AMS Flight Out of business
There seems to be problem to contact the company nowadays, they do not
answer phone or reply mails. Does anyone know does this company still exist? |
On Jun 8, 11:47*pm, Teme wrote:
There seems to be problem to contact the company nowadays, they do not answer phone or reply mails. Does anyone know does this company still exist? If AMS is not out of business they should be. I purchased a new DG-505 in 2006 from AMS. AMS supllied a certificate of airowrthiness for export to the United States in the standard category. As it turns out AMS was NOT certified to issue this document. As a result the FAA revoked the glider's standard airworthiness certificate when this was discovered in an FAA audit of AMS in 2008. Mr. Weber and Mr. Dirks at the DG factory sent a DG/LBA (German FAA) inspector to the United States (at my expense) to inspect the aircraft and issue a new more bone fide standard airworthiness for export to the United States. With this new documentation I argued the revocation in front of a National Tranportation Safety Board judge in Federal Court. The FAA prevailed on the grounds that the glider was fully consturcted in a country, Slovenia, with which the United States has no bilateral aviation agreements. As such the standard airowrthiness certificate remained revoked. In the court proceedings, which are a matter of public record, the FAA chief counsel elicited testimony from the FAA expert witnesses indicating that the FAA will be revoking all the standard airworthiness certificates of aircraft made by AMS because they were made in the country of Slovenia without direct DG supervision, a country with which the U.S. has no aviation export agreements. Let it be said that the aircraft supplied to me by AMS, my 5th glider, is as flawless and as perfect a glider aircraft as I have seen or owned. However, the paper work supplied by AMS is not worth the paper it is written on and has created a nightmare. I would suggest that other owners of AMS aircraft with standard airworthiness certificates contact an aviation attorney because the FAA will be coming after your glider next. neilgreen |
On Jun 13, 2:13*pm, NG wrote:
...As such the standard airowrthiness certificate remained revoked... I think I remember reading about this case a long time ago. Do you mean that the glider has still not been issued an airworthiness certificate? If so, I'm sorry to hear that. Also, can you describe how you came to purchase the glider from AMS and not from DG Flugzeugbau? I'm not sure I understand how AMS was entitled to sell to the public gliders that they ostensibly made under license for DG. Thanks, Bob K. |
On Jun 13, 4:15*pm, Bob Kuykendall wrote:
On Jun 13, 2:13*pm, NG wrote: ...As such the standard airowrthiness certificate remained revoked... I think I remember reading about this case a long time ago. Do you mean that the glider has still not been issued an airworthiness certificate? If so, I'm sorry to hear that. Also, can you describe how you came to purchase the glider from AMS and not from DG Flugzeugbau? I'm not sure I understand how AMS was entitled to sell to the public gliders that they ostensibly made under license for DG. Thanks, Bob K. Bob I think AMS had a license to manufacture gliders from the old Glasser Dirks. I don't think that was just an agreement as a subcontractor (which might have been the case with Elan at one time) - i.e. they could sell the gliders themselves. I do not know if the new DG extended that license. But I suspect the terms around all this is part of the issue with the very frosty relationship between the new DG and AMS Flight. I think DG tried here to solve the problem with this USA based AMS build glider that was not their doing and this is an unfortunate NTSB ruling for some USA owners. Anybody else have any opinion if this only affects the AMS built DG-500, DG-505 models, all other AMS built gliders were experimental - right? You'd hope that the FAA would be liable here for continuing to grant USA registration to AMS manufactured DG gliders, oh one could wish... Darryl (ex owner of an AMS built DG-303 -- registered experimental). |
Bob and Daryl:
The glider remained without an airworthiness certificate in the United States. The glider could have been registered as experimental but of course this would devaluate it remarkably since it is a twin glider and has the capacity to be used in a commercial settings for rides for hire. It is my understanding that AMS continued to build the fuselage for the DG-1000 for an extended period of time although this is not now the case. AMS built the complete 500 series entirely at their factory in Slovenia except for the motor version which was built at the DG factory. As far as I know the DG-300 series were all built at AMS but all of them were experimental and never type certified in the United States. Prior to purchasing the glider directly from AMS I contacted my local FSDO. I was told that I would have no trouble getting a standard airworthiness certificate. I was also told by no less than the small aircraft directorate for gliders in Kansas City, that the build in Slovenia would not be a problem as long as the glider was sent to DG for inspection prior to import into the U.S. AMS omitted this last step, probably because of the frosty relationship between DG and AMS, thus starting the cascade of problems. As it turns out it did not matter to the court that the glider was subsequently inspected by DG, the court found that the build in Slovenia without DG supervision doomed the glider to never receiving a standard airworthiness certificate in the United States. So one moral of the story is if the FAA promises you anything be skeptical, even if it is in writing. And even if it is in writing don't expect that the federal court will allow it into evidence. At trial the FAA held to the position that the build by the AMS factory was not acceptable because the U.S. has no bilateral aviation safety agreement with Slovenia (so called BASA). However if one goes and reads the United States type certificate for the DG-500 series, G08CE Revision 2, the ONLY acceptable place and country of manufacture is stated as AMS Flight, d.o.o. in the country of Slovenia. So in effect the judge did not hold the FAA to its own type certificate and tacitly accepted the FAA's position that this was "just an error". I think you can appreciate the flavor of the trial. It is impossible to fight with the FAA when the NTSB federal court will not hold the FAA to their own type certificate. Neil |
Similar Threads | ||||
home business | littlefrank29 | Aviation Photos | 0 | January 13th 09 10:50 PM |
business jet | Aero Dana | Piloting | 12 | February 16th 06 10:18 PM |
Nice doing Business with you... | plasticguy | Soaring | 1 | June 10th 04 02:11 PM |
Survey: which business | Scott Benger | Owning | 17 | May 28th 04 10:23 PM |
How's Business in Flight Training? | Greg Esres | Piloting | 17 | May 28th 04 02:54 AM |
