#71
Some good news
On 10/25/2015 2:50 PM, Ventus_a wrote:
JS;910133 Wrote: Perhaps any male that has jumped with loose leg straps will not want to repeat the pain. You don't need to tighten them like the glider harness, though. Jim On Sunday, October 25, 2015 at 8:06:09 AM UTC-7, Jonathan St. Cloud wrote:- The instructions that came with my chute, a Butler, says not to snug the leg straps after sitting in the cockpit, leave them snug when standing. Any comments or experienced parachuter that can comment on this?- I can't comment on the pain involved with loose leg straps but a pilot in my club who baled out of a Discus CS in the last year was struck under the chin with the chest strap leaving quite a large contusion from ear to ear. The chest strap ended up on his forehead leaving one to ponder what may have been if he was knocked out or rendered insensible by the chest strap upon the chute opening Colin This is probably one of those arguments that can go on forever, but somewhen I got into soaring I read that if you could stand up straight wearing a fully buckled emergency chute harness, it wasn't tight enough, in the sense that if you later used it from a sitting position, you'd wish afterwards that you'd snugged all the straps up one last time *while* you were sitting. The one time I used an emergency (round) chute a long time ago, I can't remember if I snugged it up in the cockpit or not, but I DO remember the harness-matching, colorful, yellow and purple bruises on my upper torso and shoulders, including the buckles, afterward. I concluded my harness should've been tighter. And that was without counting to three. No major leg bruises or talking funny afterward... Bob W. |
#72
Some good news
At 03:02 26 October 2015, BobW wrote:
This is probably one of those arguments that can go on forever, but somewhen I got into soaring I read that if you could stand up straight wearing a fully buckled emergency chute harness, it wasn't tight enough, in the sense that if you later used it from a sitting position, you'd wish afterwards that you'd snugged all the straps up one last time *while* you were sitting. Some time ago I bought a Thomas Sports "pop top" parachute & picked it up directly from "Lofty" Thomas (very well known in UK army and civilian parachuting circles, over 1500 jumps) who also repeated the above advice that if you can stand up straight the leg straps are not tight enough. I asked his advice on jumping from a glider & remember the words even though it was 25 years ago. He said "As soon as you are clear pull the handle hard, dont bother with this 'one, two, three...splat' stuff. In fact (he said) if you are having serious troubles getting out and are in a hurry, as long as you can get your back clear and in the airsteam, just pull the handle, the drogue will deploy and the chute will pull you out, although you might break the odd bone in the process!. The risks of the chute tangling in the airframe are much less than the risk of getting out too low." I would imagine this may depend on chute design - his have strong coil spring that throws the drogue quite a way. Luckily I have never had to put this advice into practice, although I still wear a (newer) Thomas chute. I do worry as age creeps on about how easy or difficult it would be to exit a damaged glider, I just hope that in the event the adrenalin would give you the necessary strength! It's always very useful to hear first hand accounts of this so many thanks for posting experiences on here. |
#73
Some good news
Am Freitag, 23. Oktober 2015 17:09:28 UTC+2 schrieb Dan Marotta:
I guess our personal limits just differ from each other.* Of course I have experienced times when full deflection of the controls would not stop a rolling or pitching action, but I was never concerned about it because I kept my airspeed low enough that stall was more likely than damage.* Knowing how to recover from unusual attitudes and being comfortable with aerobatics may help here. Dan, 5J Dan, if you are spiraling with 80 kts in a rotor and one wing completely stalls, it's not about avoiding g-loads, it's about avoiding hitting the ground while you are in a fully deleveloped spin. Where I fly, rotors are very often below ridge level. And yes, I'm fairly well trained - and current - in full aerobatics. But fortunately, most rotors are just somewhat bumpy. |
#74
Some good news
I agree with what you say. The point I was trying to make is that I
will not get into an 80 kt spiral. I will handle the aircraft well before that can happen. All bets are off should I become immersed in IMC, however. Though rated, my glider is not equipped for IMC. The IMC part is unlikely where I fly due to the dryness of the air plus I have no further desire to go above 18,000' MSL any more (too cold, don'tcha know). I've been in rotor approaching extreme turbulence on both ends of the tow rope at approximately 11,000' while downwind of 14,000' peaks. It's a workout for sure. I also recall performing a near split-S in the rotor (intentionally) to definitively notch the barograph trace (back in the old days when cameras and barographs were the tools of the sport). BTW, I made two glider flights and about 10 tows that day and was the only pilot to achieve the altitude diamond. I've seen some pretty extreme winds in the Mt. Washington area and I'll bet you get stupendous wave. Perhaps your rotors are also more lively than those in the Rockies. I haven't experienced the Sierra wave yet, but it's on my list. On 10/26/2015 3:38 AM, Tango Whisky wrote: Am Freitag, 23. Oktober 2015 17:09:28 UTC+2 schrieb Dan Marotta: I guess our personal limits just differ from each other. Of course I have experienced times when full deflection of the controls would not stop a rolling or pitching action, but I was never concerned about it because I kept my airspeed low enough that stall was more likely than damage. Knowing how to recover from unusual attitudes and being comfortable with aerobatics may help here. Dan, 5J Dan, if you are spiraling with 80 kts in a rotor and one wing completely stalls, it's not about avoiding g-loads, it's about avoiding hitting the ground while you are in a fully deleveloped spin. Where I fly, rotors are very often below ridge level. And yes, I'm fairly well trained - and current - in full aerobatics. But fortunately, most rotors are just somewhat bumpy. -- Dan, 5J |
