Colibri Ipaq problem!
Old March 2nd 05, 04:04 PM
JB
I had a similar problem with my Palm. Im my case was a matter of speed.
Instead of 19200, try 9600 or 4800.
I can't understand why, but the fact is it works well like this.
JB
I just installed a colibri and IpAQ system.
I'm running a ipaq 5550 w/ SeeYou Mobile
The colibri "knows" where it is(shows correct long/lat and altitude)
but when I turn the ipaq on, the colibri beeps and the lcd says "19200
connect "
At the same time SeeYou says "no GPS Data"
However "Connect Me" recognizes colibri
Has anyone had this problem?
How do you fix it?
Thanks
Devin Bargainnier
Old March 2nd 05, 04:06 PM
Jancsika
I'm not sure but suspect that file transfer could take longer in this
case. (but maybe it will use another setting for pc connection).
/Jancsika
keithw wrote:
Adjust the Baud rate from 19,200 to a lower setting , some units only
respond at 4800 .
keithw
Thanks that did it!
what are the disadvantages of the lower baud rate setting if any?
Thanks
Devin Bargainnier
Colibri problem Ian Cant Soaring 1 August 19th 04 07:30 AM
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 4th 03 11:45 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 06:02 PM
