Aerotow - Newsletter
In response to a request, I am going to send out newsletters regarding
aerotow safety and procedures. There are variations on the theme around the soaring community, and a discussion may help prevent accidents. Glider pilots, CFIs and tow pilots are invited to subscribe and perhaps send comments. The newsletter is free, and you can always opt to unsubscribe at any time. To subscribe: Go to www.eglider.org and click on the newsletter link on the right side of the home page. The first aero tow newsletter is about the high tow position, and is included below. I will not respond to comments in this newsgroup. * * * * * Aero Tow High Tow Takeoff When flying with visiting glider pilots, it is common for some to mention how low we teach and fly when in the high tow position. Apparently, some instructors and pilots are using a tow position considerably higher than they should. The obvious hazard of using a higher than normal high tow position, is the risk of raising the tail of the towplane, perhaps exceeding the limits of the towplane elevator authority. This is especially a hazard when close to the ground. Normally, the glider reaches flying speed before the tow plane. The glider pilot must keep the glider close to the ground while the towplane is accelerating to its takeoff speed. How close? Generally no higher than a few feet. Some instructors and text books suggest no higher than a person's height. A glider pilot should be able to keep the glider within 3 or 4 feet of the ground while the towplane is accelerating. Being extremely close to the ground is not necessary, and may risk contact with the runway surface, causing the glider to bounce, beginning a series of PIOs. Tom Knauff |
Here's a question to all: Should we train tow pilots to pull the release when gliders get too high and actually have them practice it regularly? If the tug driver has never actually let go of a glider on tow, he will probably not do it in time when he actually needs to. |
On Sep 5, 9:29*am, GARY BOGGS wrote:
Here's a question to all: Should we train tow pilots to pull the release when gliders get too high and actually have them practice it regularly? *If the tug driver has never actually let go of a glider on tow, he will probably not do it in time when he actually needs to. Yes. Once the elevator reaches the up-stop with the rope attached, the pilot has lost control of the tug. The tug release must be pulled while the pilot is still in control. Tug pilots aren't paid nearly enough to put their lives at risk by delaying release. Any glider pilot who has put the tug pilot in this position should "buy the rope" and deal with the consequences. As for "practicing it regularly", that would depend on a lot of things like where the glider would land, where the rope would fall and whether you can find it again. |
Should we teach glider pilots to release the tow line in extreme slack line situations instead of attempting a recovery? These are just questions for discussion. |
Similar Threads | ||||
nice aerotow | [email protected] | Soaring | 3 | March 25th 09 04:37 PM |
Microlight aerotow....can it be done? | Microlight Pilot | Soaring | 6 | March 7th 07 11:22 PM |
Teaching the aerotow | Paul Moggach | Soaring | 5 | September 12th 05 03:31 AM |
Who said aerotow was expensive? | Nick Olson | Soaring | 1 | March 18th 05 05:23 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
