These symptoms, and a little common sense as to the sorts of errors an
installer might make, suggest that the ground connection for the gauge is not connected to the airframe ground but rather to the power source for the internal lighting. When the internal lighting is turned off or is set to max dim, the source voltage is very near ground potential, so the gauge works properly. At high or intermediate brightness settings the source voltage is closer to the power bus (battery +) voltage, so the voltage across the gauge is insufficient to allow it to work properly. This should be easy to check with a simple voltmeter, or even an ohmmeter -Elliott Drucker |
Similar Threads | ||||
Cherokee ammeter revisted | Leo | Owning | 3 | January 15th 05 12:14 AM |
CHEROKEE NATIONAL FLY-IN - MORE INFORMATION | Don | Piloting | 0 | June 16th 04 05:15 AM |
CHEROKEE NATIONAL FLY-IN & CONVENTION - THIS MONTH! | Don | Owning | 0 | June 3rd 04 05:03 AM |
Cherokee National Fly-In & Convention | Don | Owning | 0 | May 5th 04 08:13 PM |
Cherokee National Fly-In & Convention | Don | Owning | 0 | March 20th 04 02:17 AM |
