & trailer swaying | chris | Soaring | 42 | October 22nd 03 03:51 AM |
