"Corky Scott" wrote in message ... On 20 Dec 2003 20:24:36 GMT, QQQQQQQ (DarylG1532) wrote: Since Motorcycle engines are air cooled, and you can install a fairly lightweight belt reduction drive, why aren't more rice burners being used in UL's? Well for one thing, installing a lightweight PSRU isn't as easy as you imply. Almost all the engines come with an integral transmission case which isn't needed. In order to utilize the engine efficiently, it has to be cut off somehow. It might be be easier to start with a crank case machined for your use and install the crank and cylinder heads in that. Then there's the horsepower, it comes at what, 8,9 or 10,000 rpm? Do you really want an engine that has to rev up that high in order to produce the necessary power, regardless whether it can do it for very long or not? Will the neighbors begin tracking you for skeet shooting? Corky Scott What about the BMW bike engines? They deliver max power at around 6500rpm, are proven to be very reliable when converted for a/c use, are dead simple to convert as the gearbox is seperate and give useful amounts of power for a reasonable weight (typically around 70hp for about 155lbs installed weight). I've converted one very succesfully, using a dead simple adapter and a Rotax C type gearbox, as have many others that I know of. Jeremy SALISBURY UK |
Similar Threads | ||||
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
