PA-28-140D Fluctuating RPM indicator
I purchased a 1971 Cherokee 140 shortly after getting back into flying the
first of this year. It is a marvelous plane, relatively inexpensive to fly and to maintain. The other night while flying with my instructor he asked me if I typically got this much vibration. I told him that it felt normal, however when I looked at the GPS on the steering column it was vibrating so much I couldn't read it. All indicators were normal, the engine sounded fine, the one exception was the RPM indicator was moving back and forth a couple of hundred RPM from the 2500 I had it set at. I haven't had a chance to fly again and my mechanic is on vacation until tomorrow. Any thoughts or ideas? Charles Graef |
I would open up the cowlings and look over the engine very thoroughly for
any obvious problems (cylinder cracks, loose spark plugs, loose spark plug wires etc.) then pull all of the plugs, make sure they are all in good shape, clean and gap them and swap the bottom and top plugs if they all appear serviceable. Be sure to torque to the correct specification when reinstalling them (it's about 32 ft lbs for my Archer.) Also be sure to clean the 'cigarettes' at the spark plug end of the spark plug wires with something like MEK to avoid arcing around the spark plug. Then I would do a quick run-up check and, if the problem persisted, ground the plane until a mechanic had found and fixed the problem. If the engine sounded fine I can't imagine that the engine RPM was actually going up and down several hundred RPM. A bouncing RPM indication is usually caused by a tach cable in need of replacement. "att news group" wrote in message ... I purchased a 1971 Cherokee 140 shortly after getting back into flying the first of this year. It is a marvelous plane, relatively inexpensive to fly and to maintain. The other night while flying with my instructor he asked me if I typically got this much vibration. I told him that it felt normal, however when I looked at the GPS on the steering column it was vibrating so much I couldn't read it. All indicators were normal, the engine sounded fine, the one exception was the RPM indicator was moving back and forth a couple of hundred RPM from the 2500 I had it set at. I haven't had a chance to fly again and my mechanic is on vacation until tomorrow. Any thoughts or ideas? Charles Graef |
"Mike Noel" wrote in message ... I would open up the cowlings and look over the engine very thoroughly for any obvious problems (cylinder cracks, loose spark plugs, loose spark plug wires etc.) then pull all of the plugs, make sure they are all in good shape, clean and gap them and swap the bottom and top plugs if they all appear serviceable. Be sure to torque to the correct specification when reinstalling them (it's about 32 ft lbs for my Archer.) Also be sure to clean the 'cigarettes' at the spark plug end of the spark plug wires with something like MEK to avoid arcing around the spark plug. Then I would do a quick run-up check and, if the problem persisted, ground the plane until a mechanic had found and fixed the problem. If the engine sounded fine I can't imagine that the engine RPM was actually going up and down several hundred RPM. A bouncing RPM indication is usually caused by a tach cable in need of replacement. Bingo. If the engine sounded right, I'm sure it was fine. A 50 rpm swing is noticable. A couple of hundred rpm swing would be attention grabbing in the "Hit hte NEAREST button on the GPS" kind of way. KB |
On 5-Sep-2005, "att news group" wrote:
Any thoughts or ideas? A fluctuating tach with no other indication of engine problems is probably caused by a binding tach cable. Fairly easy and (by airplane standards) inexpensive to replace. However, if there was an accompanying unusual vibration, it could be any number of things. Did you try running on only left and right mags? If the problem is anywhere in the ignition system (mags, ignition harness, plugs, that will confirm it and tell you which side has the problem. -- -Elliott Drucker |
If you actually getting more vibration than normal and a fluctuating
tach then there is a problem that needs to be looked at before further flight. Michelle wrote: On 5-Sep-2005, "att news group" wrote: Any thoughts or ideas? A fluctuating tach with no other indication of engine problems is probably caused by a binding tach cable. Fairly easy and (by airplane standards) inexpensive to replace. However, if there was an accompanying unusual vibration, it could be any number of things. Did you try running on only left and right mags? If the problem is anywhere in the ignition system (mags, ignition harness, plugs, that will confirm it and tell you which side has the problem. |
I ran the plane again late this afternoon, after de-fouling the plugs by
leaning it out during run-up at 2300 RPM. It flew fine, I didn't notice any vibration, nor were there any wild fluctuations on the tach, I flew it about 20 minutes. I then did a couple of touch and goes at a nearby airport. On the way back to my home base again I saw the RPM fluctuate and I thought I detected a little roughness in the way the engine ran. There certainly has been no corresponding fluctuation in engine noise with the fluctuation in the Tachometer. Thanks for everyone's suggestions, I am going to have my mechanic look at it tomorrow. I'll let everyone know what he finds. Charles Graef "Kyle Boatright" wrote in message ... "Mike Noel" wrote in message ... I would open up the cowlings and look over the engine very thoroughly for any obvious problems (cylinder cracks, loose spark plugs, loose spark plug wires etc.) then pull all of the plugs, make sure they are all in good shape, clean and gap them and swap the bottom and top plugs if they all appear serviceable. Be sure to torque to the correct specification when reinstalling them (it's about 32 ft lbs for my Archer.) Also be sure to clean the 'cigarettes' at the spark plug end of the spark plug wires with something like MEK to avoid arcing around the spark plug. Then I would do a quick run-up check and, if the problem persisted, ground the plane until a mechanic had found and fixed the problem. If the engine sounded fine I can't imagine that the engine RPM was actually going up and down several hundred RPM. A bouncing RPM indication is usually caused by a tach cable in need of replacement. Bingo. If the engine sounded right, I'm sure it was fine. A 50 rpm swing is noticable. A couple of hundred rpm swing would be attention grabbing in the "Hit hte NEAREST button on the GPS" kind of way. KB |
Well the verdict came in today, the Tach cable needed to be lubricated.
