EJECT!
Thunderbird F-16 cockpit video of ejection at Mountain Home AFB crash.
http://www.razorsedgesoft.com/eject.mpg |
Dean Wilkinson wrote:
Thunderbird F-16 cockpit video of ejection at Mountain Home AFB crash. http://www.razorsedgesoft.com/eject.mpg WOW! |
He was really close to the ground when he bailed out. Is there a minimum
altitude to eject? Doesn't look like it. I guess it is better to nurse some broken bones then die in the wreckage. Thanks. Jon Kraus PP-ASEL Student-IA Dean Wilkinson wrote: Thunderbird F-16 cockpit video of ejection at Mountain Home AFB crash. http://www.razorsedgesoft.com/eject.mpg |
In article , Jon Kraus wrote:
He was really close to the ground when he bailed out. Is there a minimum altitude to eject? Doesn't look like it. I guess it is better to nurse some broken bones then die in the wreckage. Thanks. I believe the modern Martin-Baker ejector seats are 'zero zero' capable (i.e. you can eject at zero feet, zero airspeed) and have been for some time. Minor name dropping: the Ronaldsway Aircraft Company, just 5 miles from where I live, makes these for MB. They have some amazing pictures on their walls inside the plant. My favorite is the one which (from the photographer's point of view) must have been the result of serendipity: a nicely framed (photography wise, not what it's mounted in!) picture of a man on a tractor, looking around behind him in awe. He's looking around in awe becase an English Electric Lightning (50s era twin jet interceptor) is pointing _straight down_, maybe at 300 feet or so, with the gear down, and the pilot ejecting, his parachute just starting to open. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
any more background info available?
regards wolfgang, loww, vie, austria |
Actually, the seat in the F-16 is an Aces II, not a Martin Maker. While it
is zero-zero, this does not count for a downward flight vector. As I recall, the parameters for insuring a good chute are around 2000 feet agl in controlled flight, and 8-10,000 feet in uncontrolled flight. Also, the most common cause of fatal accidents is due to delayed ejection. I have around 60 hours in the back of F-16's as a flight surgeon, and our recurrent training always emphasized these numbers. |
"Jon Kraus" wrote in message ... He was really close to the ground when he bailed out. Is there a minimum altitude to eject? Doesn't look like it. I guess it is better to nurse some broken bones then die in the wreckage. Thanks. Most modern seats, are 'zero zero' rated. This means you can eject at zero feet, and zero mph. However this is degraded when you are descending fast. What amazes me more, is how low some designs will allow you to eject inverted!... Some now have an 'any atitude' ejection ability once you are in excess of a couple of thousand feet. Given the speeds you could be doing, and the different directions possible, this is really scarey. Best Wishes Jon Kraus PP-ASEL Student-IA Dean Wilkinson wrote: Thunderbird F-16 cockpit video of ejection at Mountain Home AFB crash. http://www.razorsedgesoft.com/eject.mpg |
IIRC... the Mig-29 crash at the Paris Airshow, years back, the crew ejected with the aircraft 90-or-more degrees to the horizon. The seats blasted down and out initially and flew to a vertically upright position before releasing the crew. |
Jon,
Aircraft with ejection seats have an "ejection envelope" that is defined by speed, altitude, rate of descent and attitude of the aircraft. The very first ejection seats had to be fired at something on the order of 5,000 feet AGL, with no descent rate and a pretty much level attitude. Some were really odd, such as the initial design of the F-104, which fired the pilot downward and killed the greatest test pilot in U.S. history, Ivan Kinchloe (the Society of Experimental Test Pilots named its top award after him), when he had to eject shortly after takeoff...he tried to roll inverted before doing so but did not have the time. The zero/zero seats will allow ejection from an airplane sitting on the ground (there is a film of an early Martin Baker seat sitting in an English meadow, a man dressed in top hat and tails sits down, straps in and pulls the handles...pow...the chute opens, he lands, rolls, stands up and walks off, minus top hat). The Russians developed a seat that would turn and go up even if the aircraft were in an attitude in which the pilot was fired on a downward trajectory initially, and proved its worth in a stunning ejection at the Paris Air Show several years back. Even with the best seat, if the aircraft is low and still descending rapidly, the ejection may not be a success. All the best, Rick Jon Kraus wrote in message ... He was really close to the ground when he bailed out. Is there a minimum altitude to eject? Doesn't look like it. I guess it is better to nurse some broken bones then die in the wreckage. Thanks. Jon Kraus PP-ASEL Student-IA Dean Wilkinson wrote: Thunderbird F-16 cockpit video of ejection at Mountain Home AFB crash. http://www.razorsedgesoft.com/eject.mpg |
Hi Wolfgang,
I don't remember correctly. It came on German TV yesterday evening. If I am right was somewhere in the US on an air show back in November. It was kept secret by the US government until yesterday, they said in the TV. Best Regards Ralf "Wolfgang K." schrieb im Newsbeitrag ... any more background info available? regards wolfgang, loww, vie, austria |