#75
Some good news
Dan,
I crouched once the canopy was already open and I was breathing cloud. The slow-motion would have looked like me standing up in my seat and jumping while pulling the cord. To get that position, I just kinda hoisted myself up and jumped. (actually the slow-motion would have looked like a polar bear in a snowstorm on a UHF black and white TV with no signal...but that is neither here nor there) Chris On Sunday, October 25, 2015 at 10:06:53 AM UTC-4, Dan Marotta wrote: Thanks, Chris. That's exactly the kind of information I was looking for!* I'll wait patiently for the full story when you're ready to release it. One question:* You mentioned crouching in the cockpit immediately prior to jumping.* I don't know how the seating is in an HP, but in my LAK, I'm sitting too low to get into a crouch.* I've found that, by putting my upper arms (just above the elbows) on the canopy rails, bringing one foot way back, and bracing my back against the seat back, I can raise my body enough that I can get the other leg over the canopy rail.* Then I can use that leg to assist in rolling over the side.* Note:* I'm 67 years old. Dan |
#76
Some good news
:-D
On 10/26/2015 12:27 PM, Christopher Giacomo wrote: Dan, I crouched once the canopy was already open and I was breathing cloud. The slow-motion would have looked like me standing up in my seat and jumping while pulling the cord. To get that position, I just kinda hoisted myself up and jumped. (actually the slow-motion would have looked like a polar bear in a snowstorm on a UHF black and white TV with no signal...but that is neither here nor there) Chris On Sunday, October 25, 2015 at 10:06:53 AM UTC-4, Dan Marotta wrote: Thanks, Chris. That's exactly the kind of information I was looking for! I'll wait patiently for the full story when you're ready to release it. One question: You mentioned crouching in the cockpit immediately prior to jumping. I don't know how the seating is in an HP, but in my LAK, I'm sitting too low to get into a crouch. I've found that, by putting my upper arms (just above the elbows) on the canopy rails, bringing one foot way back, and bracing my back against the seat back, I can raise my body enough that I can get the other leg over the canopy rail. Then I can use that leg to assist in rolling over the side. Note: I'm 67 years old. Dan -- Dan, 5J |
#77
Some good news
The below is what i received from Bulter Parachute regarding tightening the leg straps after sitting in the cockpit.
Hello Jonathan, It's always nice to hear from customers who take their emergency equipment serious enough to ask questions. It comes down to personal preference. Our Owner's Manual states: Tighten the leg straps until they are snug while standing erect... This adjustment will feel slightly looser after you sit in your aircraft; if desired, you may further tighten the leg straps after you are seated." Both methods will produce a fit that will be fine should you have to bailout. My personal preference is to snug the straps a little tighter after I am seat in the aircraft. A harness that is slightly tighter has no negative effects and will ensure that your harness is not too loose.. You will not fall out of a harness that is too loose, but one that is drastically too loose may cause the chest strap to contact the neck or chin on deployment. This can cause injury. You don't have to snug the straps to the point of discomfort or cutting off blood supply; just slightly tighter is fine and ensures your harness will be snug on deployment. Hope this helps. |
#78
Some good news
Thanks for all the responses. My ship has been pulled down from the mountain (excellent helicopter work flying it by the tail), and is off to salvage through USAIG.
For all documents, photos, and my personal thoughts/evaluation, please see https://drive.google.com/open?id=0B2...0QtVWI1V3pVYWM Chris |
#79
Some good news
Thanks for the detailed reporting, Chris. That provides so much to
think about. If I had any criticism at all it would only be that, in your shoes, I would have left the aircraft sooner once going into the clouds. But then I don't have the benefit of real time knowledge of your location, height AGL, descent rate, etc. Overall - Good Job! On 11/1/2015 7:57 PM, Christopher Giacomo wrote: Thanks for all the responses. My ship has been pulled down from the mountain (excellent helicopter work flying it by the tail), and is off to salvage through USAIG. For all documents, photos, and my personal thoughts/evaluation, please see https://drive.google.com/open?id=0B2...0QtVWI1V3pVYWM Chris -- Dan, 5J |
#80
Some good news
Am Montag, 2. November 2015 03:57:31 UTC+1 schrieb Christopher Giacomo:
Thanks for all the responses. My ship has been pulled down from the mountain (excellent helicopter work flying it by the tail), and is off to salvage through USAIG. For all documents, photos, and my personal thoughts/evaluation, please see https://drive.google.com/open?id=0B2...0QtVWI1V3pVYWM Chris Thanks for posting this. Although the event had ruined your day, there is a lot of benefit for others by learning and reflecting through your story. Bert Ventus cM TW |
Similar Threads | ||||
Good news and bad news about SPOT 2 devices | Frank[_12_] | Soaring | 6 | May 12th 10 06:43 AM |
The news is in. It's not good for the FAA | Mike | Instrument Flight Rules | 0 | June 23rd 09 08:16 PM |
Some good news | Jay Honeck | Piloting | 2 | June 22nd 07 05:44 PM |
(",) .............. Good News Everyone! .............. | [email protected] | Owning | 0 | January 26th 05 09:56 PM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
