#41
New Iraqi Airborne Strike Capability Spotted
On Oct 22, 11:55*am, frank wrote:
On Oct 22, 1:22*am, Mark Borgerson wrote: In article ab5f457c-92f8-4016-9d19-ef56508e44f0@ 79g2000hsk.googlegroups.com, says... On Oct 21, 5:42*pm, BlackBeard wrote: On Oct 21, 12:52*pm, Jack Linthicum wrote: On Oct 21, 3:10*pm, BlackBeard wrote: On Oct 21, 7:00*am, Mark Borgerson wrote: In article 9870b6e3-029a-4701-9405-6919ed5d2cd0 @s1g2000prg.googlegroups.com, says... On Oct 20, 9:59*pm, Mark Borgerson wrote: In article , says... On Mon, 20 Oct 2008 13:59:09 -0700 (PDT), Jack Linthicum wrote: On Oct 20, 4:50*pm, Peter Skelton wrote: On Mon, 20 Oct 2008 13:42:34 -0700 (PDT), BlackBeard wrote: Thanks Jack and Dumpst. *That link worked. *I don't believe it can carry 12 passengers with all that equipment onboard.. *I worked on several projects where we loaded EO/IR sensors, trackers, and targeting equipment onboard similar platforms we were using as test beds. *Not much room left after all that gets shoehorned in. re. OV-10. *I have a friend that was a USN test jumper who jumped several times from the Bronco. *He claims they'd sit on the deck, nuts- to-butts facing aft. *The Bronco would go into a steep climb and they'd all slide out the back. *Crazy... If the maximum payload load is 3500 lb as Cessna says, 12 kitted soldiers are not going to fit. Peter Skelton specs for the Grand Caravan Super Cargomaster, listed at 14 passengers plus two crew. Something like 3700-3800 pounds of cargo/people Weights: Empty Weight 1,746kg Maximum Take-Off Weight 3,629kg Maximum Load 1,900kg Fuel Capacity 1,267l Ramp Weight (Grand Caravan, Super Cargomaster) 3,985kg http://www.aerospace-technology.com/...van/specs.html http://www.aerospace-technology.com/...van/specs.html Interesting. The Cessna website gives the maximum useful load number I gave above. The Brochure downloadable from the site gives 1862 kg. It also shows that, for a range of 100 nm, the maximum payload, exclusive of 170 lb pilot and 45 min fuel reserve is 1588 kg. to get 300 nm it's down to 1361 kg. http://www.cessna.com/MungoBlobs/746...n_Brochure.pdf 12 kitted soldiers is too much weight. The MC-5 and MP-360 canopies used by the Marine Corps Force Recon troops can easily handle 400 pounds. *They have been tested at weights up to 700 pounds. *I don't think they regularly jump anywhere near that weight, but 400 pounds divided between the Marine and his separately- suspended duffel is probably not uncommon. http://atairaerospace.com/onyx/ul/ (been there, wrote the software, but DIDN'T jump out of the airplane----I'm a 62-year old ex-squid, after all!) Mark Borgerson Test jump site looks like Marana... The test site with visible cactus, *known as "Area 52", *is about 15 miles East of Eloy, Arizona. * The dry lake bed is Red Lake, about 30 miles North of Kingman, Arizona. Mark Borgerson Thanks, I knew it had to be Az. but it didn't look like Yuma which was my first thought. *I didn't know about Area 52. *Who runs it? BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. http://www.lasvegasnow.com/Global/story.asp?S=7340352 Thanks Jack, I've been to Tonopah more than once. *I was referring to the site Mark mentioned in Az. BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. I used to have a cite for the location of all of the "areas". As I understand it Area 51 is now partially in Tooele Proving Ground. I remember---but can't find---a reference to some black aircraft programs moving to a site in Utah. *In any case, the area 52 to which I was referring is very much a local nickname. *On the Skydive Arizona web site they call it their own Area 51. http://skydiveaz.com/filmoffice.html Mark Borgerson I'd heard Area 12 as the new place to be. Part of the problem is its not just getting the airframe there (and if you're lucky its something you can load into a C-5 under a tarp) but all the support. You want telemetry, maintenance, security, it adds up fast. Janitors, toilet attendants. Though with the way technology advances, it makes as much sense to just start from scratch every decade. We were using an Atari to put flight test data up on the monitor. Started as a 'proof of concept'. Of course it worked, so nobody wanted to change it. Utah had test and training range (UTTR). I think Edwards had better TM and other data support. At least at the time, they were a step child. Though they did have better camera setups. Tonopah had best stuff for nuclear drops. Better operators. Probably better angles around drop site. Huge ****ing contest late 80s, Edwards wanted to get part of the action. Just couldn't follow release and keep cameras trained on the items. Eglin had their own specialties, mainly weapons as opposed to releases, all the aircraft specific tests. Uncle Sam sure does have the real estate tied up to move though.... My personal encounter with the U-2 was on the back road to the beach at Cubi Point, aircraft being unloaded from a 124, IIRC. |
