Icom Boom Mike
Old September 24th 03, 02:40 PM
Kevin Neave
Default Icom Boom Mike
Icom used to sell a slim, sexy boom mike, about 2/3
the thickness of all the chunky ones that seem to be
readily available.
Anyone know if it's still in production?
If so where can I get one?
Or any alternatives ?
Most of the ones available from your typical pilot's
shop seem to be about 10mm diam, the Icom one as I
remember was about 6 or 7mm (That's the gooseneck bit
not the Mike!)
Cheers
Kevin
Old September 24th 03, 11:10 PM
Tim Newport-Peace
X-no-archive: yes
In article , Kevin Neave
k writes
readily available.
not the Mike!)
Cheers
Kevin
To the best of my knowledge it is no longer available if you are
referring to the IC-HS15.
Which model of ICOM are you trying to work to? The microphone
arrangements for the A3E/A22 are different from the legacy models
(A2/A20). The HS15 would work with the A2 or A20 but probably not to an
A3E or A22.
Tim Newport-Peace.
Specialist Systems Ltd. Tel: +44 (0) 1256 381465
Old September 25th 03, 09:39 AM
Kevin Neave
I'm actually using an Icom A20.
However if I can find a source for a slim gooseneck
I can change the Microphone insert to suit whatever
radio.
My problem is that the goosenecks that are readily
available seem much fatter than the Icom HS15 used
to be
if you are
microphone
legacy models
probably not to an
A3E or A22.
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Home Built 1 December 3rd 04 09:16 PM
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Piloting 1 December 3rd 04 09:16 PM
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Owning 0 December 3rd 04 08:25 PM
PA28-181 - Stuck Mike - King Silver Crown Roy Page Owning 2 October 29th 04 03:36 AM
Icom CM-35 Desktop Battery Charger for Icom IC-A2 Radio A. Kay Aviation Marketplace 0 August 23rd 03 08:01 AM
