Lockheed XF-104
https://en.wikipedia.org/wiki/Lockheed_XF-104
The Lockheed XF-104 was a single-engine, high-performance, supersonic interceptor prototype for a United States Air Force (USAF) series of lightweight and simple fighters. Only two aircraft were built; one aircraft was used primarily for aerodynamic research and the other served as an armament testbed, both aircraft being destroyed in accidents during testing. The XF-104s were forerunners of over 2,500 production Lockheed F-104 Starfighters. During the Korean War, USAF fighter pilots were outclassed by MiG-equipped Soviet pilots. Lockheed engineers, led by Kelly Johnson, designed and submitted a novel design to the Air Force, notable for its sleekness, particularly its thin wings and missile-shaped fuselage, as well as a novel pilot ejection system. Flight testing of the XF-104s began with the first flight in March 1954, encountering several problems, some of which were resolved; however, performance of the XF-104 proved better than estimates and despite both prototypes being lost through accidents, the USAF ordered 17 service-test/pre-production YF-104As. Production Starfighters proved popular, both with the USAF and internationally, serving with a number of countries, including Jordan, Turkey, and Japan. Clarence L. "Kelly" Johnson, chief engineer at Lockheed's Skunk Works, visited Korea in December 1951 and talked to fighter pilots about what sort of aircraft they wanted. At the time, U.S. Air Force pilots were confronting the MiG-15 "Fagot" in their North American F-86 Sabres, and many of the pilots felt that the MiGs were superior to the larger and more complex American design. The pilots requested a small and simple aircraft with excellent performance. One pilot in particular, Colonel Gabby Gabreski was quoted as saying; "I'd rather sight with a piece of chewing gum stuck on the windscreen" and told Johnson that radar "was a waste of time". On his return to the U.S., Johnson immediately started the design of just such an aircraft realising that an official requirement would soon be published. In March 1952, his team was assembled, and they sketched several different aircraft proposals, ranging from small designs at 8,000 lb (3.6 t), to fairly large ones at 50,000 lb (23 t). The L-246 as the design became known remained essentially identical to the "Model L-083 Starfighter" as eventually delivered. The design was presented to the Air Force in November 1952, who were interested enough to create a new proposal, inviting several companies to participate. Three additional designs were received: the Republic AP-55, an improved version of its prototype XF-91 Thunderceptor; the North American NA-212, which would eventually evolve into the F-107; and the Northrop N-102 Fang, a new General Electric J79-powered design. Although all were interesting, Lockheed had an insurmountable lead and was granted a development contract in March 1953. Test data from the earlier Lockheed X-7 unmanned ramjet/rocket program proved invaluable for aerodynamic research since the XF-104 would share the general design of the X-7's wing and tail. Experience gained from the Douglas X-3 Stiletto was also used in the design phase of the XF-104. Over 400 surplus instrumented artillery rockets were launched to test various airfoils and tail designs; from which the camera film and telemetry were recovered by parachute. The wooden mock-up was ready for inspection at the end of April, and work started on two prototypes late in May. The J79 engine was not yet ready, so both prototypes were instead designed to use the Wright J65, a licensed built version of the Armstrong Siddeley Sapphire. Construction of the first prototype XF-104 (US serial number 53-7786, Buzz number FG-786) began in summer 1953 at Lockheed's Burbank, California factory. This aircraft was powered by a non-afterburning Buick-built Wright J65-B-3 turbojet. The first prototype was completed by early 1954, and started flying in March. The total time from award of the contract to first flight was only one year, a very short time even then, and unheard of today, when 10–15 years is more typical. Construction of the second prototype (s/n 53-7787) proceeded at a slower pace. F-104 production Official approval of the XF-104 design led to a contract for 17 YF-104A service test aircraft and a production run of over 2,500 aircraft built