Problem solved. Thanks for all the feed back. Charles "att news group" wrote in message ... I ran the plane again late this afternoon, after de-fouling the plugs by leaning it out during run-up at 2300 RPM. It flew fine, I didn't notice any vibration, nor were there any wild fluctuations on the tach, I flew it about 20 minutes. I then did a couple of touch and goes at a nearby airport. On the way back to my home base again I saw the RPM fluctuate and I thought I detected a little roughness in the way the engine ran. There certainly has been no corresponding fluctuation in engine noise with the fluctuation in the Tachometer. Thanks for everyone's suggestions, I am going to have my mechanic look at it tomorrow. I'll let everyone know what he finds. Charles Graef "Kyle Boatright" wrote in message ... "Mike Noel" wrote in message ... I would open up the cowlings and look over the engine very thoroughly for any obvious problems (cylinder cracks, loose spark plugs, loose spark plug wires etc.) then pull all of the plugs, make sure they are all in good shape, clean and gap them and swap the bottom and top plugs if they all appear serviceable. Be sure to torque to the correct specification when reinstalling them (it's about 32 ft lbs for my Archer.) Also be sure to clean the 'cigarettes' at the spark plug end of the spark plug wires with something like MEK to avoid arcing around the spark plug. Then I would do a quick run-up check and, if the problem persisted, ground the plane until a mechanic had found and fixed the problem. If the engine sounded fine I can't imagine that the engine RPM was actually going up and down several hundred RPM. A bouncing RPM indication is usually caused by a tach cable in need of replacement. Bingo. If the engine sounded right, I'm sure it was fine. A 50 rpm swing is noticable. A couple of hundred rpm swing would be attention grabbing in the "Hit hte NEAREST button on the GPS" kind of way. KB |
FWIW, I too had bouncing tachometer syndrome and lubricated the cable. I
believe it was original and so about 32 years old. After the lubrication the bouncing stopped but the cable broke in flight a few weeks later. The replacement cost was in the $30 range. You might also want to compare the RPM reading on your mechanical tach with that of a hand-held optical tach pointed out the windscreen. Mine was reading 80 RPM low, which explained why my fuel burn was higher than I expected and the static RPM was lower than expected. "att news group" wrote in message ... Well the verdict came in today, the Tach cable needed to be lubricated. Problem solved. Thanks for all the feed back. Charles "att news group" wrote in message ... I ran the plane again late this afternoon, after de-fouling the plugs by leaning it out during run-up at 2300 RPM. It flew fine, I didn't notice any vibration, nor were there any wild fluctuations on the tach, I flew it about 20 minutes. I then did a couple of touch and goes at a nearby airport. On the way back to my home base again I saw the RPM fluctuate and I thought I detected a little roughness in the way the engine ran. There certainly has been no corresponding fluctuation in engine noise with the fluctuation in the Tachometer. Thanks for everyone's suggestions, I am going to have my mechanic look at it tomorrow. I'll let everyone know what he finds. Charles Graef "Kyle Boatright" wrote in message ... "Mike Noel" wrote in message ... I would open up the cowlings and look over the engine very thoroughly for any obvious problems (cylinder cracks, loose spark plugs, loose spark plug wires etc.) then pull all of the plugs, make sure they are all in good shape, clean and gap them and swap the bottom and top plugs if they all appear serviceable. Be sure to torque to the correct specification when reinstalling them (it's about 32 ft lbs for my Archer.) Also be sure to clean the 'cigarettes' at the spark plug end of the spark plug wires with something like MEK to avoid arcing around the spark plug. Then I would do a quick run-up check and, if the problem persisted, ground the plane until a mechanic had found and fixed the problem. If the engine sounded fine I can't imagine that the engine RPM was actually going up and down several hundred RPM. A bouncing RPM indication is usually caused by a tach cable in need of replacement. Bingo. If the engine sounded right, I'm sure it was fine. A 50 rpm swing is noticable. A couple of hundred rpm swing would be attention grabbing in the "Hit hte NEAREST button on the GPS" kind of way. KB |
Similar Threads | ||||
Turn & Bank Indicator and 2 gallons of poyester resin | [email protected] | Piloting | 0 | February 12th 05 07:53 PM |
Indicator for Narco 12D | Mike Adams | Owning | 1 | July 6th 04 06:19 PM |
Inaccurate airspeed indicator | Wyatt Emmerich | Instrument Flight Rules | 20 | April 20th 04 12:08 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
ICom A-5 Question - Battery Level Indicator | Harry Gordon | Piloting | 22 | December 5th 03 12:07 AM |