#42
On Oct 22, 8:55*am, frank wrote:
On Oct 22, 1:22*am, Mark Borgerson wrote: In article ab5f457c-92f8-4016-9d19-ef56508e44f0@ 79g2000hsk.googlegroups.com, says... On Oct 21, 5:42*pm, BlackBeard wrote: On Oct 21, 12:52*pm, Jack Linthicum wrote: On Oct 21, 3:10*pm, BlackBeard wrote: On Oct 21, 7:00*am, Mark Borgerson wrote: In article 9870b6e3-029a-4701-9405-6919ed5d2cd0 @s1g2000prg.googlegroups.com, says... On Oct 20, 9:59*pm, Mark Borgerson wrote: In article , says... On Mon, 20 Oct 2008 13:59:09 -0700 (PDT), Jack Linthicum wrote: On Oct 20, 4:50*pm, Peter Skelton wrote: On Mon, 20 Oct 2008 13:42:34 -0700 (PDT), BlackBeard wrote: Thanks Jack and Dumpst. *That link worked. *I don't believe it can carry 12 passengers with all that equipment onboard.. *I worked on several projects where we loaded EO/IR sensors, trackers, and targeting equipment onboard similar platforms we were using as test beds. *Not much room left after all that gets shoehorned in. re. OV-10. *I have a friend that was a USN test jumper who jumped several times from the Bronco. *He claims they'd sit on the deck, nuts- to-butts facing aft. *The Bronco would go into a steep climb and they'd all slide out the back. *Crazy... If the maximum payload load is 3500 lb as Cessna says, 12 kitted soldiers are not going to fit. Peter Skelton specs for the Grand Caravan Super Cargomaster, listed at 14 passengers plus two crew. Something like 3700-3800 pounds of cargo/people Weights: Empty Weight 1,746kg Maximum Take-Off Weight 3,629kg Maximum Load 1,900kg Fuel Capacity 1,267l Ramp Weight (Grand Caravan, Super Cargomaster) 3,985kg http://www.aerospace-technology.com/...van/specs.html http://www.aerospace-technology.com/...van/specs.html Interesting. The Cessna website gives the maximum useful load number I gave above. The Brochure downloadable from the site gives 1862 kg. It also shows that, for a range of 100 nm, the maximum payload, exclusive of 170 lb pilot and 45 min fuel reserve is 1588 kg. to get 300 nm it's down to 1361 kg. http://www.cessna.com/MungoBlobs/746...n_Brochure.pdf 12 kitted soldiers is too much weight. The MC-5 and MP-360 canopies used by the Marine Corps Force Recon troops can easily handle 400 pounds. *They have been tested at weights up to 700 pounds. *I don't think they regularly jump anywhere near that weight, but 400 pounds divided between the Marine and his separately- suspended duffel is probably not uncommon. http://atairaerospace.com/onyx/ul/ (been there, wrote the software, but DIDN'T jump out of the airplane----I'm a 62-year old ex-squid, after all!) Mark Borgerson Test jump site looks like Marana... The test site with visible cactus, *known as "Area 52", *is about 15 miles East of Eloy, Arizona. * The dry lake bed is Red Lake, about 30 miles North of Kingman, Arizona. Mark Borgerson Thanks, I knew it had to be Az. but it didn't look like Yuma which was my first thought. *I didn't know about Area 52. *Who runs it? BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. http://www.lasvegasnow.com/Global/story.asp?S=7340352 Thanks Jack, I've been to Tonopah more than once. *I was referring to the site Mark mentioned in Az. BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. I used to have a cite for the location of all of the "areas". As I understand it Area 51 is now partially in Tooele Proving Ground. I remember---but can't find---a reference to some black aircraft programs moving to a site in Utah. *In any case, the area 52 to which I was referring is very much a local nickname. *On the Skydive Arizona web site they call it their own Area 51. http://skydiveaz.com/filmoffice.html Mark Borgerson I'd heard Area 12 as the new place to be. Part of the problem is its not just getting the airframe there (and if you're lucky its something you can load into a C-5 under a tarp) but all the support. You want telemetry, maintenance, security, it adds up fast. Janitors, toilet attendants. Though with the way technology advances, it makes as much sense to just start from scratch every decade. We were using an Atari to put flight test data up on the monitor. Started as a 'proof of concept'. Of course it worked, so nobody wanted to change it. Utah had test and training range (UTTR). I think Edwards had better TM and other data support. At least at the time, they were a step child. Though they did have better camera setups. Tonopah had best stuff for nuclear drops. Better operators. Probably better angles around drop site. Huge ****ing contest late 80s, Edwards wanted to get part of the action. Just couldn't follow release and keep cameras trained on the items. Eglin had their own specialties, mainly weapons as opposed to releases, all the aircraft specific tests. Uncle Sam sure does have the real estate tied up to move though.... And then there's China Lake... We have it all. BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. |
#43
