5th year of living dangerously with LiFePo4 batteries
Old June 3rd 18, 06:20 AM posted to rec.aviation.soaring
jfitch
Default 5th year of living dangerously with LiFePo4 batteries
Got it at the beginning of the 2014 season, 12AH Starkpower. Last year I got the CBA battery tester. At the beginning of last year it tested at 11.908 AH (down to 11 V) at a 1.5A load. Just tested it again and got 11.820AH. My panel is drawing about 1.3A if I don't turn on the solar charger, so I'm limited to 9 hour flights. It would be 14 hours with the solar, but of course the sun is gone by then. Oh well.
I've had 12AH AGMs made by Panasonic and others last about 3 seasons at most, best to replace them after 2, and generally they would be below 11.5 volts by the end of the 6 hour day even in the first season.
Now I know I take my life into my hands every time I load the LFP into the glider, but I intend to continue taking the risk.
Old June 3rd 18, 01:48 PM posted to rec.aviation.soaring
krasw
Last week there was (to my knowledge) first case of LFPs catching fire in glider. Luckily the glider was close to airfield and landed immediately. Primary structures were not damaged but it was a matter of minute or two, and pilots considered using parachutes. I thought LFPs were pretty safe but now we know better.
Old June 3rd 18, 02:32 PM posted to rec.aviation.soaring
Renny[_2_]
Got it at the beginning of the 2014 season, 12AH Starkpower. Last year I got the CBA battery tester. At the beginning of last year it tested at 11..908 AH (down to 11 V) at a 1.5A load. Just tested it again and got 11.820AH. My panel is drawing about 1.3A if I don't turn on the solar charger, so I'm limited to 9 hour flights. It would be 14 hours with the solar, but of course the sun is gone by then. Oh well.
Interesting...I am very glad they landed safely. Can you tell us where this event occurred?
Old June 3rd 18, 02:50 PM posted to rec.aviation.soaring
kinsell
"We" know better? Be careful about including Jon in that, he's made
quite a career out of trying to convince people to use lithium.
Do people really think they're that foolproof? Are you guys not
familiar with Google and YouTube?
http://www.batteryvehiclesociety.org...pic.php?t=1825
Old June 3rd 18, 03:15 PM posted to rec.aviation.soaring
Dan Marotta
Just for balance, has there ever been an inflight fire with a lead-acid
battery?Â* I can't find an instance with a quick google search.
then. Oh well.
"We" know better?Â* Be careful about including Jon in that, he's made
Do people really think they're that foolproof?Â* Are you guys not
Dan, 5J
Old June 3rd 18, 03:48 PM posted to rec.aviation.soaring
jfitch
To correct the record, I have not "made a career out of convincing people" to do anything. I've reported my experience, and corrected errors of fact. You use what you like - my career is not furthered either way. In the same link you provided, is a further link to another electric car also burned to a crisp, but using LA batteries to do it.
Any battery of 10 AH size can start a nice fire. I can start a fire with a 1.5V D cell, it isn't hard.
I'd like to know more specifics about the incident krasw mentioned.
Old June 3rd 18, 04:18 PM posted to rec.aviation.soaring
Nick Kennedy
So is the problem of a fire caused by a dead short across the battery terminals?
Shouldn't a inline fuse coming off the positive terminal take care of any fire problem? I realize a wrench or something like it placed across the terminals would cause a massive short and possible fire, but lacking that, whats the problem?
Do these things spontaneously combust? I have two in my ship and want to know.
Old June 3rd 18, 04:29 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
I shorted two different batteries, by placing upside down on a metal plate.
The LiFEPO4 was a non event. The battery management shut down immediately.
On the other hand the Lead Acid got quite hot melted the case.
Richard
Old June 4th 18, 12:01 AM posted to rec.aviation.soaring
jfitch
Richard
There you go bringing real data into the discussion again.
I would like krasw to elaborate on the event, if he knows more. Anything that stores energy is potentially dangerous. The devil is in the details.
Old June 4th 18, 05:17 AM posted to rec.aviation.soaring
Frank Whiteley
then. Oh well.
LifePO4 batteries for motorgliders - are we there yet? Chris Soaring 13 January 9th 16 03:43 PM
LiFePO4 Batteries on sale. [email protected] Soaring 20 December 9th 15 05:34 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
