"Montblack" wrote in message ... ("tony roberts" wrote) snip Has anyone ever disposed of cremated remains from a light plane? How did you do it? All suggestions/ideas gratefully received. This is a wind up surely? |
Why would you think that? From the reading that I have done over the last couple of days, and from the responses posted here, it does not appear to be a unique event. -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument Cessna 172H C-GICE |
Last time this came up IIRC a good suggestion was.
Put ashes in paper bag. Carefully slit the bag w/razor knife to weaken the bottom. Tie shut w/a length of cord (12-15ft). Take aloft. secure end of cord to seat rail or whatever, throw bag out window. Bottom rips out at the end of the fall, drop done. Suggestion also mentioned adding glitter to ashes to aid in viewing from the ground. -- Kevin McCue KRYN '47 Luscombe 8E Rans S-17 (for sale) -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
tony roberts ) wrote:
: I appear to have volunteered for a task I know nothing about. : My friend who owns a Cherokee was approached by a neighbour who advised : him that his father was dying and has asked that his ashes be scattered : from an aircraft over a rural area near where I live. Others have posted ways to do this. Take a pair of eye protection goggles with you. I recomend the ones you find for use in chemistry classes that are completley sealed. You don't wany any of the ashes to blow back in your face. -tim http://web.abnormal.com |
"Tim Hogard" wrote in message ... tony roberts ) wrote: Others have posted ways to do this. Take a pair of eye protection goggles with you. I recomend the ones you find for use in chemistry classes that are completley sealed. You don't wany any of the ashes to blow back in your face. If doing this to finally get rid of a not so loved one - always on your case - and the ashes did blow back in your face, that person would always be up you nose, for the rest of your life.:-) -- --- Cheers, Jonathan Lowe. / don't bother me with insignificiant nonsence such as spelling, I don't care if it spelt properly / Sometimes I fly and sometimes I just dream about it. :-) -tim http://web.abnormal.com |
x-no-archive: yes
tony roberts wrote: I appear to have volunteered for a task I know nothing about. My friend who owns a Cherokee was approached by a neighbour who advised him that his father was dying and has asked that his ashes be scattered from an aircraft over a rural area near where I live. My friend volunteered, then thought that a high wing may do the job better, and asked me if I would do it in my 172 - in a weak moment I agreed. Throwing the sealed bag out of the window is an appealing option for its simplicity, but I doubt that next of kin or persons on terra firma would agree. An open bag, thrown out of the window may or may not empty on its way down - not reliable enough. Also I don't want the dear departed to hit the horizontal stab and take us with him. Tipping the contents of the bag out of the window would, I suspect, result in the contents siphoning back into the cockpit. A tube hanging out of the window, with a funnel at the top? That may create a venturi effect and cleanly suck the ashes out of the plane. Has anyone ever disposed of cremated remains from a light plane? How did you do it? All suggestions/ideas gratefully received. The best method I have seen was using a plane with an STC'd camera port in the floor. In this case it was a C-182. Some plumbing was constructed to make a tight fit over the port, and at the appropriate time a simple valve was opened. I believe Avweb or one of the similar publications had an article about this subject. |
Do a search in the rec.aviation newsgroups archive. It's been discussed
before, but it's been quite a while. I believe the tube and funnel method worked pretty well. I would think you'd want the tube long enough to get below the horizontal stab. I guess that ask can be pretty gritty and you don't want it in your hinges. A little duct tape and tubing and you're good. mike regish "Lynn Melrose" wrote in message ... x-no-archive: yes tony roberts wrote: I appear to have volunteered for a task I know nothing about. My friend who owns a Cherokee was approached by a neighbour who advised him that his father was dying and has asked that his ashes be scattered from an aircraft over a rural area near where I live. My friend volunteered, then thought that a high wing may do the job better, and asked me if I would do it in my 172 - in a weak moment I agreed. Throwing the sealed bag out of the window is an appealing option for its simplicity, but I doubt that next of kin or persons on terra firma would agree. An open bag, thrown out of the window may or may not empty on its way down - not reliable enough. Also I don't want the dear departed to hit the horizontal stab and take us with him. Tipping the contents of the bag out of the window would, I suspect, result in the contents siphoning back into the cockpit. A tube hanging out of the window, with a funnel at the top? That may create a venturi effect and cleanly suck the ashes out of the plane. Has anyone ever disposed of cremated remains from a light plane? How did you do it? All suggestions/ideas gratefully received. The best method I have seen was using a plane with an STC'd camera port in the floor. In this case it was a C-182. Some plumbing was constructed to make a tight fit over the port, and at the appropriate time a simple valve was opened. I believe Avweb or one of the similar publications had an article about this subject. |
tony roberts wrote in message news:nospam-A53B13.21060101122003@shawnews...
Has anyone ever disposed of cremated remains from a light plane? How did you do it? All suggestions/ideas gratefully received. I found this link: http://www.trailsendaerialdispersion.com/index.html Has anyone tried one of these? |
Similar Threads | ||||
Aviation Video: Another F-16 bites the dust | Iwan Bogels | Instrument Flight Rules | 0 | September 21st 04 07:02 AM |
Aviation Video: Another F-16 bites the dust | Iwan Bogels | Owning | 0 | September 21st 04 07:02 AM |
Russia & India to send joint manned mission to Moon | Michael Petukhov | Military Aviation | 84 | November 20th 03 11:04 PM |
FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 08:32 PM |
