2 gear up switches?
I have owned my glider for nearly 4 years and it seems that I still find new things out about it. Its a Ventus B and has a L-Nav flight computer that I use as a backup to my Oudie.
I went to test my gear up switch the other day and it didn't make any sound.. Now I always thought the gear up switch is part of my L-nav and recently I have been having some intermittent issues with my speed command graph and glide slope indicator not functioning properly. So I start looking for broken wires and I look behind the seat and see that there are two wires that are taped to a support and i see a switch with a thin wire that has two posts not connected to anything. Well I take the wires and attach then and voila the sound of a French police car is made when I actuate the airbrake with the gear up. Then I read my L-NAV manual again and it never refers to any switch with a tickle wire. it takes about sensing the speed for it to actuate and the last time I flew I put the air brakes on with the gear up to test and didn't hear anything. Could I have two alarms? Dennis |
2 gear up switches?
On Sunday, June 5, 2016 at 6:28:25 AM UTC-7, HGXC wrote:
I have owned my glider for nearly 4 years and it seems that I still find new things out about it. Its a Ventus B and has a L-Nav flight computer that I use as a backup to my Oudie. I went to test my gear up switch the other day and it didn't make any sound. Now I always thought the gear up switch is part of my L-nav and recently I have been having some intermittent issues with my speed command graph and glide slope indicator not functioning properly. So I start looking for broken wires and I look behind the seat and see that there are two wires that are taped to a support and i see a switch with a thin wire that has two posts not connected to anything. Well I take the wires and attach then and voila the sound of a French police car is made when I actuate the airbrake with the gear up. Then I read my L-NAV manual again and it never refers to any switch with a tickle wire. it takes about sensing the speed for it to actuate and the last time I flew I put the air brakes on with the gear up to test and didn't hear anything. Could I have two alarms? Dennis Believe in later versions there is a stall alarm which is speed dependent. Jim |
2 gear up switches?
What you describe sounds like a simple old-fashioned 2-switch system
(one at the gear lever in series with one at the airbrake lever and a buzzer) that warns you when you actuate the airbrakes on final with the gear up. Seems to me that it has nothing to do with your L-Nav... Okko Netherlands Op 5-6-2016 om 15:28 schreef HGXC: I have owned my glider for nearly 4 years and it seems that I still find new things out about it. Its a Ventus B and has a L-Nav flight computer that I use as a backup to my Oudie. I went to test my gear up switch the other day and it didn't make any sound. Now I always thought the gear up switch is part of my L-nav and recently I have been having some intermittent issues with my speed command graph and glide slope indicator not functioning properly. So I start looking for broken wires and I look behind the seat and see that there are two wires that are taped to a support and i see a switch with a thin wire that has two posts not connected to anything. Well I take the wires and attach then and voila the sound of a French police car is made when I actuate the airbrake with the gear up. Then I read my L-NAV manual again and it never refers to any switch with a tickle wire. it takes about sensing the speed for it to actuate and the last time I flew I put the air brakes on with the gear up to test and didn't hear anything. Could I have two alarms? Dennis |
Similar Threads | ||||
Breakers as Switches - Good Idea? | Six-Seven Romeo | Soaring | 18 | February 19th 16 07:51 PM |
Master Switches | K | Soaring | 52 | April 28th 13 12:11 AM |
Dual Trim Switches? | Christopher Brian Colohan | Piloting | 46 | October 7th 07 08:24 PM |
Gear Warning Switches on a Mosquito | scooter | Soaring | 6 | March 9th 05 01:15 PM |
Fading Rocker Switches | O. Sami Saydjari | Owning | 2 | February 16th 04 03:54 PM |
