Solenoid valve for creating a tail ballast dump system...Lak17a
Old March 28th 11, 02:48 PM posted to rec.aviation.soaring
Sean Fidler
Default Solenoid valve for creating a tail ballast dump system...Lak17a
I need advise or recommendations on what solenoid valve's (type, model) would work best for creating a tail ballast dump mechanism. My glider, unfortunately, did not come with a mechanical release. My glider is in the shop getting an evacuation vent and break away tail wheel so the time is right to do this. As part of the current project we are removing the tail battery and adding lead in the boom to reduce the chances of a tail break in a ground loop. We can also easily use the tail battery wiring to power the solenoid switch.
Anyone have any experience or info to help me? Thanks in advance. I need to buy a valve today or tomorrow so pace is key!
Sean Fidler
Lak17a F2
248 977 7911
Old March 28th 11, 05:27 PM posted to rec.aviation.soaring
On Mar 28, 9:48*am, Sean Fidler wrote:
I need advise or recommendations on what solenoid valve's (type, model) would work best for creating a tail ballast dump mechanism. *My glider, unfortunately, did not come with a mechanical release. *My glider is in the shop getting an evacuation vent and break away tail wheel so the time is right to do this. *As part of the current project we are removing the tail battery and adding lead in the boom to reduce the chances of a tail break in a ground loop. *We can also easily use the tail battery wiring to power the solenoid switch.
Anyone have any experience or info to help me? *Thanks in advance. *I need to buy a valve today or tomorrow so pace is key!
Sean Fidler
Lak17a F2
248 977 7911
You may want to consider mechanical solution for valve. The bits used
by S-H would do nicely and it is a proven system.
Dead batteries lead to no dump.
When doing tail wheel, leave a way to inspect the bottom bulkhead area
of the tail tank. That is the first thing to get damaged in a ground
loop. It won't show from the outside, but the water leaking out will
make you want to inspect. You don't want to know how I know all this.
Take your time to do what you need long term.
FWIW
UH
Old March 28th 11, 05:33 PM posted to rec.aviation.soaring
Gary Evans[_2_]
Sean Fidler
Lak17a F2
248 977 7911
If you have 12 or 24 volts available this SS and vitron solenoid valve
would work.
http://www.aircraftspruce.com/search/search.php
Old March 28th 11, 08:51 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
Sean Fidler
Lak17a F2
248 977 7911
would work.
Keep in mind that especially for a tail water tank it might be crucial
that you get the valve opened, even with a dead battery.
My ASW 24 has electric valves for the wing tanks. They are made up of an
mechanical valve that is operated by a servo motor as it is used in R/C
model aircraft. This servo operates at 5V, so even with a dead battery
you should have enough voltage to operate the servo.
Peter Scholz
ASW24 JE
Ballast dump time Discus J. Nieuwenhuize Soaring 7 April 27th 07 05:56 AM
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price valvetom Piloting 0 November 28th 06 02:25 AM
Dump valve for Ls4a Robert Harvey Soaring 0 November 20th 05 08:47 PM
Schemp Hirth water ballast dump valves tango4 Soaring 14 September 2nd 04 07:13 PM
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 11:02 AM
