Flarm unit performance to OGN Ground station issue.
Old August 18th 18, 09:25 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default Flarm unit performance to OGN Ground station issue.
On Saturday, August 18, 2018 at 12:15:06 PM UTC-7, kinsell wrote:
On 08/18/2018 09:33 AM, Richard Pfiffner wrote:
On Saturday, August 18, 2018 at 4:45:25 AM UTC-7, waremark wrote:
Isn't it supposed to transmit from both antennas with the current firmware?
PowerFlarm transmits and receives on Antenna A, receives on B and receives on ADS-B.
Richard
www.craggyaero.com
True for PowerFlarm. This is in New Zealand, presumably using Flarm
down there, and yes current firmware is supposed to transmit and receive
on both A and B.
Please direct me the Flarm Model the transmits on both A and B Antennas and the manual that specifies this.
Richard
Old August 18th 18, 10:09 PM posted to rec.aviation.soaring
Dave Watrous
Release notes for Flarm firmware version 6.40:
PowerFLARM: Fully symmetric antenna diversity, dynamic receive and transmit on
both antennas (except USA and Canada)
Old August 18th 18, 10:31 PM posted to rec.aviation.soaring
Darryl Ramm
Thank you very much to the FCC.
We need a new version of Eric Idle's FCC song addressing device approval: https://www.youtube.com/watch?v=9tn1QNxEoF4 (NSFW)
Old August 19th 18, 01:38 AM posted to rec.aviation.soaring
So much for being Great Again.
Richard
Old August 19th 18, 04:04 AM posted to rec.aviation.soaring
Paul Agnew
Richard
It takes time to reverse rules put into place by the previous administrations.
PA
Old August 19th 18, 02:42 PM posted to rec.aviation.soaring
Richard
PA
I looked into FCC certification of a Flarm Device and was amazed at the cost.
Around $25,000 per enclosure, if you passed the first time. That is why manufacturers have approached Flarm as an add on device.
Richard,
Old August 19th 18, 02:56 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
On Saturday, August 18, 2018 at 2:18:16 PM UTC+2, Glidingstuff wrote:
Hi Chris and Dan
Yes the coax is connected to the aircraft ground. The aerials are correctly connected. Both aerial outlets are activated in the unit and are used. The Flarm transmit and receive aerial is on the top of the aircraft and the receive only aerial is underneath on the starboard side just behind the firewall.
Cheers
Paul
Then I would try disconnecting it at the antenna end.
Old August 19th 18, 04:05 PM posted to rec.aviation.soaring
Benedict Smith
Paul,
No sign of your posting on the OGN forum, however a couple of
points occur to me,
The Flarm is probably faulty if the frequency is that unstable, I
have seen units where the frequency offset has been close to
unacceptable, but they don’t normally change much in use, as a
workaround you could ask the owner of the ground station to
increase the bandwidth that they receive on, this has the
downside of higher cpu load and greater noise but will pick up off-
frequency units better (perhaps set the demodulator ScanMargin
to around 20 or 25)
But in the long term you will probably need to get the Flarm unit
checked by the manufacturer as it doesn’t look right to me.
Ben. (U.K. OGN station Aldersht2)
At 01:17 18 August 2018, Glidingstuff wrote:
Thanks for the quick reply Dan.
Have you updated the FLARM to the latest firmware (6.60)?
Yes. Both units are running 6.60
What kind of coax did you use to connect the antennae to the
FLARM and
how long are the runs?
Aviation quality and about three meters
Have you tried a factory reset of the FLARM?
Yes. Its just back from being reset. But they admit they didn't
check the
freq performance.
Does the towplane have a metal tint on the plexiglass
windscreen?
No
I haven't ever seen the frequency offset move that quickly.
We had a FLARM CORE in the club which went for repair and
the transmit
section was replaced; it could only be seen for 100m or so. Now,
range like
all the others (OGN ranges of greater than 40 km).
A great resource is the forum for the OGN; it is at
https://groups.google.com/forum/#!fo...nglidernetwork .
Details on
joining it are at http://wiki.glidernet.org/contact .
Cheers
Dan
I have sent the above data to the OGN people but no reply from
them as yet
either.
Paul
Old August 19th 18, 06:56 PM posted to rec.aviation.soaring
Charlie Quebec
Never was great, never will be.
Continental PE-150 Ground Power Unit 150HP For Sale [email protected] Aviation Marketplace 1 August 9th 20 09:45 PM
Gloster Gladiator pics 2 [06/11] - Legionnaires_guards_gladiators landing ground at H4 pumping station in Transjordan.jpg (1/1) Miloch Aviation Photos 1 March 22nd 18 11:08 AM
Continental PE-150 Ground Power Unit 150HP For Sale [email protected] Aviation Marketplace 0 August 29th 17 01:24 AM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
FAA Awards $1.8 BILLION ADS-B Ground Station Contract Larry Dighera Piloting 27 October 4th 07 04:07 PM
