#41
Feds Want to Equipe Gliders With Transponders and Radios
On Apr 28, 3:18*am, WingFlaps wrote:
*I am sure that the nicely curved body of a high performance glass glider has a much lower radar cross section than any aluminium GA aircraft. It's not stealth but fiberglass is so transparent it's used for radomes. The RCS of glass gliders is quite large because of all the metal push rods. Tests with local radar (Luke Air Force base) showed no significant improvement in primary target return if a corner reflector was added. I have been easily tracked by approach control in my ASW19 and had them vector traffic round me as I climbed. They do have to want to see you though and, as others have pointed out, it's likely that the radar display will be set to filter out a slow moving primary target. Andy |
#42
Larry Dighera wrote:
radar energy as aluminum. The issue in equipping gliders with transponders, the way I see it, is the high power consumption required by transponders. Here's a typical glider transponder: http://www.airplanegear.com/becker.htm It seems to draw 175W to 250W. That's not insignificant, and way more than the comm radio consumes. Then there's the weight and antenna that reduce performance, not to mention the cost of the equipment, installation, and maintenance. You may have made a small mistake: 175 to 250 Watts is the pulse output power. In the same document, the current consumption is about a half ampere at 14 V, which is 7 Watts. -- Tauno Voipio (CPL(A), avionics engineer) tauno voipio (at) iki fi |
#43
On Apr 29, 5:51*am, Larry Dighera wrote:
I would guess the controller would need to adjust his scope from it's usual setting to see primary targets, so a radio call may be necessary. *While a corner reflector would doubtless increase the radar energy returned to the radar antenna and provide a brighter primary target, I doubt that would be sufficient to cause the glider so equipped to become visible on ATC's scopes without reconfiguring them to display slow-moving primary targets. How slow does a target need to be to be undisplayed -typically? I would have thought that even a glider is fast (45 knots) compared to usual clutter. Cheers |
#44
On Mon, 28 Apr 2008 19:20:20 GMT, Tauno Voipio
wrote in : Larry Dighera wrote: radar energy as aluminum. The issue in equipping gliders with transponders, the way I see it, is the high power consumption required by transponders. Here's a typical glider transponder: http://www.airplanegear.com/becker.htm It seems to draw 175W to 250W. That's not insignificant, and way more than the comm radio consumes. Then there's the weight and antenna that reduce performance, not to mention the cost of the equipment, installation, and maintenance. You may have made a small mistake: 175 to 250 Watts is the pulse output power. In the same document, the current consumption is about a half ampere at 14 V, which is 7 Watts. You are correct. Here's another with even less power consumption: http://www.sportflyingshop.com/Avion...ansponder.html Microair T2000 Transponder, $1,825 Wiring harness for T2000, $149 Ameri-King AK-350 Blind Encoder, $179 Power input: .25 amps @ 27.50 volts; .4 amps @ 13.75 volts TX, 80 mA RX I wonder if those power consumption figures include the heater in the encoder. Perhaps it's a good idea to require equipping all gliders with transponders after all. :-( |
#45
On Mon, 28 Apr 2008 12:49:07 -0700 (PDT), WingFlaps
wrote in : On Apr 29, 5:51*am, Larry Dighera wrote: I would guess the controller would need to adjust his scope from it's usual setting to see primary targets, so a radio call may be necessary. *While a corner reflector would doubtless increase the radar energy returned to the radar antenna and provide a brighter primary target, I doubt that would be sufficient to cause the glider so equipped to become visible on ATC's scopes without reconfiguring them to display slow-moving primary targets. How slow does a target need to be to be undisplayed -typically? I would have thought that even a glider is fast (45 knots) compared to usual clutter. I have no idea, but just assumed it was a tunable parameter. Perhaps one of the ATC folks among the readership of these newsgroups may offer some input on that subject. |
#46
On Apr 27, 7:26*am, Larry Dighera wrote:
If this is implemented, will it affect powered aircraft without electrical systems too? * Actually its more than gliders. They're talking about requiring that we carry a transponder on our boats too. There has also been talk from the TSA about having boat owners licensed and binding their license to their craft to ensure that the person is operating the boat he owns/ operates. -Robert |
#47
$1300 transponders?
