Removing RTV
I am trying to remove some RTV silicone sealant. I have carved and
scraped off most of it and am wondering what others have tried to remove the residue left after mechanical removal. Paint stripper doesn't work and I am trying some MEK now. Any thoughts? John Dupre' |
Removing RTV
In article om,
"John" wrote: I am trying to remove some RTV silicone sealant. I have carved and scraped off most of it and am wondering what others have tried to remove the residue left after mechanical removal. Paint stripper doesn't work and I am trying some MEK now. Any thoughts? John Dupre' Gasoline, lacquer thinner, MEK, TCE will lift it off, but it will probably still need some mechanical removal. |
Removing RTV
scraped off most of it and am wondering what others have tried to remove the residue left after mechanical removal. Paint stripper doesn't work and I am trying some MEK now. Any thoughts? John Dupre' Gasoline, lacquer thinner, MEK, TCE will lift it off, but it will probably still need some mechanical removal. TCE was the long time standard, since it wouldn't harm most other materials; but where does one obtain it today? Peter |
Removing RTV
Your local hardware store should have something to specifically remove bathtub silicone. It was invented about 20 yrs. ago. |
Removing RTV
wrote in message oups.com... Your local hardware store should have something to specifically remove bathtub silicone. It was invented about 20 yrs. ago. Good luck with that! The best I have found is a mechanical, if you wish, but specifically scotchbrite pad with an abrasive, like valve lapping compound, or comet cleanser, or rubbing compound. Silicone caulk was invented partially for its high resistance to chemicals. -- Jim in NC |
Removing RTV
Last time I had to remove the high-temp stuff from the threads of SS
bolts in a boat motor, my Dad (an A&P for 35 years) made me use leaded MOGAS. That was in 1979. That loosened everything up, but I still wound up peeling most of it off of the bolt threads, and then hitting it with an SS wire toothbrush dipped in gas, followed by a red shop rag. Knowing what we know now regarding shop safety, I don't think I'd go that route again unless nothing else worked. And then, I'd be extremely careful. Gasoline has some very nasty properties when it comes to vapor pressures and flamibility. Maybe just a soak in a small amount of gas poured into a coffee can, placed squarely in the middle of my vegetation-free back yard, followed by a rinse in something less flamible. Harry |
Removing RTV
wright1902glider wrote: Last time I had to remove the high-temp stuff from the threads of SS bolts in a boat motor, my Dad (an A&P for 35 years) made me use leaded MOGAS. That was in 1979. That loosened everything up, but I still wound up peeling most of it off of the bolt threads, and then hitting it with an SS wire toothbrush dipped in gas, followed by a red shop rag. My dad must have known your dad. A rag soaked (dripping wet) in about 3/4 motor oil and 1/4 gasoline laid on the RTV for a day. That made the RTV swell up and get very weak, then mechanically removed with whatever was handy. I got that lesson in 1981. |
Similar Threads | ||||
Favorite technique for removing rusted screws?? | Michael Horowitz | Home Built | 16 | October 4th 06 11:18 AM |
Removing Ethanol from Gas? | Jay Honeck | Piloting | 67 | August 16th 06 03:29 PM |
Removing old antennas | Jay Honeck | Owning | 30 | March 21st 04 04:34 PM |
Removing Old Contest Numbers | Milan Air | Soaring | 5 | November 25th 03 12:59 AM |
F-14 squadrons removing refueling cover plate? | dave999 | Military Aviation | 7 | August 6th 03 09:45 AM |