And then there's China Lake... *We have it all. * BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. China Lake had some nice toys. Interesting what showed up there. We had A-7s, they used A-7s for drones for air to air work. There was quite a lot of under the table parts swapping going on. Their good tires for our bad tires to put on their drone they were going to shoot down anyway. Needed parts to keep things flying. Might have been some other incentives between the maintenance guys. Everybody flew when required so commands were happy. |
#44
On Oct 23, 11:05*am, frank wrote:
And then there's China Lake... *We have it all. * BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. China Lake had some nice toys. Interesting what showed up there. We had A-7s, they used A-7s for drones for air to air work. There was quite a lot of under the table parts swapping going on. Their good tires for our bad tires to put on their drone they were going to shoot down anyway. Needed parts to keep things flying. Might have been some other incentives between the maintenance guys. Everybody flew when required so commands were happy. My parents went to a tiny Kansas college, Southwestern, that seems to have furnished a lot of the early staff members for China Lake. I met them at the college's annual picnic in Southern California. In addition one of my father's YMCA club members became the basketball coach and then principle of Sherman Burroughs HS. Later I had contact with people from China Lake who wanted help from the FCC. I don't know if it is the desert air or just a tendency for hiring nice people but I never met a bad personality from China Lake. |
#45
On Oct 23, 8:15*am, Jack Linthicum
wrote: On Oct 23, 11:05*am, frank wrote: And then there's China Lake... *We have it all. * BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. China Lake had some nice toys. Interesting what showed up there. We had A-7s, they used A-7s for drones for air to air work. There was quite a lot of under the table parts swapping going on. Their good tires for our bad tires to put on their drone they were going to shoot down anyway. Needed parts to keep things flying. Might have been some other incentives between the maintenance guys. Everybody flew when required so commands were happy. My parents went to a tiny Kansas college, Southwestern, that seems to have furnished a lot of the early staff members for China Lake. I met them at the college's annual picnic in Southern California. In addition one of my father's YMCA club members became the basketball coach and then principle of Sherman Burroughs HS. Later I had contact with people from China Lake who wanted help from the FCC. I don't know if it is the desert air or just a tendency for hiring nice people but I never met a bad personality *from China Lake. You just got lucky It _is_ a bit like the show Eureka, there are so many S&E's and post-grad degrees in this town you can't swing a dead cat without knocking someone's pocket protector loose. There are several schools that seem to dominate the recruiting efforts. Rolla, MO. UT, and A&M have a strong presence. There's a generation of old timers that have recently retired that every third one was from New Mexico. The Physics Dept. used to have a strong showing from UofAz and Rochester. But Cal Poly seems to have the most consistent level of alumni working here, probably because of the proximity, reputation, and the fact that there are so many generations that work here. Kids graduate from the local HS and leave swearing they'll never come back to this terrible place. After a year or so of work once they've completed college/service a whole lot of them come back. A lot of them either come back to work on the base or teach in the schools. As for the personality thing I equate it to the Submarine service. When you live in a harsh, isolated environment, you learn to work with and depend on each other. It develops the skills that make good neighbors. I also think it's hard to survive such a place if you don't have a sense of humor. A lot of people are like me in that we came here figuring we'd put up with it for a few years and then move on to greener pastures. But between the interesting/rewarding work, great people, and small town atmosphere it seems like if you don't leave in your first 3 years, you stay forever. (Exceptions to every rule of course.) BB I guess everybody has some mountain to climb in their life. It's just fate whether you live in Kansas or Tibet. |
Similar Threads | ||||
Flying Car Spotted at TIW | C J Campbell[_1_] | Piloting | 9 | May 30th 07 03:30 PM |
APG-65/66/68/70 simultaneous track/attack capability | Bjørnar Bolsøy | Military Aviation | 0 | November 9th 03 12:15 AM |
Question on airplane's IFR capability | Slav Inger | Instrument Flight Rules | 10 | July 12th 03 03:48 PM |
New RAAF Air-To-Air Refuelling Capability | Errol Cavit | Military Aviation | 11 | July 2nd 03 06:43 AM |
