Another E glider concept
Old September 25th 20, 09:01 AM posted to rec.aviation.soaring
Paul T[_4_]
Default Why bother with a GP15?
https://youtu.be/vcPCLPyXOYE
  #62
Old September 25th 20, 02:46 PM posted to rec.aviation.soaring
Pat Russell[_2_]
Why are they flying LY registered aircraft in Slovenia?
  #63
Old September 25th 20, 03:07 PM posted to rec.aviation.soaring
krasw
Did you read the video description?
  #64
Old September 25th 20, 04:25 PM posted to rec.aviation.soaring
kinsell
Notice how much the tail is bouncing even on a golf course quality grass
runway? One good bounce and goodbye prop and motor.
  #65
Old October 9th 20, 03:44 PM posted to rec.aviation.soaring
Adrian Morgan
Default LX5000/Flarm Red box
I have an LX 5000, which I want to interface with a Red Box Flarm.
The LX has four ports (five including the vario display connection)
labelled:
1. Power (wired to battery main switch)
2. Hold (wired to flip switch. No idea what it does!)
3. DataComm (a previous owner had "hot wired" two of its leads into a
Garmin LX12 cable. No Garmin now fitted)
4. Meter ( RJ 12 6 pin phone type port. Not connected.)
The LX presumably has a built in GPS, but needs an aerial.
The LX is not finding a GPS fix, as there is no aerial. I assume the
Garmin
had been used to give the LX data via the DataComm hot wires.
Now, with no Garmin, I assume the Flarm GPS aerial could do the job.
Question, how to wire it all up. Must be simple for anyone other than an
electronic imbecile like myself.
  #66
Old October 9th 20, 03:54 PM posted to rec.aviation.soaring
kinsell
Why are so many topics getting threaded under "Another E glider
concept"? Happens both on my newsreader, as well as when just viewing
R.A.S. on Google.
labelled:
Garmin
  #67
Old October 9th 20, 06:40 PM posted to rec.aviation.soaring
B BRIONES
R.A.S. on Google.
labelled:
Garmin
here's another Not an e-glider but a fossil burning, screaming jet engine, glider looking but short winged--
https://www.desertaerospace.com/extreme-light-jet--xlj-
  #68
Old October 10th 20, 03:32 AM posted to rec.aviation.soaring
That was an early concept for a personal jet airplane modelled on a glider type fuselage with a wing designed for the flight characteristics envisioned. It was to use a PBS TJ-100 engine like the one Bob was using on his airshow Salto glider (www.vertigoairshows.com) and the two-seat retractable engine TsT-14 BonusJet glider (as well as the four jet powered Arcuses built by Desert Aerospace.)
The design was superseded by the jet powered SubSonex from Sonex Aircraft. About a dozen or more are flying today, with probably 20 more kits in progress. https://en.wikipedia.org/wiki/Sonex_Aircraft_SubSonex
The XLJ (Extreme Light Jet) concept may be revisited in the future by Desert Aerospace if time permits.
  #69
Old October 10th 20, 03:45 AM posted to rec.aviation.soaring
B BRIONES
The design was superseded by the jet powered SubSonex from Sonex Aircraft.. About a dozen or more are flying today, with probably 20 more kits in progress. https://en.wikipedia.org/wiki/Sonex_Aircraft_SubSonex
The XLJ (Extreme Light Jet) really looks good though--
  #70
Old October 10th 20, 04:00 AM posted to rec.aviation.soaring
2G
R.A.S. on Google.
labelled:
Garmin
That doesn't even rise to the level of a concept - more like wishful thinking.
Tom
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [4/5] - "Eclipse Concept Jet 4.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [3/5] - "Eclipse Concept Jet 3.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [2/5] - "Eclipse Concept Jet 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (0/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