Thanx Eric.. it's been a while since I checked.. I remember 13 but that may
have been the crappy Becker Radio. Had two.. both went back for repairs.. and I know at least one Becker Transponder had to go back too. BT "Eric Greenwell" wrote in message news:RIdRj.174$1m3.73@trndny02... BT wrote: Small transponders now are about $1300 plus antenna and installation. It can be done. That's a great price! Where do you get these? What brand? The ones I know about (Becker, Microair) are $1900 plus $200 for the encoder. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#48
"BT" wrote:
Technology is coming for the small transponder, along with ATS-B. Why would I put a 50# $15K ATS-B system in a $15K glider. I suspect that you mean "ADS-B Out" Reference: http://tinyurl.com/33k9m2 You will see responses from me. I am adamantly against it. Ron Lee |
#49
Larry.. it's been a few years since I've been on the ATC side of the radar..
but "we" had to monitor "primary" returns when working low altitude sectors, Below FL180. I've listened in on the local TRACON ATC frequency when flying in the "airline approach area" and yes, they are issuing "traffic, altitude unknown, could be a glider", and I did not call them first to give them a heads up. This has been in Grob 103s and LS-4, fiberglass with metal pushrod controls. Becker Transponders are very popular with glider pilots, I missed on the price.. it's closer to $1900 plus antenna and install. http://www.beckerusa.com/products/de...php?search=557 B "Larry Dighera" wrote in message ... On Sun, 27 Apr 2008 21:27:54 -0700, "BT" wrote in : Larry.. DO you fly gliders? Not in several years. From these statements it would appear that you do not. Gliders may or may not have electrical systems, they do not "generate power", but stored battery power of a limited life span. Gliders are small, batteries are small, everything needs to be small. None of the gliders I have flown have had electrical systems, small or otherwise. NTSB "recommends", FAA cannot mandate without a comment period and a change to many CFRs. True, but I'm thinking that it is in our best interest to provide some guidance to the FAA before they draft their NPRM; hopefully proactive will be better than reactive. Technology is coming for the small transponder, along with ATS-B. Are you able to provide any specific information about that technology? Why would I put a 50# $15K ATS-B system in a $15K glider. Of course, it's worse than that. There would need to be antennas, cabling, batteries, switches, circuit breakers, ammeter, ... It wouldn't be very cost effective to equip gliders used for training with all that, not to mention the resulting degraded flight performance and maintenance requirements. Small transponders now are about $1300 plus antenna and installation. It can be done. Can you provide more specific information about them? My issue is not with TCAS equipped aircraft, but with smaller GA aircraft that do not have TCAS, do not have a Garmin 430 with TIS (or equivalent) and are not talking to ATC. It does no good to have a transponder, when the aircraft causing the traffic conflict is not talking to anyone. Just sitting there FDH and not even paying attention in the traffic pattern. I'm not sure if there is a solution to that issue short of having a control tower at _all_ fields. Have you got any ideas? Last Saturday we had at least 4 transient aircraft attempt to land at the airport with 15 to 20 knot tail winds, and against the flow of traffic. While not very smart, it's not a violation of regulations, is it? They could not even listen up to the radio to figure out the runway in use, or even look at a wind sock or a huge flag and see the 15knt winds and make up their own mind about the landing runway. I find the level of competence, diligence, and responsibility of some airmen to be disappointing, and it's not just the "hobby" pilots. One wonders how they manage to pass their biennial flight reviews. What makes you think a transponder in a glider would make any difference. |
#50
In rec.aviation.soaring WingFlaps wrote:
On Apr 29, 5:51?am, Larry Dighera wrote: I would guess the controller would need to adjust his scope from it's usual setting to see primary targets, so a radio call may be necessary. ?While a corner reflector would doubtless increase the radar energy returned to the radar antenna and provide a brighter primary target, I doubt that would be sufficient to cause the glider so equipped to become visible on ATC's scopes without reconfiguring them to display slow-moving primary targets. How slow does a target need to be to be undisplayed -typically? I would have thought that even a glider is fast (45 knots) compared to usual clutter. A cruising glider is likely to be faster than that. However, gliders climbing in a thermal are making tight little circles, and I believe this will look like a stationary target to the radar. Worse, a glider climbing in wave really will *be* stationary, as the glider will try not to move by matching airspeed to wind speed at altitude. I have heard stories of unintelligent GPS units deciding the airplane was parked and shutting themselves off in this situation. -- Michael Ash Rogue Amoeba Software |
Similar Threads | ||||
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
Cessna forced down by the Feds | C J Campbell | Piloting | 51 | February 8th 05 01:29 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
Transponders and Radios - USA | Ray Lovinggood | Soaring | 1 | February 27th 04 06:10 PM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
