My weird sink drain
Old April 13th 06, 04:59 AM posted to rec.aviation.piloting
Default My weird sink drain
".Blueskies." wrote in news:aDe%f.1290
"Skywise" wrote in message
AES wrote in news:siegman-11B9F7.19492611042006
@news.stanford.edu:
This is totally OT for this group -- except the group contains a lot of
obviously clever people who are professionally interested in aerodynamic
and fluid flows and pressures, pipes, valves, and the like, and maybe
someone will be entertained by the following odd bathroom sink behavio
Snipola of rest
You filled the pipe to the point it starts acting as a siphon.
I've seen my shower do it. I'm on the second level. I have one of
them 'water saver' heads so you know the flow is slow. I get about
an inch of water in the tub anyway. After several minutes, it
starts draining and stays that way.
Brian
Shouldn't make a siphon because you have a vent stack on it, right?
Yes, there is. Perhaps there's a clog somewhere. Bird nest?
Brian
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html
Sed quis custodiet ipsos Custodes?
Old April 13th 06, 10:17 AM posted to rec.aviation.piloting
On Tue, 11 Apr 2006 19:49:26 -0700, AES wrote:
At the last second turn the faucet part way off -- down to roughly 50%
of full flow, more or less -- then trim the flow until inflow rate just
equals outflow, so the water level stays just 1/4 inch or so below the
rim. Then leave it in this steady-state condition, and wait.
I think you need a hobby.
Might I suggest reading In Search of Lost Time? It has saved many
individuals who despaired of ever finding meaning in life.
(I recommend the new "Penguin Proust" translation.)
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
Quick drain mess. dlevy Owning 10 October 17th 05 01:55 AM
Spider in Archer Sump Drain Bob Chilcoat Owning 3 June 29th 05 10:29 PM
Rounding a turnpoint in sink CV Soaring 13 July 22nd 04 05:27 PM
sump drain cleaning Mike Noel Owning 15 August 15th 03 02:41 AM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 08:52 PM
