'Shorter field landings?
Old December 8th 14, 07:27 PM posted to rec.aviation.soaring
Graham Drinkell
Default 'Shorter field landings?
Having recently landed a Pilatus B4 'wheels up, on a wet grass runway
(without any physical damage to the a/c!). I noted the extremely short
ground run!
Could this be a useful option- if you have selected a slightly small
field for an out-landing (ie- leave the u/c up?)
Another scenario, perhaps if you find the glider rolling along at high
speed towards an obstacle, then retract the u/c! Expensive, but maybe less
painful?
Old December 8th 14, 07:51 PM posted to rec.aviation.soaring
Luke Szczepaniak
ground run!
painful?
There is not much room or material between you and the ground if you
leave the gear up, it is an easy way to get hurt on a hidden rock etc.
The general consensus is that the best option is to always land gear
down, this will help absorb the impact and transfer the load to the
airframe rather than your body.
YMMV
Luke
Old December 8th 14, 08:28 PM posted to rec.aviation.soaring
Graham Drinkell
ground run!
small
less
painful?
YMMV
Luke
Old December 8th 14, 08:29 PM posted to rec.aviation.soaring
Graham Drinkell
ground run!
small
less
painful?
YMMV
Luke
Old December 8th 14, 08:31 PM posted to rec.aviation.soaring
Graham Drinkell
ground run!
small
less
painful?
YMMV
Luke
Old December 8th 14, 09:13 PM posted to rec.aviation.soaring
ground run!
painful?
Herniated discs can be extremely painful particularly if pinching parts of the spinal cord leading to paresthesia. I recommend using the landing gear and the big bouncy thing attached to it.
Old December 8th 14, 10:11 PM posted to rec.aviation.soaring
ground run!
painful?
The landing gear is there to protect you. Use it for that purpose.
Gliders with decent brakes commonly stop faster on the gear than off the gear.
UH
(USA only) Managing 911 response to off field landings Jim Beckman[_2_] Soaring 8 August 11th 09 04:23 PM
Soft field landings - low wing vs high wing aircraft Justin Gombos Piloting 19 May 23rd 07 05:21 AM
Variations in soft field landings Maxwell Piloting 42 April 27th 07 05:12 PM
Short vs Soft Field Takeoff and Landings Ol Shy & Bashful Piloting 17 November 17th 06 10:32 PM
Rough Field Landings [email protected] Piloting 38 December 19th 04 01:42 PM
