Hp-18 Glider: leaving it tied outside, not in trailer
Old September 21st 20, 06:00 PM posted to rec.aviation.soaring
Dan Goldman[_2_]
Default Hp-18 Glider: leaving it tied outside, not in trailer
Hello all,
Wonder if anyone has experience leaving a metal HP-18 glider tied down, out of the trailer.
Any damage to the wing foam ribs ? wing bonding issues ? Corrosion ?
Location is in the northeast USA.
Dan
Old September 21st 20, 06:13 PM posted to rec.aviation.soaring
Tango Eight
That entire glider is held together with epoxy, and the fuselage from the trailing edge to the nose is polyester matrix fiberglass. It is *not* a metal glider. I recommend that you keep it out of the weather.
I owned one for ten years. It wasn't hard to assemble, just more fiddly and time consuming than modern factory ships.
T8
On Monday, September 21, 2020 at 1:00:59 PM UTC-4, Dan Goldman wrote:
Hello all,
Dan
Old September 21st 20, 07:06 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
T8
Hello all,
Dan
My HP18 wings were aluminum bonded to foam ribs.
Richard
Old September 21st 20, 08:44 PM posted to rec.aviation.soaring
Brian[_1_]
T8
Hello all,
Dan
I agree it will do much better inside the trailer, and it only took me a few minutes longer to assemble my HP-16 than the Ls-6 or ASW-20 I regularly flew with. The extra time was just installing the turtledeck and the extra taping over the other planes.
The trick is to practice assembling and work on getting your trailer and rigging gear working well, just saving a minute or two and reducing the number of loose pieces helps a lot. Assembling my HP got a lot easier after I got rid of the wing spar trailer mounts (glider was held in the trailer by the special rollers that attached to the fuselage), Got Rid of the stand to hold the glider vertical while wings were installed after rolling it out of the trailer. I replaced these with the more standard fuselage cradle and ramp that extended out the back of the trailer. This got rid of 3 loose rigging pieces and removed the need for a send person for everything except attaching the wings.
Airspeed Horsa pics 3 [4/7] - Paratroops leaving an Airspeed Horsa Glider, a training aircraft.jpg (1/1) Miloch Aviation Photos 0 May 7th 19 03:33 PM
50 shades of grey glider, whose glider is that in the movie trailer SF Soaring 23 October 16th 14 05:10 AM
Elevator Tied Up or Tied Down? Waveguru Soaring 5 June 18th 14 06:48 AM
What are the forces on a tied down glider? Eric Greenwell Soaring 40 August 21st 08 05:39 AM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