both in the United States and under license worldwide. Visible changes from the XF-104 to production versions of the Starfighter include a longer fuselage (to accommodate the J79 engine and extra internal fuel) and a forward-retracting nose landing gear (except two-seat versions) to increase clearance for the downward-ejecting seat. A ventral fin for increased stability was added during the YF-104A test program. Inlet shock cones and a fuselage spine fairing between the canopy and fin that housed fuel piping were further added features. Production aircraft would also feature a redesigned fin structure using stainless steel spars to eliminate the flutter problem. Since the internal fuel capacity was low limiting the useful range of the aircraft, extra capacity was provided on later versions by lengthening the forward fuselage. The XF-104 had a radical wing design. Most supersonic jets use a swept or delta wing. This allows a reasonable balance between aerodynamic performance, lift, and internal space for fuel and equipment. However the most efficient shape for high-speed, supersonic flight had been found to be a small, straight, mid-mounted, trapezoidal wing of low aspect ratio and high wing loading. The wing was extremely thin, with a thickness-to-chord ratio of only 3.4%. The leading edges of the wing were so thin (0.016 in/0.41 mm) and so sharp that they presented a hazard to ground crews, and protective guards had to be installed during ground operations. The thinness of the wings meant that fuel tanks and landing gear had to be contained in the fuselage. The hydraulic actuators driving the ailerons were only one inch (25 mm) thick to fit into the available space and were known as Piccolo actuators because of their resemblance to this musical instrument. The wings had electrically driven leading and trailing edge flaps to increase lift at low speed. The XF-104 did not feature the Boundary Layer Control System of the production aircraft. Flight testing proved that performance estimates were accurate and that even when fitted with the low powered J65 engine, the XF-104 flew faster than the other Century Series fighters being developed at the time. The XF-104's ceiling at 60,000 ft (18,000 m) was 7,000 ft (2,100 m) higher than predicted, and it exceeded estimated speed and drag figures by two to three percent. It was noted however that the low thrust of the J65 engine did not enable the full performance potential of the type to be realized. During a later interview, Kelly Johnson was asked about his opinion on the aircraft, "Did it come up to my designs? In terms of performance, yes. In terms of engine, we went through a great many engine problems, not with the J65s but with the J79s." For his part in designing the F-104 airframe, Johnson was jointly awarded the Collier Trophy in 1958, sharing the honor with General Electric (engine) and the U.S. Air Force (Flight Records). Specifications (XF-104) General characteristics Crew: 1 Length: 49 ft 2 in (15 m) Wingspan: 21 ft 11 in (6.69 m) Height: 13 ft 6 in (4.1 m) Wing area: 196 ft² (18.21 m²) Airfoil: Bi-convex 3.36% Empty weight: 11,500 lb (5,216 kg) Loaded weight: 16,700 lb (7,575 kg) Max. takeoff weight: 15,700 lb (7,120 kg) Powerplant: 1 × Wright J65 turbojet Dry thrust: 7,800 lbf (34.70 kN) Thrust with afterburner: 10,300 lbf (45.82 kN) Performance Maximum speed: 1,151 kn (1,324 mph, 2,131 km/h) Stall speed: 139 kn (160 mph, 257 km/h) Range: 695 nmi (800 mi, 1,290 km) Service ceiling: 50,500 ft (15,500 m) Armament Guns: 1 × T171 Vulcan 20 mm (.79 in) cannon (XF-104 083-1002 only) * |
Similar Threads | ||||
Lockheed T-33 pics 2 [8/9] - U.S. Air Force Lockheed P-80A-1-LO Shooting Star.jpg (1/1) | Miloch | Aviation Photos | 0 | April 10th 18 10:09 AM |
Lockheed T-33 pics [7/9] - Gregory “Wired” Coyler pilots his Lockheed T-33.jpg (1/1) | Miloch | Aviation Photos | 0 | April 10th 18 10:07 AM |
Lockheed L-188 Electra pics 2 [06/12] - Lockheed-P-3-Orion-Interior.jpg (1/1) | Miloch | Aviation Photos | 0 | August 20th 17 03:04 PM |
Lockheed L-188 Electra pics 1 [02/12] - g-lofc-atlantic-airways-lockheed-l-188-electra_PlanespottersNet_306370.jpg (1/1) | Miloch | Aviation Photos | 0 | August 20th 17 03:02 PM |
Lockheed L-188 Electra pics 1 [01/12] - 162315-US-Navy-Lockheed-P-3-Orion_PlanespottersNet_264145.jpg (1/1) | Miloch | Aviation Photos | 0 | August 20th 17 03:02 PM |
