#151
Nuther SR-22 crash/incident?
T o d d P a t t i s t wrote:
Matt Whiting wrote: I'm not familiar with the Blanik glider or its aerodynamics so I can't comment. Isn't that the subject we are discussing? - whether general aerodynamic principles are sufficiently well understood that we can not only predict what happens aerodynamically in the real world, but also use that prediction to determine whether we should disregard a pilot report that conflicts with our prediction? Sure, but you need to know the specifics of the aircraft in order to know which principles to apply. For example, a powered airplane at high angles of attack derives some lift from the propulsion system as the thrust is vectored downward from the horizontal. This can be a big factor for powered airplanes, but doesn't apply to gliders. That doesn't change the underlying aerodynamic principles, it just means you have to apply the appropriate principles. Matt |
#152
It's not the principles in question, it is one's understanding of them in the light of apparantly conflicting empirics. The difference between theory and practice is that in theory, there is no difference. In practice, there is. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#153
T o d d P a t t i s t wrote: What I said was that they entered via an "accelerated stall" and that they brought "the nose well above the horizon, while slipping ... holding that attitude then allowing speed to decay." The stick was full back and in one corner, with the rudder to the opposite side. They expected from the nose high attitude that the critical AOA would be exceeded as their initial upward path became a downward path (as speed decayed) and the attitude relative to the horizon remained unchanged. Not to split hairs, but... what you originally wrote was: "We decided to try an accelerated stall spin entry from a full slip, bringing the nose well above the horizon, while slipping with stick full back and left and full right rudder, holding that attitude then allowing speed to decay." A big difference in "...decided to try an accellerated stall spin entry..." and "...they entered via an "accelerated stall..." |
#154
Matt Whiting wrote: With the stick full back? I'd like to see that demonstration. Can be done in a Citabria. When I took my first acro lesson, this was one of the first maneuvers I was taught. Another was a "falling leaf", where the aircraft is fully stalled with the stick full aft and rudder is used to keep the nose "centered", thereby preventing a spin from developing. |
#155
T o d d P a t t i s t wrote: In this case, the stall entry was brought about by bringing the nose up very high at speed in an initial accelerated maneuver so that the unpowered aircraft was in a steady climb. Remember my use of the word "agressively"? You have to force the accellerated stall (that's why it is called "accellerated"!). Another name for an accellerated stall is a snap/flick roll. |
#156
john smith wrote:
In article , Matt Whiting wrote: With the stick full back? I'd like to see that demonstration. Can be done in a Citabria. When I took my first acro lesson, this was one of the first maneuvers I was taught. Another was a "falling leaf", where the aircraft is fully stalled with the stick full aft and rudder is used to keep the nose "centered", thereby preventing a spin from developing. I don't think that is what was claimed. The claim was going from full rudder one way to full rudder the opposite side without entering a spin. Then again, the original claim about entering a acclerated stall seemed to morph in later messages so I don't know about this claim. :-) Matt |
#157
Matt Whiting wrote: I don't think that is what was claimed. The claim was going from full rudder one way to full rudder the opposite side without entering a spin. That is correct. |
#158
On 2006-06-16, Matt Whiting wrote:
Then, I'd like to know which model airplane it is. You can always find odd exceptions, but if this is a Cessna single, then, yes, I think the pilot is full of it. :-) Think again! When I first got my Cessna 140, we tried all kinds of manoevres to see what was likely to bite and what was not. One of them was stalling in a maximum effort slip. All that happens is the plane shakes like a wet dog and develops a high sink rate. No spin. The yoke was all the way on its back stop and the rudder was to the floor. Note that something entirely different happens if you try this from a SKID rather than a slip. At least in the C140, we couldn't get it to spin from a slip whatever we tried (and the C140 has plenty enough elevator to properly stall the plane and to enter a spin from a skid). I suspect that the Blanik L13 (the only aircraft I have access to that is approved for spins) will do the same if I stall it in a slip - I'll have to try it and see what happens. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
#159
http://sr22shop.com
Peter Duniho wrote: "T o d d P a t t i s t" wrote in message ... But 80 knots isn't "at low speed". That's my point. I'm sure you will agree that whether 80 knots is close to stall or not depends strongly on airfoil, wing loading, etc. Yes, I agree that it does. However, there's no reason to believe that the SR22 is in that category. For the SR-22, given that it has a published stall of 59 knots w/flaps, I can't see how 80 knots could be anywhere near stall. It's obviously not. Not during a normal approach, that is. However, I've never flown an SR-22, and I've learned enough over the years to strongly temper my own theoretical aerodynamic musings whenever they conflict with a pilot report. Well, I *have* flown the SR20, which lands essentially the same (elevator forces might be slightly higher in the SR22 for a pilot who doesn't know how to use the trim). I found absolutely no tendency for it to be unresponsive to an increase in AOA during the approach and flare. More to the point, the person to whom I was responding also has NOT flown the SR22 (probably not an SR20 either). He's purely speculating, and in doing so inventing some pretty odd concepts of aerodynamics. Pete |
Similar Threads | ||||
'nuther question: highest TAS... | xerj | Piloting | 12 | October 19th 05 02:00 PM |
